Member postings for Robert Atkinson 2
Here is a list of all the postings Robert Atkinson 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: digi phase converter for 10 machines.....
04/10/2023 23:13:48
Posted by Mark Rand on 04/10/2023 19:29:32:
Posted by Dave Halford on 04/10/2023 16:17:58:
Posted by Mark Rand on 04/10/2023 13:26:40:
Posted by Robert Atkinson 2 on 04/10/2023 01:58:13:
So they say to use a 71/2 HP inverter for a 2 HP motor i.e. > 3 times de-rating.
Whatever. The voice of hypothesis obviously trumps the voice of experience...
And the voice of hypothesis is of course the voice of the equipment supplier who ought to know what he's selling and why he's saying it.
Sorry, but the 7.5 hp Teco that is used has a rated output of 10.1kVA. with a 50% overload capacity for one minute on top of that. If you assume a 3 times rated current starting current, then you end up with the 7.5hp unit being happy to start 6.75hp motor.
That's my last post in this thread...
I was only quoting what the supplier says their equipment is capable of. Don't blame the messenger.
A lot of people including suppliers suggest de-rating the low-cost drives even when used as a normal VFD. I assume this is to improve reliability. The quality branded drives will of course run at their full rating 24/7 365 days a year with no issues.......
Robert.
04/10/2023 12:36:48
One problem with simple* "passive" converters is they do not provide 120 degrees of phase shift. This means you loose the low torque ripple advantage of 3 phase motors. This can affect surface finish and generate noise.
Robert.
* You can generate proper 3 phase passivly using capacitors to generate phase quadrature and then a a Scott-T trhansformer to get 3 pahases but as far as I know the low cost units don't do that..
04/10/2023 01:58:13
That is not what DD say. Quote :
"All this range of DIGITAL Plug and Play Converter allow you to take a 150% overload for 30 seconds so the 6HP starting requirement of the 2HP mill can be accommodated by this 7½ HP converter"
https://www.ebay.co.uk/itm/154157588494
Robert
03/10/2023 23:13:14
Posted by Mark Rand on 03/10/2023 08:57:57:
Posted by Robert Atkinson 2 on 03/10/2023 01:11:30:
The Drives Driect unit linked to by Mark Rand does not provide a neutral as standard. It requires an optional "neutral generator". Presumably a star transformer of some type and not just a resistor network. It also requires additional filters for some machines. Perhaps the unit you have included these. Unsurprisingly DD do not publish enough information to determine exactly what modifications they have done. Possibly none other than underrating it and setting for no or a very fast turn on frequency / voltage ramp. They certainly know how to charge for them though.
They now seem to sell only throgh ebay (odd for a "direct " company...) and currently don't list the required neutral generator or filters on ebay.
The 3-4 times underrating means that the 71/2 HP £3800 converter is not big enough for the OP task of a 4 HP load. He would need a 12 to 16 HP which may not be available. The 71/2 HP is stated as needing a 40A input supply so the larger one will presumably need a 80A feed, well above the OP's supply capacity.
Robert.
Where are you getting the 3-4 times unde-rating from??? The Teco VFDs that DD use have a 150% for 1 minute overload rating. DOL Starting a 4hp motor from a 7.5 hp rated VFD is no problem. The 'extra work' that DD do is to modify them to use a voltage doubler rather than a three phase bridge rectifier. I don't know whether they uprate the smoothing capacitors, but they might.
I do use a sine wave filter and delta/star grounded neutral generating transformer with mine, because I was already using them with a second hand Danfoss 23kVA VFD that I had used in the same role. That one was fed from a single phase step up transformer. But, in fact, very few three phase machines need the neutral, just a ground connection.
I have also re-programmed mine slightly and connected a time delay relay to the run signal contacts. This is so that it can live happily in the electronics/computer cupboard in the shed and automatically start when powered up from the switch on the wall. The VFD which gives variable speed for the dust extractor is similarly connected, but with control via a switched potentiometer.
I think that Clive and my experience of using the things trumps scare stories made from whole cloth...
Edit to add:-
I do wish that I had gone with Western Power Distribution's 2005 quote of £1.400 to replace the house's single phase supply with three phase. Trouble is that building the shed had already put me deeply in debt (it cost more than the bl***y house did!). Had I done that, I could plan for more solar panel/inverter capacity than now and for a fast charger for if we live long enough to get an EV. I did run 3ph cable from the breaker at the supply entrance to the shed, so that bit's done.
I might still do it at some time in the future, but only for the latter needs. The shed doesn't absolutely need it now.
