Soldering cast iron with silver solder.
I did not think you could solder cast iron ?
Brian John13/06/2016 01:54:46
1487 forum posts
582 photos
I did not think it was possible to solder cast iron but this solder from Micro-Mark claims to be able to do that. It looks like it cannot be posted outside the US. Has anybody tried this product or something similar ?
Edited By Brian John on 13/06/2016 01:57:53
Peter Krogh13/06/2016 02:00:03
228 forum posts
20 photos
That's a low temp (430*F) 95% tin, 5% silver, solder. It works perfectly on most everything including stainless steel. But not aluminum. I've never tried it on cast iron. I suspect that it would work well on really clean cast iron. I have silver brazed cast iron with EZFlo. The iron must be absolutely clean. No old, greasy, machine parts. New iron. You should be able to find 95/5 under another name somewhere. It's important to use the acid flux recommended.
Pete
Edited By Peter Krogh on 13/06/2016 02:00:50
Edited By Peter Krogh on 13/06/2016 02:03:15
JasonB13/06/2016 07:32:11
I've soldered cast iron with Easyflow. Heat first to bring the carbon to the surface, wirebrush and then solder.
Last time the subject came up I posted this pic of Mike Sawyers Bently engine block which shows what can be done.
Neil Wyatt13/06/2016 08:48:22
19226 forum posts
749 photos
86 articles
Even I've done it, just make sure you have fresh, clean surfaces.
John Fielding13/06/2016 10:45:53
235 forum posts
15 photos
Yep-----well covered in the brazing books.
The important thing is to heat the cast iron well above the normal brazing temperature to burn off the graphite and then let it cool. Then wire brush vigorously and apply flux. This brings the surface to more like low carbon steel. Done this lots of times to repair broken castings etc.
Brian John14/06/2016 09:42:26
1487 forum posts
582 photos
I bought the silver solder and flux kit from Jaycar today but I had no luck with it. The solder just rolled itself into a ball.
I have reread John's post and he said to heat the cast iron well above brazing temperature to burn off the graphite. I did not do that ; I only got it hot then let it cool. I did not read his instructions properly. I will have to do this again but I will need the big burner to preheat the cast iron. That means doing it outside if the rain ever stops.
What sort of pickle should be used for cast iron after soldering ?
NOTE : I do not like wetting cast iron with anything. I remember the last time I washed a piece of cast iron with soapy water prior to painting and it went rusty in about 10 minutes. I was told to do this by PM Research when I inquired about painting cast iron. Now I never wash it with water ; I clean it with meths prior to painting it with a meths based etch primer.
Clive Hartland14/06/2016 11:31:08
2929 forum posts
41 photos
The fact that the solder just stayed as a ball/globule shows it is not hot enough, heat the item, and apply the solder and it should wet and run in straight away. This is a common fault when soldering, not getting it hot enough, the metal should be seen to glow and then offer the solder to the joint. But of course add flux on the solder rod.
Edited By Clive Hartland on 14/06/2016 11:31:38
speelwerk14/06/2016 11:52:11
464 forum posts
The few times I soldered cast iron I sandblasted the workpiece to clean it. Niko.
Michael Gilligan14/06/2016 18:38:23
23121 forum posts
1360 photos
Brian,
Forgive me for this digression, but your thread seems the most likely place for people to find this information, if they need it in the future.
Tidying-up my small-but-costly collection of Silver Solders, I found a stowaway ... A small coil of Thesscal "A", purchased years ago from K. R. Whiston [UK readers of a certain age will remember his 'Cat'].
Importantly, the little leaflet was also there, albeit barely legible.
What follows is a transcript:
Thesscal "A" Hard Aluminium Solder
Approved for use in aircraft
Melting Range 420--450 degrees C
All parts to be soldered must be mechanically clean.
For, Aluminium and its alloys, copper and brass, do not pre-flux the parts, but when making joints to steel a thin layer of paste flux on the steel surface will prevent oxidisation.
