Simon Robinson 4 | 14/02/2018 16:22:15 |
102 forum posts |
I think the steam locomotive was far more technologically advanced for its time than any jet airliner is today. Even looking at an A1 Pacific there is far more to it than the jet engine. The jet engine is relatively simple, fans that get smaller as the force air into a narrow appeture to combust it. Attached to wings a body and tail. The steam engine is far more complex than that. Fire tubes, superheater elements , firebox stays. Even the complex shaping of the firebox end and boiler barrel that holds immense pressure, a pressure able to pull hundreds of tonnes of freight. All manner of steam pipes and tubes, water injectors, lubricators. Accurately timed valves and Walcherts valve gear that to this day I have difficulty understanding. So is the Steam locomotive far ahead of its time compared to airliners?
Speedy Builder5 | 14/02/2018 16:31:33 |
2878 forum posts 248 photos | I think you may be confusing the issue. The steam engine like the jet engine is just one part of the vehicle. If you take the number of parts for the steam engine on its own, it pales into insignificance with the pieces of a jet engine surely. The fuel and management system of the steam engine also has fewer parts than the fuel and management system of the jet engine (Unless you are talking about a V1 rocket motor). As for the steam loco being more advanced for its time, then that has some merit for debate. |
not done it yet | 14/02/2018 17:15:17 |
7517 forum posts 20 photos | Are we comparing apples with apples? Are we comparing airliners with a steam engine, or just the jet engine with a whole locomotive? |
Brian G | 14/02/2018 17:17:05 |
912 forum posts 40 photos | I'm not sure I would call an A1 Pacific "advanced" when it was little different from a locomotive built 100 years before. Larger size, different valve gear, higher pressures, piston valves, injectors and mechanical lubrication were all incremental changes to a basic design that went at least as far back as the Planets, if not Rocket itself. The gas turbine, like the steam turbine before it, was a complete technological leap in performance, materials and manufacture away from the reciprocating engines that it replaced. As far as "for its time" goes, the interval between the Pen-y-Darren locomotive and the GWR Iron Duke class is similar to that between the Wright Flyer and the DC-3. Brian Edited By Brian G on 14/02/2018 17:23:52 |
Stephen Millward | 14/02/2018 18:13:15 |
23 forum posts | I recently visited Didcot and was struck by how basic steam locomotives are, - probably part of their appeal. Also I suspect much of the design work was by rule of thumb and trial and error. A single engineer (highly skilled) could have designed a steam loco, - could a single person design a modern jet? I doubt it. |
Dave Halford | 14/02/2018 20:49:19 |
2536 forum posts 24 photos | Mostly Sir Frank Whittle so I don't doubt it at all |
SillyOldDuffer | 14/02/2018 22:18:03 |
10668 forum posts 2415 photos | I suggest it's a misunderstanding to think that jet engines are simple. Although the principle of driving a fan with exhaust gas might be easy enough, it's much harder to build a working engine. And another series of difficult development challenges to make it lightweight, efficient, maintainable and reliable. Hundreds of tough problems have to be solved, for example:
Back in the day, steam engines presented equivalent difficulties. Early on much of the science was poorly understood, materials undeveloped, skills rare and technology primitive. Technology doesn't stand still and by 1920 the steam locomotive was pretty much as good as it could be. After 1920 only small improvements to steam reciprocating engines were left to do. Although steam was done, the technologies and benefits it had sparked continued. I say that the steam engine is father to most modern technology. Although the Victorians couldn't build a jet engine, much of what we know and do is built on their foundations. If they hadn't done what they did, we wouldn't be making jet engines either. Dave |
julian atkins | 14/02/2018 23:13:35 |
![]() 1285 forum posts 353 photos | Hi Simon, Not sure this is the best forum for your question. Have you come across NatPress? Some poor sod in LNER and BR days was paid a pittance to shovel tons of coal into an A1 firebox getting backache and blister on his hands, scorched legs, and covered in coal dust. The same poor sod had to work the injectors and keep a watch on the water gauges on a draughty cab. He would have to get up at all hours of the day and night on shiftwork and was not paid enough to own a car so would walk or cycle to work in all weathers probably from a small terraced house or council house. Some other poor sod had to shovel out a smokebox of ash, and empty the firebox of clinker, if the fireman was lucky not to have to do this also. No covered accommodation for this - the wind would blow everything all over you and if it was raining you got soaked. The fireman would have to go down and couple up the coaches or goods vehicles to the loco/tender which was precarious and risky and also very dirty. Long shifts at unsocial hours, and to no set pattern. Then you get a poor loco long overdue for a shopping that shakes you to bits and gives a very rough ride and steams poorly and you spend your whole shift in discomfort and struggling to make steam. You finish your shift filthy dirty and your home does not have a modern bathroom, neither do you have facilities at work to wash and change before going home. (Suggest you read Harold Gasson's books) Cheers, Julian |
Hopper | 15/02/2018 05:22:10 |
![]() 7881 forum posts 397 photos | You have got to be kidding. A 747 has six million parts, almost 200 miles of wire and five miles of tubing. The cabin pressurising and air conditoning system alone is more hi-tech than any steam train ever made. Let alone all the stuff in the cockpit control panel and the systems it links to.
