HQS taps and dies - anyone tried them?
Robin Graham22/07/2018 22:58:13
1089 forum posts
345 photos
I need some BSW taps and dies and had a look at the Tap and Die Company's website - they do them in something they call HQS: I quote:
"1/4 BSW tap = 1/4 x 20 BSW taps in taper second bottoming / plug EXCELLENT 1st quality HQS (Highest Quality Steel, considered a tougher and better alternative to HSS) cuts even into most stainless steel All in stock".
These are significantly cheaper than their HSS equivalents - which they say "cut stainless steel" - without the "most" qualifier note. Anyone know what this HQS stuff is, and if it's any good? "Highest quality steel" sounds a bit like vague marketing-speak to me. Might I be better off with plain old carbon steel? They're for a one-off in brass and ali, and as I rarely work in imperial I don't want to shell out for HSS if I can avoid it.
Robin.
GoCreate22/07/2018 23:50:37
387 forum posts
119 photos
HQS taps and dies are carbon steel, I couldn't testify as to the steel grade or quality but HQS taps that I have bought have looked ok and worked well on a range of materials. Cheaper carbon steel taps have in some cases been ok and other cases terrible.
IMO for a tap or die that isn't to be used often then buying HQS will be a better guarantee of a tap or die that will cut a good thread otherwise, buy cheaper carbon steel taps ahd dies from and reputable supplier who will replace a faulty product.
Nige
Edited By tractionengine42 on 22/07/2018 23:51:34
JasonB23/07/2018 07:01:16
Have a search of te hforum, HQS has come up a few times.
The couple that I have cut OK.
Old School23/07/2018 07:12:49
426 forum posts
40 photos
Have a look at Arceurotrade website they are selling off their imperial tsps dies.
Mike Poole23/07/2018 08:45:33
3676 forum posts
82 photos
I have a couple of box sets from Tap &Die and they are good quality carbon steel, I think they would do well to drop the HQS thing as it is near meaningless and casts doubt in people's minds about what they are buying. I am pleased with what I purchased as I wanted to be in a position of having the right tap and die to hand and as they need replacing I will go for HSS ground thread as the ones I use most should need replacing first. Some people like to keep cutting tools for brass separate from steel tools or use them on steel after they lose that new keen edge on brass.
larry phelan 123/07/2018 08:54:30
1346 forum posts
15 photos
Never heard of that stuff before. I thought there was only HSS or Carbon.
I live and learn !
old Al23/07/2018 09:01:58
187 forum posts
The price sound good at the start. By the time you get to the bottom line and its too late to back out of the deal, you are not saving much.
Everything out of india is 'best quality'. I would hate to see something come out of India that was not graded that way.
Generally pleased with what i have had from tap and die company, but feel their are better alternatives available.
You do get a free pen, so it must be good!
Michael Gilligan23/07/2018 09:20:50
23121 forum posts
1360 photos
Posted by Robin Graham on 22/07/2018 22:58:13:
I need some BSW taps and dies ... 1/4 BSW ...
Given that procurement spec, I would be astonished if you couldn't find what you need at a local Car Boot Sale.
larry phelan 123/07/2018 11:15:52
1346 forum posts
15 photos
Almost everything you see is advertised as "Best quality"
I am reminded of the old saying that " A fishwife never sells rotten fish,it,s always fresh fish "
Same difference ?cheekywink
peak423/07/2018 11:17:11
2207 forum posts
210 photos
I've no experience of either HQS, or this retailer, but am a little curious as to their marketing.
From their web site. Quote;
Our HSS-GT Ground thread range are made to precision ISO-529 making them very superior precision tools for machine or hand tapping - cuts stainless steel
Our HQS (=Highest Quality Steel) range (sold since 1978) are made to BS-949 are found to be a tougher and better alternative to HSS taps & dies and are lower in price and excellent quality and used for hand or machine tapping - cuts most stainless steel
When I looked up BS-949, it seems that it has been replaced by ISO-529 LINK
Is it just me that feels that this could be a bit misleading?