Prepared parts held in position should be brought up to temperature EVENLY with a suitable torch. Heat the solder and dip in flux, apply flux on the end of solder to joint area (not directly in flame). When flux flows temperature will be about 400 degrees C. A little more heat and Thesscal "A" will flow and complete the joint. Allow contact with the joint to melt the solder rather than heat from the flame. After prolonged exposure to a torch flame the flux will tend to dry up and this prevents the solder "Taking".
When joining Aluminium to Stainless Steel it is necessary to apply a thin layer of Silver Solder to the Stainless Steel first, Aluminium Solder adheres to this successfully.
Thesscal "A" joints should NOT be Anodised.
K. R. WHISTON, NEW MILLS, Stockport
Unfortunately, I must have already used-up the small packet of flux already.
Edited By Michael Gilligan on 14/06/2016 18:42:55
Brian John15/06/2016 02:06:09
1487 forum posts
582 photos
Is it still possible to buy aluminium solder/flux ?
Michael Gilligan15/06/2016 08:06:34
23121 forum posts
1360 photos
For info.
I have just found this review of Thesscal "A" by Flight, in 1955
Ian S C15/06/2016 10:31:56
7468 forum posts
230 photos
MichaelG, a bit OT, but very interesting, that sort of thing could be very handy if you stuff up or get a dud aluminium casting, I vaguely remember something like that, I think it was in the form of a bar, not unlike plumbers solder sticks. Ian S C
Speedy Builder515/06/2016 11:08:19
2878 forum posts
248 photos
K.R.Whiston New Mills, Stockport. What a marvellous company that was. Whatever happened to them?
BobH
Michael Gilligan15/06/2016 11:13:38
23121 forum posts
1360 photos
Posted by Speedy Builder5 on 15/06/2016 11:08:19:
BobH
Regrettably, the place is now a Plumbers Merchant
We moved to the area in 1988, and Ken Whiston retired shortly thereafter crying 2
... I don't think it was cause & effect but you never can tell.
Roderick Jenkins15/06/2016 11:38:49
2376 forum posts
800 photos
Posted by Ian S C on 15/06/2016 10:31:56:
been there, done that frown
This stuff seems to be a more modern version. I did little experimantation, reported here
Cheers,
Rod
mechman4815/06/2016 12:26:07
2947 forum posts
468 photos
Posted by Roderick Jenkins on 15/06/2016 11:38:49:
Cheers,
Rod
Rod,
Check your pc; clicked on the link above... my AV came up with ' antivirus prevented a harmful file downloading'... ?
George.
Roderick Jenkins15/06/2016 13:50:00
2376 forum posts
800 photos
Hi George,
AVG hasn't thrown up any problems on my machine. I'm don't understand why you would think that links to external websites via this website would be an issue with my PC frown . It seems more likely that your PC is unhappy with something on the target website. I don't get any warnings accessing the links from my Android tablet either.
Cheers,
Rod
Keith Hale15/06/2016 15:26:25
334 forum posts
Silver soldering of cast iron is sraightforward once the surfaces are clean and free of carbon/graphite. Silver solder will not wet onto carbon. The best jigs are carbon.
Get rid of the surface carbon by using the oxidizing part of the flame. That's the bit outside the blue zone of your flame. Heat to red and hold for a couple om minutes.
Allow to cool naturally in air and then clean with a stiff wire brush. Apply a long life flux eg HT5. Reheat. When the flux melts and flows apply the alloy.
Soldering aluminium is also straightforward. Any soft solder can be used, but,as above,. success depends on getting the surfaces lean. Proprietary fluxes are readily available. Your alloy selection will be based on price (?), colour match (?) melting range (?)
For more info see "Best Brazing Practice" and "FAQ" here. **LINK**
Keith
Neil Wyatt15/06/2016 15:35:00
19226 forum posts
749 photos
86 articles
I found Alutite quite easy to use and it doesn't require a flux, just gentle stirring & scratching with a steel wire.
60/40 solder will take on aluminium, apply oil over the area to be soldered and again use a steel wire or even a screwdriver to scratch the area.
Speedy Builder515/06/2016 16:26:26
2878 forum posts
248 photos
Would SIF BRONZE be as good or stronger than using silver solder, and would the same techniques apply - Ie heat up and scratch off the carbon before brazing?
BobH
