Marble or chalk?
RichardN | 06/08/2017 20:59:38 |
123 forum posts 11 photos | I picked up a tobacco tin of BA taps a few weeks ago at a boot sale, which aren't a full set but are in really decent nick- paid a quid but was then given several other tins of rusty taps, drills, and another tin with what look like marble but feel like chalk- some kind of stone sticks? I wondered if these were hard and could polish up the tip of a drill, or the flute of a tap, but they feel soft and chalky... about 5/16-1/2" in section if that helps?! Any thoughts? |
Mike Poole | 06/08/2017 21:10:37 |
![]() 3676 forum posts 82 photos | Have a look at Washita and Arkansas stones and see if they fit what you have. Mike |
John Baron | 06/08/2017 21:13:03 |
![]() 520 forum posts 194 photos | Hi Richard, It is chalk ! Actually its called "French Chalk" and it is usually used for writing on steelwork, often powered and used when mending punctures in your bike tyres tube, to stop the glue sticking to the inside of the tyre.
Edited By John Baron on 06/08/2017 21:14:46 |
Journeyman | 06/08/2017 21:16:28 |
![]() 1257 forum posts 264 photos | Water of Ayr Stone, used by jewellers to polish after soldering. John |
RichardN | 06/08/2017 21:19:47 |
123 forum posts 11 photos | Well that's three apparently different answers for a start! But seriously, thanks, I'll start googling with at least some sensible words now- the suggestions above all seem very plausible from a 10 second Google on each! |
Bazyle | 06/08/2017 21:42:09 |
![]() 6956 forum posts 229 photos | Just rub one on a bit of fine sandpaper or file If it produces fine white powder even more easily than blackboard chalk then it is French chalk. Given the quantity and inclusion with engineering tools rather than cyclists spanners I would guess a polishing stone is a distinct possibility. |
Kenneth Deighton | 06/08/2017 21:42:26 |
69 forum posts | Hi RichardN, it is known as "French Chalk " and is usually used in the "heavy" ( Blacksmiths) engineering world to mark out work that does not need the precision that lathe and milling machines need , the end of the chalk is usually ground to a sharp point. |
Nige | 06/08/2017 21:47:21 |
![]() 370 forum posts 65 photos | Water of Ayr stone. It looks like french chalk sticks but harder. I also have some in a tin. Used it long ago for removing very light blemishes from copper and aluminium. |
Andrew Johnston | 06/08/2017 21:55:20 |
![]() 7061 forum posts 719 photos | French chalk can be rubbed onto files to stop pinning. Andrew |
Vic | 06/08/2017 22:17:11 |
3453 forum posts 23 photos | Another vote for French chalk. I have a pack of it I bought for marking hot metal. |
Clive Hartland | 06/08/2017 22:29:50 |
![]() 2929 forum posts 41 photos | Looks to me like Soap stone, used to mark up steel plate etc. Clive |
jason udall | 06/08/2017 22:48:02 |
2032 forum posts 41 photos | Op has it...soft and chalky...defo soap stone or "french chalk"... |
Brian Wood | 07/08/2017 10:02:41 |
2742 forum posts 39 photos | An interesting side fact about soap stone [which is also my vote for these sticks] is that when it is heated and allowed to cool it is then hard, water resistant and resistant to wear. A useful property for fashioning low voltage electrical fittings, soft for easy working and durable when hard. |
Hopper | 07/08/2017 11:06:25 |
![]() 7881 forum posts 397 photos | Posted by Andrew Johnston on 06/08/2017 21:55:20:
French chalk can be rubbed onto files to stop pinning. Andrew So can ordinary chalk. (English chalk??) |
Georgineer | 07/08/2017 13:07:55 |
652 forum posts 33 photos | Looks like talc to me. I was brought up to call the solid talc, and the powdered form French Chalk. I think it's a magnesium compound, unlike ordinary chalk which is calcium carbonate. Blackboard chalk is actually calcium sulphate (gypsum, Plaster of Paris). George |
Russ B | 07/08/2017 14:02:22 |
635 forum posts 34 photos | Posted by Georgineer on 07/08/2017 13:07:55:
Looks like talc to me. I was brought up to call the solid talc, and the powdered form French Chalk. I think it's a magnesium compound, unlike ordinary chalk which is calcium carbonate. Blackboard chalk is actually calcium sulphate (gypsum, Plaster of Paris). George I thought I was the only one......... The guy changing tyres at the classic bike races looked at me like I was stupid when I mentioned grating talc on the tubes.......... he said, "No... use french chalk" in a very worried tone.... |
Russell Eberhardt | 07/08/2017 19:37:40 |
![]() 2785 forum posts 87 photos | Definately talc, otherwise known as French chalk. It is mined near Luzenac 1800m up in the Pyrenees in southern France. I visited the talc mine there last year. It is one of the world's biggest talc mines and is an open cast mine on a massive scale. Well worth a visit if you are anywhere near. A video on Imerys Talc website shows the scale of the mining operation. Talc has a very wide range of uses apart from stopping files pinning when filing aluminium and using on baby's bottoms. Russell |
mechman48 | 08/08/2017 19:07:12 |
![]() 2947 forum posts 468 photos | +1 for 'French Chalk', always keep a piece in my workshop coat pocket for rubbing on files when filing aluminium... & for rubbing on drill shanks when I can't read the impressed size. |
fizzy | 08/08/2017 20:37:54 |
![]() 1860 forum posts 121 photos | This is the composition of common talc, Mg3Si4O10(OH)2, and this is for Crysotile asbestos, Mg3Si2O5(OH)4. Both are usually mined next to each other and despite reassurances to the contrary I wont have it anywhere near me. |
Russell Eberhardt | 08/08/2017 21:11:22 |
![]() 2785 forum posts 87 photos | Posted by fizzy on 08/08/2017 20:37:54:
This is the composition of common talc, Mg3Si4O10(OH)2, and this is for Crysotile asbestos, Mg3Si2O5(OH)4. Both are usually mined next to each other and despite reassurances to the contrary I wont have it anywhere near me. Difficult to avoid Fizzy. It's an ingredient in lots of food and pharmaceutical products. It's in papers, paints, and plastics. Russell |