Edited By Mark Rand
The 3-4 times de-rating is wht DD specify when using the unit as a 3 phase converter NOT as VFD. The OPis looking for a converter.
The difference is because there is no "soft-start" ramp up of voltage and frequency.
03/10/2023 01:11:30
Posted by Clive Foster on 02/10/2023 22:42:09:
Robert
My Drives Direct box provides me with a neutral line and, with the smoothing inductors, works exactly like proper three phase supply save for the limitation on motor power that can be started. Drives Direct says 5 hp, half the VFD rated load, I reckon 3 hp is more realistic if the motor is connected to any sort of load.
So far as I can see or measure it behaves sufficiently like real three phase for anything I wish to hang on it to be perfectly happy.
Appears to be a little less demanding on the single phase supply than my friends Transwave rotary converter of similar rating.
I can only presume the doubling of price from Drives Direct relative to the standard Teco VFD covers the needed modifications to make everything safe, effective and not send interference back down the lines. I've no intention of opening it up and winding the clock back 40 odd years to when I was supposed to be some sort of electronics engineer to check. Over a decade of successful operation proves that something must be right as all the magic smoke is still successfully contained.
That said I'd not even dream of installing something like that without output smoothing. The radiated interference from driving a naked line doesn't bear thinking about.
I'd prefer a proper mains three phase but given that it seems to be impossible to find someone willing to connect up the three phase income I have the "interim" device has to soldier on. Newt so permanent as a temporary fix.
Robert.
Thread: Winter Storage Of Locomotives
02/10/2023 21:50:16
Drain cocks open and heat up cylinders with hot air gun? A small squirt of WD 40 and then add o
Lidll sometimes sell a variable temperature hot air gun. Commom use is paint stripping.
Robert.
Thread: Where to get steam oil in Ireland
02/10/2023 18:30:04
It is on their website but not obvious:
https://maccmodels.co.uk/product-category/tools-drills-taps-oils-etc/oils/
Morris also sell steam oil but 5l minimum.
https://www.morrislubricants.co.uk/products/classsteam/cylinder-oils.html
Robert.
02/10/2023 17:42:21
Well you can't run a 20HP drive off 45A supply for starters.
The big issue with using a VFD is that they are designed to be permanently and directly connected to a MOTOR. They are not designed to drive control gear lights etc. The control gear almost certainly needs neutral connection which a VFD does not have. A single good quality 5kW VFD could run all your motors individually but you would have to interface the controls of each machine to the VFD. IF all the machines have just a single Start / Stop E-Stop control (and maybe reverse) than perhaps you could wire a single pendant to the VFD and then move it to the machine in use when you plug that machine's MOTOR into the VFD output.
To make it more fool-proof you could have a contactor at each machine that when energised connects that machine's MOTOR to the VFD. On each machine you have a socket for the control pendant to plug into. The paendant is interlocked with the contactors so only the machine that has the pendant plugged in is connected to the VFD.
A more complex variation would be to rewire the controls on each machine to a a set of relays that only connected them to the VFD when that machine was selected. That is a lot of work though.
There are some possible issues with VFD output cable lengths, EMC etc but it is workable. An output reactor may be required.
I'm surprised that you have ten 3 phase machines without a 3 phase supply. If only I had the room.....
Robert.
Edited By Robert Atkinson 2 on 02/10/2023 17:43:20
Thread: simple loop alarm for exhibits
02/10/2023 16:58:09
A loop alarm is a deterrent at all times and an aid when stand is attended. You can't watch everything all the time.
Electrically a loop pases current all the time and alarms if the current stops. Simplest implementation is a a relay. Loop is in series with the coil and power source. Buzzer / sounder is in series with nomally closed contact. Disadvantage of this is the relay coil uses a fair bit of current and is powered all the time so limits life on batteries.
At least one professional system I've seen used 3.5mm "headphone" jack plugs and in-line sockets with screened cable. The center conductor is the loop and the screen is connected to 0V. This can use cheap off the shelf audio extension leads. A low current (limited by a resistor) passes through the center conductor and keeps a two transistor circuit driving the sounder off. If the circuit is broken current stops and alarm sounds. The use of screened cable makes it very hard to bypass a section by pins or clips. If you push a pin through the cable it will short the center conductor to 0V diverting the current and causing the alarm to sound.
If you want I can do a sketch....
Robert.
