Anthony Knights | 21/02/2016 11:27:53 |
681 forum posts 260 photos | I have obtained drawings for a low temperature stirling engine, which specifies graphite to be use for certain bushes and bearings. Would carbon motor brushes be a likely source of material or is there a plastic which could be used as an alternative ? If none of the above, where could I obtain suitable pieces of graphite? |
Russell Eberhardt | 21/02/2016 11:51:18 |
![]() 2785 forum posts 87 photos | Be careful if using motor brushes. Many of them incorporate copper powder to improve the conductivity. You could try **LINK** for or http://www.olmec.co.uk/graphite_blocks.htm graphite rod. Russell. Edited By Russell Eberhardt on 21/02/2016 12:02:19 |
ega | 21/02/2016 12:09:08 |
2805 forum posts 219 photos | Anthony Knights: You could consider Nylatron, graphite impregnated nylon available from eg Direct Plastics. |
JasonB | 21/02/2016 13:09:01 |
![]() 25215 forum posts 3105 photos 1 articles | Noggin End sell graphite in small amounts |
Roderick Jenkins | 21/02/2016 13:10:14 |
![]() 2376 forum posts 800 photos | Noggin End stock graphite **LINK** Rod |
Chris Evans 6 | 21/02/2016 16:51:05 |
![]() 2156 forum posts | Check out the EDM (spark erosion) suppliers for graphite. Where are you based ? a few suppliers here in the Midlands. |
mgnbuk | 21/02/2016 16:57:17 |
1394 forum posts 103 photos | Does it specify a grade of graphite on the drawing ? If you post the block dimensions required & any grade info I'll see if I can find a suitable offcut at work (graphite machining specialists - many tonnes of various different grades on site !). Nigel B. |
Michael Gilligan | 21/02/2016 17:08:18 |
![]() 23121 forum posts 1360 photos | Posted by Nigel B on 21/02/2016 16:57:17:
(graphite machining specialists - many tonnes of various different grades on site !). . Nigel, You could end-up as everyone's best friend !! Seriously: It might be worth striking a deal with your employer. MichaelG. |
Ajohnw | 21/02/2016 17:40:13 |
3631 forum posts 160 photos | Looking at a commercial LTD it seems to use a grade that will more or less take a polish. I'd guess that means very dense and very fine grained but there is little information about. It would be logical for Noggin End to stock the correct on but he mentions other uses for it. It's about on ebay in rod form as well but no info on grade. John - |
jason udall | 21/02/2016 17:48:21 |
2032 forum posts 41 photos | If stuck ( or don't have any better source). Artists pure graphite pencils.. Ihave used these with some success. You can even buy them in various grades. My fav for this purpose are the hex section ones about 13 mm acros flats..these are "pure" graphite so no grade number |
Anthony Knights | 21/02/2016 17:52:21 |
681 forum posts 260 photos | Thank you gentlemen. As usual, prompt and useful advice. No grade specified, but there are 3 parts to make which would probably only need 25mm of 10mm rod, which was why I asked about motor brushes. Noggin End looks good so I'll be giving them a try. Edited By Anthony Knights on 21/02/2016 17:53:01 |
mgnbuk | 21/02/2016 17:59:08 |
1394 forum posts 103 photos | Seriously: It might be worth striking a deal with your employer I would clear anything with the boss first - not worth risking the job for a bit of graphite ! In the past he has been amenable to requests for small bits / offcuts, but larger amounts of more expensive grades would most likely be chargeable. In the past also it has not been worthwhile commercially to raise invoices etc. for very small orders, but he has recently installed a credit card machine specifically to cater for small online orders of "standard" machined graphite parts like studs, nuts & bolts, so supply of smaller quanties of "raw material" should also be possible now. As above, let me have a bit more info & I'll see what I can do. Nigel B. |
martin perman | 21/02/2016 19:10:29 |
![]() 2095 forum posts 75 photos | I managed to pick up graphite rod from large Arc Lights at a car boot sale a while back.
Martin P |
Chris Evans 6 | 21/02/2016 19:20:56 |
![]() 2156 forum posts | When I was running EDM machines here in the Midlands I bought off two companies. Erodex and Graphite Technologies. There are other suppliers but these where local to work. |
MW | 21/02/2016 20:24:53 |
![]() 2052 forum posts 56 photos | Posted by ega on 21/02/2016 12:09:08:
Anthony Knights: You could consider Nylatron, graphite impregnated nylon available from eg Direct Plastics. I would also vouch for this, very durable Michael W |
Hopper | 22/02/2016 05:32:29 |
![]() 7881 forum posts 397 photos | www.graphitestore.com will have everything you need. Also, graphite rods sold on eBay for use by jewellers stirring pots of melted gold or silver etc. |
Ian S C | 22/02/2016 09:17:49 |
![]() 7468 forum posts 230 photos | I have some graphite impregnated PTFE/ Teflon, I use it for the bushes on displacer rods in hot air engines. One design of LTD that I'v seen uses pointed ends on the crankshaft bearing on blocks of graphite, I think the suggestion was to use motor brushes for this motor. Are you going to use a diaphragm, or a piston, if the latter a bit of graphite for the piston would be good, and a glass cylinder, best cylinder a glass medical syringe. Ian S C |
Circlip | 22/02/2016 09:29:08 |
1723 forum posts | "Be careful if using motor brushes. Many of them incorporate copper powder to improve the conductivity." So how will this affect operation in this application? Regards Ian. |
MW | 22/02/2016 10:06:09 |
![]() 2052 forum posts 56 photos | Posted by Circlip on 22/02/2016 09:29:08:
"Be careful if using motor brushes. Many of them incorporate copper powder to improve the conductivity." So how will this affect operation in this application? Regards Ian. Well, if i might hazard a guess, best case scenario it's for a push fit bushing which sits as dead as a door nail, not harming or upsetting anything or anyone else around it. Now worst case scenario it's for a moving part like a piston that might, on the worst of all the worst days becomes a conduit for electric shock? Other than that, it might just be a handy to know piece of info, i ne'er knew that before now, i thought a carbon brush meant exactly that. Michael W Edited By Michael Walters on 22/02/2016 10:08:53 |
roy entwistle | 22/02/2016 10:40:04 |
1716 forum posts | Michael W Seeing that both carbon and copper are conductors How would a moving part make any difference How would there be any chance of electric shock ? |
