Member postings for speelwerk
Here is a list of all the postings speelwerk has made in our forums. Click on a thread name to jump to the thread.
Thread: Achieving a long-term quality finish on brass?
24/08/2023 23:05:41
This **LINK**keeps brass shiny for a long time. Niko.
Thread: 12 x 2 lead screw
18/08/2023 12:23:52
If you search in Germany you can find a few: **LINK** or https://www.walzkraft.de/produkte/trapezgewindespindel.
Niko.
Thread: M3.5 thread with 1mm pitch, very non standard
13/07/2023 22:53:14
Perhaps possible to find a wood screw with similar thread and use that as tap. Niko.
Thread: Balancing Bench Grinder Wheels
10/07/2023 20:25:32
The grinding wheels on these cheaper bench grinders do not usually have a very close fit on the arbor. You can possibly improve a bit on the vibration by shifting the stone on its arbor and trying to find a sweet spot. Niko.
Edited By speelwerk on 10/07/2023 20:34:45
Thread: Groove/cutoff tools wants to dig in too much
21/06/2023 21:21:16
Being a Myford from (I guess) somewhere the 1950's, is there perhaps too much play in the headstock bearings because of wear. Niko.
Thread: Titanic submersible
21/06/2023 15:06:59
Sorry for the persons on board but I do not grasp the fascination people have with the Titanic. Niko.
Thread: Help Identify this Myford 7 lathe
24/05/2023 12:16:56
Looks fine but for safety do fit a countershaft belt guard. Niko.
Thread: A Leeuwenhoek microscope project
14/05/2023 09:56:11
Here a description of an original one in the Boerhave museum the Leiden, sadly only in Dutch, **LINK** Niko.
Thread: Myford Lathes
29/04/2023 18:56:37
This Dutch dealer has a set of imperial Myford collets for sale, Niko. **LINK**
Thread: What are these clips called?
20/03/2023 16:14:47
"crutch horseshoe clip" or height adjustment clip gives result. Niko.
Thread: ML7 - Zeroing the Topslide?
14/03/2023 11:31:05
If the steps are small the easiest way I find is setting a DTI against the saddle. Niko.
Thread: platform escapement repair
02/03/2023 17:28:35
Perhaps this might be helpful, Niko.
Thread: Someone else has a mystery object
15/01/2023 21:29:09
Perhaps for making thread gauge blades. Niko.
Thread: Myford Metric Lathe Leadscrew
30/12/2022 16:19:31
Of course you are right Rod, but raised metric I was learned to use a 127 change wheel, its how I still do it. Niko.
30/12/2022 14:56:52
Myford-metric or name it imperial-metric is accurate enough for model enginering but it is not metric. Niko.
Thread: Rust on New Lathe
10/11/2022 11:36:21
Posted by John McCulla on 10/11/2022 10:10:27:
Would it be fair to say then that the lathe should be fine going forward? In my head I have it that once metal has started to rust, it is more prone to it in the future. Is that true or am I imagining this? I think I'm going to struggle to get a replacement lathe from Warco, but I'll push for it if I feel it's merited. Obviously it would be simpler for everyone involved if I could keep this lathe.
I would not except it, you have paid for a new lathe with no damage and this one has damage. They should either take this one back and replace it with a new one in pristine condition or you should get your money back, no ifs and buts. Niko.
Thread: Mechanical Mantel Clock
09/10/2022 10:26:50
Please remind that clocks are for the most a very poor investment. Niko
Thread: Very small holes
30/07/2022 18:16:18
Try drilling 1.3mm, open it up with a 1.4mm drill and again with a 1.5mm drill. Niko.
Thread: Buying from the EU
21/07/2022 10:13:54
Posted by pgk pgk on 21/07/2022 09:35:58:
I thought books (and charts are just large flat reference books) were vat free UK. and not subject to any other customs charges from the EU.
Of course DHL may decide to make a charge for declaring they are free of tax.....
pgk
When you buy from a EU country it is not the EU that will charge you. It is the country to which the goods are exported (UK) that will charge customs duties.
Thread: Dividing head attachment
06/07/2022 21:19:16
You will need a vertical slide, fixed or swiveling. Niko.