Thread: Speedo gear size
30/09/2023 19:57:49
I agree with John. Normally with eddy current indicators the magnetic field strength is adjusted to change the calibration. Changing a return spring (normally a hairspring) will give coarse range change. The field can be adjusted by movable poles or how far the poles cover the disc or cup but often the actual magnet strength is changed.
On some aircraft instruments I've calibrated this often meant taking the magnet out, putting it in a magetiser / demagnetiser taking an educated guess at the energy setting required, zapping it, putting it back and re-checking the calibration. It you were doing a series of similar instruments you would get quite good at setting th level. If it was a one-off you might have many iterations.... If i awas a electric remote tachometer you had to do it twice. Once to set the output voltage from the generator and then the eddy current to calibrate the indicator.
You could always fit one of the modern electronic programmable speedos:
https://www.competitionsupplies.com/smiths-programmable-speedometers
Not cheap though...
Robert.
Thread: Old bearings never die...
30/09/2023 19:34:48
Posted by gerry madden on 04/09/2023 21:31:47:
Posted by Robert Atkinson 2 on 04/09/2023 10:37:37:
Requirement seems a little obsessive to me. Certainly during the working life of the aircraft they would not have bothered about the make. That is why there are standard size designations.
Not always so Robert. Even in some mundane applications that call up standard catalogue products, the cage type is considered important enough that certain manufacturers can be precluded from supplying. One example that comes to mind from my memory banks was the spot-welded steel cages that became popular in 1970s 'pop met' single row ball bearings. And it all happened again with the trend toward plastic cages in 1990s.
Gerry
Normally if there are specific requirements outside those controlled by the standard specification of a part the specification number would not be called up in the drawing or parts list. Typically either the equipment OEM would specify their own part number or they would call up a specfic part manufacturers stock or part number. This part manufacturers number might be a special for the aplication. Using their own part numer has the added benefit of controlling the market. Sometimes a standard part will be purchased and then one or more of inspection (often for specific characteristic(s). test, modification, treament carried out before using their own number for the part.
For aviation at least this means you should always refer to the approved documentation. Just because it says ACME 1234 on the part doesn't mean you can just buy an ACME 1234 and fit it. The OEM may have bought thousands of ACME 1234s and then selected the "best" ones for their application.
Robert.
29/09/2023 08:14:30
Not sure the Mini has an excentric bush. Due to the geometry of a worm and helix they can accomodate a tooth or two ratio range by adhusting the diameter and tooth shape. It changes the amount of engagement but as there is little power transmission in a spedo drive that is acceptable.
Don't know about the French test but in the UK the MOT only reqiures the speedometer to work. Assuming it is a regular annual test not a one of for approval after modification etc like the SVA in YK. There is no accuracy test. The construction rules say the speedometer must be accurate to -0 +10% when new. It also has to be "independant" so you can't use GPS.
IF accuracy is a requirement but it is over-reading can you just put a label on the speedos saying it over-reads by 20kph?
If you are of an electronics bent you could add a digital speedometer. There are plenty of RPM meter (same thing different calibration) designs and even modules out there. If the back of the speedo is plastic you can often pickup a signal from the rotating magnet inside using a coil attached to the outside.
Robert.
Thread: Average Energy Consumption
28/09/2023 19:56:08
That is not a good description. It misses out the important fact that the heat extracted from condensing the water vapour (latent heat of evaporation 2250kJ/kg) is used to heat the air circulated back into the drum.
It only uses about 20% of the energy of a conventional dryer. They release virtually no moisture to the house and little heat. According to SWBO it is also much more gentle on the clothes as the temperature is lower.
Robert.
Edited By Robert Atkinson 2 on 28/09/2023 19:56:37
28/09/2023 17:23:41
Even better than a condensing tumble dryer is one with a heatpump. Uses latent heat of evaporation to dry the clothes. No heater involved.
Robert.
28/09/2023 12:22:54
Sorry mis-read 2500 as 3500. 2kW 24/7 is still a lot of heat.
Robert.
28/09/2023 08:14:00
Posted by Joseph Noci 1 on 27/09/2023 16:56:44:
My house/workshop has been off-grid since Dec 2022 reliant on PV solar energy. Monthly usage averaged 1300KW over winter, with 2500KW generated. The excess is exported to the Electricity supplier at 60% consumption value.
I have hot water underfloor heating, which used to run from a solar heated water system, heating a 6000liter insulated water tank, buried in the ground. That heated water ( around 30degC in winter end of day) fed a 3phase 14KW boiler, and then into the pipes in the floors. The boiler was used during many low/no-sun days in winter.
