Steady rest - metal or roller bearings ?
capnahab08/12/2015 17:47:05
194 forum posts
17 photos
I am renovating the pictured steady rest. What do people think about the relative merits of metal tips vs roller bearings , - if the latter where to get them ?.image.jpeg
Thor 🇳🇴08/12/2015 17:58:44
1766 forum posts
46 photos
When I made a larger capacity steady rest for my HBM 290 lathe I used small roller bearings. The rest can also use the brass fingers that came with the stock fixed steady.
Thor
Roger Williams 208/12/2015 18:20:55
368 forum posts
7 photos
Capnahab, looks very much like a DSG steady you have there !. I've heard it said that roller bearing ones are more susceptible to chip ingress than your type.
Raymond Anderson08/12/2015 18:35:42
785 forum posts
152 photos
That looks very similar [but not exactly] like the one for my DSG 17t. The finger pads on my one are phosphor bronze [ I think ] certainly not brass. I prefer the solid type rather than the roller type especially if cutting very close to the fingers. Rollers are fine if they are kept away from the swarf. If im using the roller type on me other lathe then I always put a piece of card between the rollers and the cutting tool, so no swarf gets beside the rollers.
Raymond.
Gordon W09/12/2015 09:49:11
2011 forum posts
I've just made a large dia. steady, used roller bearings (from Arc) , cheap enough not to worry to much about swarf. This for large dia. pipe and will be light cuts. It is my impression that solid fingers, clamped tight, are best for shaft turning and good finish, but you need a good finish first before using the solid fingers.
Chris Evans 609/12/2015 10:09:02
2156 forum posts
If you want to use roller bearings try Simply Bearings the web page is very good. You could use 2RS rubber shielded bearings to stop swarf ingress. Me I am happy with bronze pads I only use a steady a couple of times a year.
Ady109/12/2015 10:31:50
6137 forum posts
893 photos
I've been thinking about making a rest with rollers for a while but sealed bearings seem a bit bulky for the job
Will probbly try PB rollers on a steel shaft to start with
Emgee09/12/2015 13:09:33
2610 forum posts
312 photos
Hi Chris
I believe the ingress that Roger referred to was the ingress of swarf between the bearing OD and the rotating work.
To ensure no marking on the work I clamp and turn a nylon collar to fit the work for the hardened steady fingers to run on. The clamping Jubilee clip has been removed in the picture below.
Emgee
Edited By Emgee on 09/12/2015 13:13:11
Roger Williams 209/12/2015 13:37:24
368 forum posts
7 photos
Emgee, your right, that's what I should have said !. Perhaps DSG thought the same by not fitting the steady with roller bearings.
thaiguzzi13/12/2015 08:45:56
704 forum posts
131 photos
If you want to go the roller bearing route, have a look at a V8 (American) car shop and their stock of hydraulic cam followers. Cheap as chips too. Bearing and shaft can all be used as an all in one item. Personally i like bronze fingers, but both have their merits.
capnahab13/12/2015 09:28:47
194 forum posts
17 photos
Thanks Thaiguzzi, have you got a link please ?.
thaiguzzi19/12/2015 06:02:35
704 forum posts
131 photos
Sorry, no. Google a V8 car engine image to get the idea or "hydraulic cam followers". Plenty of 'Mercan car shops about, and engine internals are generally ridiculously cheap. You''d need 3.
Tim Stevens19/12/2015 14:22:28
1779 forum posts
If you are in the UK and seeking hydraulic roller followers, remember the Rover (ex Buick) V8 that found its way into all sorts of vehicles including LandRovers.
Cheers, Tim
mark costello 119/12/2015 14:31:34
800 forum posts
16 photos
I have made steady rest pads from Nylon. Made as wide and as long as possible for more bearing area.
Ajohnw19/12/2015 14:52:24
3631 forum posts
160 photos
You can always add sealed ball bearings. They don't need to be big ones, they will only be taking side loads. I keep telling myself to get round to doing it to my boxford steady every time I use it especially on aluminium. Often it's just a case of drilling and reaming fixing holes in the fingers and making the "studs" to support them. The bearing size is set by where the fixing holes need to be in order to make the set up strong. I have used a steady on a very large lathe where this had been done with much smaller bearings than I would be inclined to use. The finger ends were well tapered to allow low diameters to be gripped. As small as they were the bearings still increased the minimum size that could be gripped.
Some people modify the fingers so that they can take various tips - some plastics are favourite. I am not so keen on that method as it wont be as rigid as bearings.
RJW19/12/2015 15:02:09
343 forum posts
36 photos
Standard flat bottom lifters are relatively cheap as chips, but Roller cam followers used in American V8 and other engines are 'generally' an aftermarket racing or high performance road application, you may be able to buy followers individually, but I suspect they won't be cheap, they cost a small fortune during my F5000 Chev and Ford big block engine building days, the main producers being specialist companies such as Crane Cam's,
Rover V8's in standard form use flat bottom cam followers, roller cam follower and roller rocker kits are produced for them, but again, they're an aftermarket product and likely to be in fairly expensive engine sets rather than individual items.
John Stevenson19/12/2015 21:17:38
5068 forum posts
Quite common nowadays, even the Ford Serria 1.8 CVH has them fitted.
Plenty in the scrapyards or even new they are only four and a half quid a pop.
Ian S C20/12/2015 11:39:19
7468 forum posts
230 photos
I,v got one roller finger from (I think) a vertical lathe ex NZ Railway workshop Addington Christchurch, I use it in the tool post to push things straight.
Ian S C
capnahab26/12/2015 14:43:40
194 forum posts
17 photos
I am keeping the metal fingers as they are hardly used. Somewhere between Middlesborough Tech and me the holding plate for the steady rest has dissappeared. Its the same as the one for the tailstock. I got a quote from the manufacturer for one and needless to say it was in the same ballpark as the cost of the lathe. In the same town as the manufacturer found a brilliant Foundry (no association) who have made me two castings which I now need to machine. The tailstock plate is on the left, castings on the right. About a third the price.
Michael Gilligan03/01/2016 10:37:47
23121 forum posts
1360 photos
I have just found this interesting design for the WW style of Watchmaker's Lathe.
MOWRER
He is offering printed parts, in "Bronze infused Stainless Steel"
Edited By Michael Gilligan on 03/01/2016 10:41:48
