Mark Williams 21 | 17/06/2016 22:36:16 |
![]() 42 forum posts 13 photos | Hi, When I complete my oscillating engine I won't have a boiler or anything live steam wise to run it on so obviously I will be running it on compressed air, so my question is what do people use for this? Mini-air compressor, aquarium air pump? Any suggestions please Many Thanks
Peter Krogh | 17/06/2016 22:40:01 |
![]() 228 forum posts 20 photos | Aquarium pumps may not do the job; not enough pressure. Air brush compressors will run most small engines but may cycle frequently depending upon the size of the engine and the size of the air receiver. I know guys who use the mini to fill an air tank of some sort so they can run quite a while.... Pete
Mark Williams 21 | 17/06/2016 22:45:40 |
![]() 42 forum posts 13 photos | Ok so the best option is buy a airbrush compressor and make/purchase a air tank for it while I build a steam boiler? |
Peter Krogh | 17/06/2016 22:58:23 |
![]() 228 forum posts 20 photos | Many auto parts stores sell air tanks to transport air to locations without compressors. Anywhere from about 2 gallons to 5 gallons size. Air brushes are very nice to have when painting models. Pete |
julian atkins | 17/06/2016 23:01:40 |
![]() 1285 forum posts 353 photos | For testing locomotive chassis I run them on air (not too long) but use Singer sewing machine oil which doesnt break down under condensate on air. Cheers, Julian |
Paul Lousick | 17/06/2016 23:43:51 |
2276 forum posts 801 photos | Auto parts stores also sell small compressors for inflating car wheels.
John Reese | 18/06/2016 02:54:07 |
![]() 1071 forum posts | I used a propane cylinder for a hand held torch as an air tank on my airbrush compressor to keep it from short cycling. |
Thor 🇳🇴 | 18/06/2016 06:11:14 |
![]() 1766 forum posts 46 photos | Hi Mark, I too use an air brush compressor for running my small oscillators. If your oscillator has little friction they don't need much pressure to run. For a simple to make low-pressure boiler see here. Thor |
Paul Lousick | 18/06/2016 06:27:47 |
2276 forum posts 801 photos | See previous post about powering small steam engines Edited By Paul Lousick on 18/06/2016 06:28:11 |
Mark Williams 21 | 18/06/2016 07:11:49 |
![]() 42 forum posts 13 photos | Morning gents, thanks for the advice, I've had a quick look online and an airbrush kit that contains a compressor with tank is only about 40-50 quid so I'll probably get one ordered today and as Peter said it'll be nice to have anyway for painting my future models 👍🏻 Mark 😎 |
john carruthers | 18/06/2016 07:43:43 |
![]() 617 forum posts 180 photos | Old fridge compressor? they are very quiet.
Edited By john carruthers on 18/06/2016 07:44:17 |
Howi | 18/06/2016 08:52:47 |
![]() 442 forum posts 19 photos | There are two ttypes of airbrush compressor, the piston type which produces high pressure but low volume and the diaphragm type which produces larger volume but lower pressure. This second type is better for small engines. |
Neil Wyatt | 18/06/2016 09:51:13 |
![]() 19226 forum posts 749 photos 86 articles | Do you have a cappuccino machine? You can run a small engine for a few minutes using a silicone tube on the frother (don't let your coffee addicted better half catch you though). Neil |
Martin Whittle | 18/06/2016 10:30:56 |
102 forum posts 12 photos |
On my Reeves Master engine, I made an inlet 'manifold' using a schrader tyre valve body as the inlet connector, silver soldered into a brass block. It runs well off a compressor, but will also run (less evenly!) using a bicycle pump Martin |
mechman48 | 18/06/2016 11:17:13 |
![]() 2947 forum posts 468 photos | I initially used a airbrush compressor with tank myself, the only fault is that it cycles frequently which is common for this type; I also have a larger compressor bought from M/Mart on one of their VAT free days, obviously this provides a larger volume of air, so it's dependent on your budget what you get. George. Edited By mechman48 on 18/06/2016 11:18:28 |
Ian S C | 18/06/2016 11:54:41 |
![]() 7468 forum posts 230 photos | I have a small medical compressor(30psi) that works well on small steam engines, it won't handle a Stuart Turner S9, double acting 1 1/2" x ! 1/2". For a quick test run I have a 5L garden spray pump, and that will run any of my little wobblers.
Hopper | 18/06/2016 12:28:15 |
![]() 7881 forum posts 397 photos | You can always make a simple boiler too, by silver soldering a couple of end plugs in a six inch length of 1.5" copper or brass pipe with suitable small pipe fittings for water fill and steam outlet. A cough drop tin full of cotton wool soaked in methylated spirits is all you need for a burner. |
Mark Williams 21 | 18/06/2016 15:16:14 |
![]() 42 forum posts 13 photos | Posted by Neil Wyatt on 18/06/2016 09:51:13:
Do you have a cappuccino machine? You can run a small engine for a few minutes using a silicone tube on the frother (don't let your coffee addicted better half catch you though). Neil You trying to get me divorced? Lol |
Mark Williams 21 | 18/06/2016 15:18:38 |
![]() 42 forum posts 13 photos | the plans for the oscillator I've all but finished also has plans for a simple boiler, I think that will have to be my next project. Thanks for all the advice 😄 |
SillyOldDuffer | 18/06/2016 20:09:06 |
10668 forum posts 2415 photos | Being a cheapskate I've used a car tyre foot pump with a plastic lemonade bottle as receiver to turn a small engine. Make two nozzles to fit through the bottle cap and connect between pump and engine with aquarium tubing. Cheap and cheerful and you get a real sense of how much work you have to do to keep a even small engine running. I've not managed to burst a bottle yet. Blood vessels yes - exercise isn't my thing! Dave |