Phil Stevenson | 15/02/2018 06:29:21 |
90 forum posts 13 photos | Wasn't / isn't each form developed as highly as technology and accountancy allowed in its day to be as efficient and reliable as possible. Steam reached the end of its road when diesel and electric was deemed a better option and we have to assume the jet engine will be superceded at some point too. |
richard 2 | 15/02/2018 08:35:18 |
127 forum posts | Hi Julian Sixty years ago I was a steam loco driver. I enjoyed every moment of it and I bitterly regret that I am now too old to drive as a volunteer. I never objected to getting up at all odd hours and, if it was possible I would go back to firing and driving right now! Why were there so many youngsters who would give anything to climb on board a "King" or "Castle" knowing that they had years of cleaning and firing before they grabbed hold of that beautiful handle and felt her get hold of the load. Every job has some disadvantages and firing and driving steam locos no more than any other. Were you a driver? Richard. |
Neil Wyatt | 15/02/2018 09:16:13 |
![]() 19226 forum posts 749 photos 86 articles | I think Julian has point, but it is amusing how many people spend large amounts of time and money to recreate that experience in miniature I think the original question misses a key point. At any time and place in human history something is the cutting edge technology. Even stone axes. At one time it was the steam engine. For a brief period in Victorian times it may have been the electric car. During the first World War it was almost certainly aircraft. At other times many things compete - in WW2 radar, the emerging jet turbines, computing. The term 'ahead of its time' is often mis-used too. It doesn't really mean 'this is something from the future', it means 'this technology failed because materials or other supporting technologies weren't up to supporting its development or implementation'. The gas turbine is interesting because its principles were well understood in the 19th century, but the applications were limited by the materials available. The much lower demands on metallurgy of steam engines allowed their greater refinement and spread. Neil |
Martin Kyte | 15/02/2018 09:22:32 |
![]() 3445 forum posts 62 photos | This does raise the interesting question of how do you define technically advanced. I would suggest it is not the same as complexity which would correllate strongly to the componant count. Perhaps a helpful guide would be how the hardware 'manages' the particular physics involved in the device. To take the example suggested of the Steam engine and the Jet engine the physics would be largely Thermochemistry (combustion) Thermodynamics (energy transfer) and Fluid dynamics (gas flow). On this basis the steam engine having a less well developed theoretical model on all three counts than the Jet engine should be more technically advanced assuming that a closer understanding of what is actually going on with the physics allows a closer approach to an ideal design. Simplicity does not per se equate to technical primitiveness. Jet nozzles can now be developed extremely precisely using finite element anlysis, something that was not possible when designing steam injectors for example. That said with modern computer modeling it should be possible to design a more technically advanced steam engine than anything that was around in the past. Maybe a new category for a Model Show Trophy? So yes I would say the Jet engine is more technically advanced than the steam engine. regards Martin |
richardandtracy | 15/02/2018 09:41:58 |
![]() 943 forum posts 10 photos | Was the steam loco as cutting edge technology in the 1920's as an aircraft is now? No. By the 1920's steam engines were old hat and had significantly failed to improve efficiency, running costs and improve design life. Look at Chapelon's and Porta's work on developing steam technology. They did nothing that was not possible in the 1920's using 1920's knowledge, theory and equipment. Porta in particular took a 1920's steam loco and made it more efficient and cheaper to run than a diesel for 10 years in the 1980's, keeping a coal mine in Argentina viable. The fact that the work was not done in the 1920's speaks volumes of how far back locos were from the cutting edge. Porta's work really emphasised the inefficiencies and poor design in steam locos that were there all the time. In the 1920's an aeroplane was the cutting edge technology. Aircraft still are cutting edge technology because of the pressure of the fact an aircraft is such a phenomenally expensive bit of kit to run and in a hugely competitive industry. If 1% can be shaved off the fuel consumption or manufacturing cost, it's a major cost saving. If a part can be made lighter, it can contribute to fuel saving. If a bit can be made more reliable and lighter, even better. If it can be made lighter, cheaper & more reliable everyone wins. That's what's driving 3D printing in aircraft bits, and is as 'forefront of technology' as you can get. In the 1920's there was the same drive to get bigger aircraft, increase range, more passengers, fewer deaths. The forefront of technology at the time was in petrol engines and the conversion from wood to the new wonder material, aluminium. All happened in aircraft, not locos. The developments in locos in the 1920's were brute force & ignorance developments, more power, more fuel & more pressure. There was no finesse in the understanding & application of the engineering. Regards, Richard.