Bill
pgk pgk23/07/2018 11:33:40
2661 forum posts
294 photos
Posted by peak4 on 23/07/2018 11:17:11:
Bill
Since those documents appear to relate to tap dimensions rather than material quality I don't think that's an issue... just a switch to eu/international standards rather than imperial.
pgk
Nige23/07/2018 11:34:23
370 forum posts
65 photos
Peak4: I don't think it is misleading as long as they were made to the original BS-949. The fact that the standard has been renumbered doesn't necessarily mean the old standard isn't any good 😊
Neil Wyatt23/07/2018 12:06:52
19226 forum posts
749 photos
86 articles
HQS and HQSS both come up every few years:
www.model-engineer.co.uk/forums/postings.asp?th=37121
www.model-engineer.co.uk/forums/postings.asp?th=132869&p=1
www.model-engineer.co.uk/forums/postings.asp?th=90393
www.model-engineer.co.uk/forums/postings.asp?th=61373
Brian H23/07/2018 12:17:51
2312 forum posts
112 photos
I bought a set of BSF from The Tap & Die Company a few years ago to help with maintaining an Austin Seven and can only say that the set has been well used on steel, cast iron, aluminium and brass/bronze with no problems.
I would certainly use T&D for any future buys.
SillyOldDuffer23/07/2018 12:50:09
10668 forum posts
2415 photos
'Quality' must be a contender for being most misused word on the planet! No engineer should take it seriously without a definition of how 'quality' can be measured. Any talk of quality in the absence of a specification is probably b*ll*cks.
However, these taps might well be made of a real thing. 'HQS' was used by our sloppy forefathers to indicate a high-carbon tool steel. No more, no less. As steel alloys go it's cheap and not difficult to make. Because it has the property of being particularly sharp and hard, high-carbon tool-steel makes decent hand taps and dies. On the downside, it's brittle and loses hardness at low temperatures, so not suitable for power tapping or clumsy operators.
Most engineering is about compromise. As one who infrequently threads soft-ish metals I've had perfectly respectable long-term results out of carbon-steel taps and dies. If I did a lot of threading of more difficult metals, it's likely that a more expensive set would pay off. In context of 'how much' and 'how often' I have to decide what I mean by 'quality' : a seller using the word in an advert is unlikely to help. I have to look deeper, which is what Robin did by asking his question. As his requirement is minimal, I think MichaelG's advice is spot on: 'Given that procurement spec, I would be astonished if you couldn't find what you need at a local Car Boot Sale.'
JasonB23/07/2018 13:22:20
It's strange how many here rush to recomend Tracey Tools then get all uptight about HQS.
Maybe take a closer look at what you got from Tracey as they quiet often supply T&D Co HQS. That's where the ones I have came from.
Mick B123/07/2018 13:58:15
2444 forum posts
139 photos
Clarke's taps and dies are made of summat they call 'high quality tungsten steel' - I wonder if that's the same or similar stuff? HQTS?
Certainly got no issue with it - for my sort of use, one set lasted 15 years before enough of them became blunt, chipped or broken to justify buying a new set (which, incidentally, appears better-ground than the old).
Vic23/07/2018 13:59:20
3453 forum posts
23 photos
As a point of interest I bought a HSS M2.5 Tap on eBay from China a couple of weeks ago for 99p inc postage and what turned up was a quality Yamawa branded Japanese tap. One uk supplier wanted £15.54 inc postage.
peak423/07/2018 14:06:50
2207 forum posts
210 photos
Posted by Nige on 23/07/2018 11:34:23:
No I'm not suggesting either standard is "Better"; it's just that they way I read the quote suggested to me, that the HSS taps were reputed to be "Superior", due to them being made to ISO-529 rather than its predecessor BS-949 (and not the material they were made from, which I don't think is covered in either standard anyway).
The quote then goes on to say that HQS is a "better" alternative to HSS anyway. dont know
Just struggling to get my head round "advertising speak", and not having a dig at either product; I suspect both would do most jobs I threw at them.
Bill
Neil Wyatt23/07/2018 15:25:05
19226 forum posts
749 photos
86 articles
Some carbon steel can be made harder and sharper than some HSS, although this doesn't mean it is more durable or less likely to lose its temper.
It does mean that contradictory claims can be founded on truth, even if they shed little light.
N.
