Paul Lousick | 19/12/2017 06:09:49 |
2276 forum posts 801 photos | What do you use in the home workshop for pickling/cleaning stainless steel after welding. I would prefer to use something a little safer than sulphuric acid. Paul. Edited By Paul Lousick on 19/12/2017 06:10:38 |
Sandgrounder | 19/12/2017 06:27:32 |
256 forum posts 6 photos | Where I worked the welders used a proprietary white paste which had a weak ( 2-3%? ) solution of Hydrofluoric acid plus Nitric acid in it, it worked well and being a paste wouldn't splash but I think that would be also too nasty to use at home due to the HF.. John |
not done it yet | 19/12/2017 07:03:15 |
7517 forum posts 20 photos | would prefer to use something a little safer Wouldn't we all! But do remember that even dihydrogen monoxide can be lethal in the wrong circumstances. If used properly and utilising all the ppe recommended, sulphuric acid is safe to use. I would not say perfectly safe because there is always the human element, of the operation, that may not be reliable. It is concentrated sulphuric acid one should really worry about - a great deal more than pickling concentrations. I used hot concentrated acids and alkalis at work and it never bothered me - because we took the necessary precautions for handling such corrosive (or poisonous) compounds. Presumably you never arc weld? Never use oxy acetylene (or oxypropane or even propane/air) to heat things really hot? Would never contemplate using anything as dangerous as a lathe or milling machine? Do your risk assessment, take all reasonable precautions - and it will be safe enough.
Roderick Jenkins | 19/12/2017 09:00:16 |
![]() 2376 forum posts 800 photos | Posted by Sandgrounder on 19/12/2017 06:27:32:
Where I worked the welders used a proprietary white paste which had a weak ( 2-3%? ) solution of Hydrofluoric acid plus Nitric acid in it, it worked well and being a paste wouldn't splash but I think that would be also too nasty to use at home due to the HF.. John Sounds a bit like this stuff **LINK** sold for use in a domestic environment Rod |
not done it yet | 19/12/2017 10:18:12 |
7517 forum posts 20 photos | Sounds a bit like this stuff **LINK** sold for use in a domestic environment........and clearly has a label which says 'danger' on it!
Edited By not done it yet on 19/12/2017 10:20:03 |
mark smith 20 | 19/12/2017 10:22:18 |
682 forum posts 337 photos | Posted by Roderick Jenkins on 19/12/2017 09:00:16:
Where I worked the welders used a proprietary white paste which had a weak ( 2-3%? ) solution of Hydrofluoric acid plus Nitric acid in it, it worked well and being a paste wouldn't splash but I think that would be also too nasty to use at home due to the HF.. John Sounds a bit like this stuff **LINK** sold for use in a domestic environment Rod Funny i was watching people using this on you tube last week, most had no gloves on or anything at all. Its a mixture of Barium sulphate,Sulphuric acid and Fluoride salts ,obviously produces a weak HF solution due to the sulphuric acid and fluoride. According to the MSDS for Armour etch, 160cm2 of skin coverage can lead to hypercalcaemia (which is only around 4"- 5" square area) |
Samsaranda | 19/12/2017 10:37:22 |
![]() 1688 forum posts 16 photos | Can't believe that a product as dangerous as glass etching cream is available mail order with no controls over who accesses it. HF acid no matter how it's generated is a very dangerous substance, then as you can buy various strengths of hydrochloric and sulphuric acid also by mail order I am not surprised. Dave W |
Roderick Jenkins | 19/12/2017 10:53:16 |
![]() 2376 forum posts 800 photos | It's amazing the dangerous things you can buy if you know where to look. I went into a shop the other day and they had lathes and milling machines for sale - so irresponsible of the vendor to make items available that could seriously injure the user. Rod |
mark smith 20 | 19/12/2017 11:03:29 |
682 forum posts 337 photos | They dont even wear gloves on the official videos. A bit silly really even if it is relatively tame compared to HF, id advise wearing gloves with any sort of chemicals. Edited By mark smith 20 on 19/12/2017 11:04:48 Also a rather amusing thread on this forum. Hence why gloves should be worn. http://www.wetcanvas.com/forums/archive/index.php/t-216350.html Edited By mark smith 20 on 19/12/2017 11:10:37 |
Oldiron | 19/12/2017 14:16:33 |
1193 forum posts 59 photos | Posted by Roderick Jenkins on 19/12/2017 10:53:16: It's amazing the dangerous things you can buy if you know where to look. I went into a shop the other day and they had lathes and milling machines for sale - so irresponsible of the vendor to make items available that could seriously injure the user. Rob ------------------------------------------------------------------------- I went to get a piece of glass the other day and there were broken pieces laying all over the floor in the glass shop and there people working around it. Why would they make such dangerous stuff. I cannot imagine what use it would be. :- 0 regards
Edited By Oldiron on 19/12/2017 14:17:20 |
Russell Eberhardt | 19/12/2017 15:31:18 |
![]() 2785 forum posts 87 photos | Posted by not done it yet on 19/12/2017 10:18:12:
Sounds a bit like this stuff **LINK** sold for use in a domestic environment........and clearly has a label which says 'danger' on it! Also says, "MAY BE FATAL" Russell |
not done it yet | 19/12/2017 15:44:26 |
7517 forum posts 20 photos | Also says, "MAY BE FATAL" More than dihydrogen monoxide in the wrong concentration?