Ian S C | 15/02/2018 10:44:52 |
![]() 7468 forum posts 230 photos | The difference between a B 747 and a B787 is almost as great as the difference between a DC-3 and the B 747, yet the B-52 bomber designed in the early 50s is expected to out last it's successors, the B-1, and B-2 and continue in service until at least 2050, a case of best for service. Ian S C |
Cornish Jack | 15/02/2018 11:10:35 |
1228 forum posts 172 photos | Not on topic but why do people consistently refer to 'jets' and 'jet aircraft' when they mean gas turbine powered aircraft. We don't refer to similarly powered warships or power stations!! I could see the aeolipile or Hero's steam engine as jets or, at a stretch, the Fairey Rotadyne. Maybe one should refer to Spitfires, Hurricanes et al as 'props' rgds Bill |
KWIL | 15/02/2018 11:30:56 |
3681 forum posts 70 photos | The Fairey Rotadyne units were of course RamJets with no moving parts like fans and compressors. Also **** noisy. |
Brian G | 15/02/2018 11:33:40 |
912 forum posts 40 photos | Posted by Cornish Jack on 15/02/2018 11:10:35:
Not on topic but why do people consistently refer to 'jets' and 'jet aircraft' when they mean gas turbine powered aircraft. We don't refer to similarly powered warships or power stations!! I could see the aeolipile or Hero's steam engine as jets or, at a stretch, the Fairey Rotadyne. Maybe one should refer to Spitfires, Hurricanes et al as 'props' rgds Bill Perhaps because jet aircraft are jet propelled in the same way as a jet-ski or a squid, by reaction to a jet of their working gas or fluid. Describing aircraft as gas turbine would lead to confusion as there are turbojet (747), turboprop (Viscount) and turboshaft (helicopter) gas turbines. Brian |
Hopper | 15/02/2018 13:22:40 |
![]() 7881 forum posts 397 photos | Posted by Neil Wyatt on 15/02/2018 09:16:13:...
... The gas turbine is interesting because its principles were well understood in the 19th century, but the applications were limited by the materials available. The much lower demands on metallurgy of steam engines allowed their greater refinement and spread. Neil The same applied to the internal combustion engine in the early 20th century. All the exotic stuff we take for granted today like super high compression ratios, high rpm engines, desmo valves, overhead cam, etc etc were all known about and used experimentally in the 1920s, but it was the state of the metallurgy that stopped them going mainstream until after WW2, when great advances in metallurgy were made. Even steam turbines required exotic metallurgy back in steam engine days. There is a sugar mill near where I live (well about 800 miles away, close enough) at Bundaberg that is still powered by reciprocating horizontal steam engines -- built and installed in 1948 because Australia didn't have the metallurgy to build steam turbines and post-war austerity measures forbade the import of turbines from overseas at that time. But they did have a local locomotive manufacturing works that could turn its hand to mill engines if need be. How cool is that?
FMES | 15/02/2018 14:59:04 |
608 forum posts 2 photos | Don't see too many loco's of any sort flying about. Regards Lofty
