Here is a list of all the postings john carruthers has made in our forums. Click on a thread name to jump to the thread.
Thread: What Did you do Today 2022 |
12/09/2022 18:33:06 |
Today my grandson and I spent a pleasant hour in the shed.
Thread: pyrex is not PYREX |
11/06/2022 13:56:42 |
quick and dirty test for Pyrex, it has the same refractive index as many vegetable oils.
Thread: Layout tool |
03/06/2022 08:15:42 |
Hmm, shrinkage; as an apprentice I was working in the glass shop cutting glass for customers. |
Thread: Hello from Swansea |
20/02/2022 09:20:30 |
Hi Martin, I'm down the road in Port Talbot. |
Thread: What is this? |
16/02/2022 08:59:21 |
As a kid I would earn my pocket money by cleaning my old man's brass , an RM band sergeant, lots of blanco and brasso. |
Thread: Run out on bar |
11/11/2021 08:45:24 |
1: First check the runout of the chuck register and also the interior spindle bore. |
Thread: Filing machine uses? |
08/06/2021 08:22:25 |
Clickspring uses one for clock wheels and frames. |
Thread: Help , can someone provide me with some equations ! |
30/05/2021 08:52:09 |
It doesn't apply with your rubric, but a counter weight might simplify the working out? |
Thread: Any views on using Fairy Liquid in a concrete mix |
26/05/2021 09:16:03 |
As a plasterer's mate I used a few drops in a mixer load as a deflocculant to prevent the mix balling. |
Thread: Greetings from sunny south wales ! |
25/04/2021 09:02:04 |
Hello Noonoo, I moved to Port Talbot a couple of years ago and have more or less organised my shed now. |
Thread: What Did You Do Today 2021 |
02/01/2021 11:03:31 |
Start the year as I mean to go on, mucked out the shed, made a mandrel to hold a set of mod1 gear cutters, made a couple of trial gears. |
Thread: Door stay help |
12/08/2020 16:38:23 |
This sort of thing? |
11/08/2020 08:40:55 |
We would fit 'restrictor stays' as a safety option, mainly on tilt&turn windows on upper floors to avoid people falling through. They are a simple toothed bar that clips onto a stud. Edited By john carruthers on 11/08/2020 08:56:27 |
Thread: Stepper Motor Flexible Coupling. |
10/05/2020 10:34:59 |
We have used Oldham couplings for many years in telescope drives using steppers and VFO drives, never had a problem from the antarctic to the equator. |
Thread: Air supply to test run steam engine. |
08/05/2020 09:00:56 |
For testing I use either a plastic pipe from the coffee machine steam outlet, or a hand pumped garden sprayer. |
Thread: Holding glass lens for grinding |
27/04/2020 18:36:00 |
Ingals ATM vol 3 page 35 > Edited By john carruthers on 27/04/2020 18:37:01 |
Thread: What Did You Do Today 2020 |
01/01/2020 09:54:03 |
Thread: Adhesive to bond metal to glass |
01/01/2020 09:21:56 |
Try your local car dealership, they use a UV bond for attaching rear view mirrors to windscreens. |
01/01/2020 09:18:21 |
I ordered a set of mini saw blades (like slitting saws) from a Chinese supplier on xmas day, they arrived yesterday so I roughed out a 'scape wheel for the clock.. |
Thread: Resilient motor mount retaining clips. |
22/12/2019 09:09:38 |
Have you tried high modulus silicone sealant? squirt it into the rings, let it set off.