Edited By not done it yet on 19/12/2017 15:45:15 |
mark costello 1 | 19/12/2017 17:53:11 |
![]() 800 forum posts 16 photos | They even deliver dihydrogen monoxide to My house and have the nerve to want Me to pay for it. Crafty scheme! |
John McNamara | 20/12/2017 11:29:27 |
![]() 1377 forum posts 133 photos | This is why some chemicals are different? They can sneak up on you. Weak hydrofluoric acid, another sneak Rather different to a machinery injury where the danger is more obvious. you can see what happens if you stick any part of your body in danger. Regards |
Sandgrounder | 20/12/2017 12:38:31 |
256 forum posts 6 photos | Posted by mark costello 1 on 19/12/2017 17:53:11:
They even deliver dihydrogen monoxide to My house and have the nerve to want Me to pay for it. Crafty scheme! You could always ask to be disconnected if you're that worried about it. |
Bill Mull | 20/12/2017 12:57:22 |
33 forum posts | I stopped using pickling paste a while back and moved to using an electrolytic weld cleaning system called Weldbrush. It works great leaves a nice shiny finish on stainless steel. |
not done it yet | 20/12/2017 14:10:55 |
7517 forum posts 20 photos | You could always ask to be disconnected if you're that worried about it. Most of it is sent back - the supplly companies charge to dispose of 90% of the original delivery to residential customers! Further, they charge more for disposal and then supply it to other customers.
mark costello 1 | 20/12/2017 16:48:38 |
![]() 800 forum posts 16 photos | There is no end to the supply chain then! You can't be last? |
Martin Dowing | 20/12/2017 17:18:05 |
![]() 356 forum posts 8 photos | Being a chemist I do pay respect to hydrofluoric acid and there are rather few compounds which are causing my concerns. So for example sulfuric acid diluted or concentrated is nothing of particular concerns comparing to HF. Hydrochloric acid in comparison would be good handwash and cyanides only moderately poisonous. Burns from HF have delayed onset (8-24hrs) so at the time of contamination nothing is felt, they are chewing tissue down to the bone and meet falls off the wound and tissue around simply rot. Healing takes many months. Wounds of older or sensitive peoples may never heal. Sometimes aputations are necessary. Rubber gloves of industrial standard, rubber apron and face protection are mandatory and special paste made of calcium gluconate must be at hand to work into skin accidently treated with HF. Cacium gluconate paste applied promptly may (and often does) prevent development of said burns. Should be applied after initial washing with plenty of water BEFORE one seeks medical attention as time counts and waiting an hour or two or three will make it useless and doctors will have much more difficult case. Saying all that I must note that HF is used in hobbies, say by glass staining/etching artists. It is branch of litography. Martin |
Mick B1 | 20/12/2017 17:30:46 |
2444 forum posts 139 photos | Posted by Sandgrounder on 20/12/2017 12:38:31:
They even deliver dihydrogen monoxide to My house and have the nerve to want Me to pay for it. Crafty scheme! You could always ask to be disconnected if you're that worried about it. That'll not stop the airborne deliveries. |