In winter my floor heating energy used was around 50KW/24hour period - I did not run the boiler during day time, since electricity costs are almost double between 10H00 and 18H00. So the floors cooled during the day, and extra energy was needed at night to re-heat.
When I fitted the PV system ( 3phase, 28KW PV capacity) I fitted a Stiebel Eltron heat pump - a 3phase pump, with a variable speed compressor, to heat the floors.. The pump is capable of 12KW output, and is an Air extraction pump.
Since I heat the floor water to 35deg C max, and the floor water return temp is never below 20degC, the delta the heat pump sees is a max of 15deg, at start of heating, with the delta reducing as the floor heats up to 25deg setpoint.
All that gives me a pump COP of 10 (!) and I run day and night, so the floors don't cool in the day. That returns a daily heat output of around 33KW, with a consumption of around 3KW...
My monthly usage for floors in now around 100KW, instead of 1500KW - and THAT ticks all the boxes - energy cost, carbon footprint, comfort....
Lower COP's are to be expected if the water heating temp differential is higher, such as heating water for showers, etc ( 50degC plus..) - but this heat pump delivers a COP of 4 to 5 when doing that...
The heat pump did cost around 8K British Pounds...but is better than sliced bread.
I'm going to be pedantic...
You cannot be "off-grid" if you are exporting power back to the supplier
What is a Kelvin Watt (KW)
Do you mean killowatt kW?
KW is power not energy. Do you mean kWh?
Was the previous consumption, 3500 (assumed kWh) really ALL heating? Did you have a seperate meter on your heater? 3500 kWh in a month is 3 kW 24/7 that's a lot of heating....
It's a bit worrying that the heat pump reporting software also uses Kelvin Watt hours.....
Robert
28/09/2023 07:55:33
Posted by Michael Gilligan on 27/09/2023 20:49:35:
Posted by Robert Atkinson 2 on 27/09/2023 19:39:28:
There is more than one type of heat pump. I assume you are referring to the air to water type currently being promoted by the government. […]
Sorry Robert … to whom are you referring ?
If it is me, then I pretty clearly stated what I had been looking at … and that is not what you have assumed
Quote from the other thread:
Not straying too far off-topic, I hope
Does anyone have experience of these: **LINK** https://sahp.info
Solar Assisted Heat Pumps for domestic hot water
… I am tempted by the SAHP 130
Ref. further discussion on that post : **LINK**
Edited By Michael Gilligan on 27/09/2023 21:08:55
I was mainly refering to the output side of the pump. Even so the SAHPs are still air-water heatpumps. The key is in the "assisted" in the name. They have a benefit from a degree of solar capture when the sun is shining. How much this affects the air operation is not clear.
Robert
27/09/2023 19:39:28
There is more than one type of heat pump. I assume you are referring to the air to water type currently being promoted by the government. These have a issue that they don't produce very hot water so the whole system needs updating and probably larger pipes and radiators.
I've had heat pumps in my last two properties for over twenty years. These were / are air to air type units that provide heat in the winter and cooling in the summer. Heating is cheap and you don't have to use the cooling. The only downside is you need another means to supply hot water. I use an instant flow gas heater and an electric shower. You can also get electric instant flow heaters. The advantage of these is you are not loosing heat from stored hot water. YMMV but they are worth a look.
Robert.
Thread: Bolt or screw?
26/09/2023 19:30:16
I'm firmly in the fully threaded = screw, plain shank = bolt. For load bearing applications screws should only be in tension. Bolts can be in shear, tension or both.
There are always exceptions e.g. cap head screws but even the plain shank versions of those are normally used in tension.
You can replace a screw with a bolt but should never replace a bolt with a screw.
Robert
Thread: Peculiar electrical problem
26/09/2023 18:25:11
N-E connections up-stream of the RCD or consumer unit are immaterial to RCD operation and leakage currents.
The whole point of measuring L-N differential current rather than earth conductor current is to capture all leakage.
400mA of leakage is a bit excessive. I'd want to investigate what is going on. what is the current in the protective conductor?
One thing is if you have metalwork with a low resistance to ground connected to the mains ground your system may be passing some mains return (neutral) current from your neighbors. If theter is a neutral fault in the street you could be badly affected.
Radio amateurs on TNC-S can suffer from this when their RF earth, often extensive and low resistance, is connected to mains earth via their radios. With a neutrla fault 100's of amps can flow.
The latest guidnace on NOT connecting pipework etc to TNC-S systems seems to be a way of avoiding this inhernet problem with TNC-S The only advantage of TNC-S is lower cost to the network providers.
Robert.
