Here is a list of all the postings capnahab has made in our forums. Click on a thread name to jump to the thread.
Thread: Crawford Collets |
30/10/2022 09:34:20 |
Many thanks DC31k. That ebay link look just the ticket. I would need a D1-8 backplate presumably. Does anyone know how the collet chuck mounts to the backplate, - looks very much like it is a threaded mount. |
29/10/2022 20:15:33 |
Hi Jason theres a link to the holder in my previous post. I have asked them for more info but Have just realised its a Burnerd (or the say it is) holder. I chose it becuase its the only D1-8 I could find. I will keep hunting for someone selling a D1-8 collet chuck and collets. |
29/10/2022 19:59:56 |
Perhaps I have misled you Michael, - all I want is collets to fit the chuck and the chuck to fit the lathe D1-8 Camlock. I have given up trying to replace things exactly as was. This is a chuck that would seem to fit the lathe. I have emailed them to ask if they have a serial number or collets to suit. How I get the 14" 4 jaw thast on there is a different matter. Whilst all of the catalogies mention a vast range of old British lathes (Herbert, CVA etc) they dont mention DSG.
29/10/2022 18:11:56 |
The lathe resided in Middlesborough Technical COllege for its whole life, and I was lucky to get it (by way of a dealer) from there. I am not too fussed about the grip range of the collets but obviously they need to fit the chuck. |
29/10/2022 17:05:04 |
I continue to restor a DSG 17T tool room lathe. See figure. It was ordered with a Crawford `collet chuck and 29 collets. The Camlock on the lathe is D1-8. I have found on ebay a D1-8 Crawford Collet chuck. Can anyone tell me what size or type of Crawford Collets I need please.
Thread: gears for hand winder |
17/09/2022 12:12:26 |
That F1B is amazing. The nose mechanism is a masterpiece of miniature engineering. |
17/09/2022 10:59:45 |
Thanks Ramon, that is the best book about building planes. Still very relevant. I will message thank you very kind. Emgee you are right, a bit like a modified hand drill though they are for outdoor free flight where the ‘motor’ is much thicker braided rubber. This is for the much more delicate indoor. Here’s a commercial one - $395. John - need the torque feedback, - so not if you want to know how tight your rubber is. Cheers Jason and Noel. I have found exactly what I need on beltingonline. |
17/09/2022 09:07:31 |
I want to make a 10:1 winder for rubber powered model planes. The recommended gears are 12,24, 48 and 60 teeth. I want it to last (even though it could be overkill am happy w EN8 gears). What would be the best gear material and where to buy ?. I don't want to make them. |
Thread: drilling tool steel |
02/09/2022 21:33:52 |
cheers old school. |
01/09/2022 23:21:31 |
I wonder if it’s piano wire .. |
01/09/2022 22:18:47 |
Its a cross hole and a brand new dormer drill wouldnt touch it so i think it will need annealing. |
01/09/2022 21:40:24 |
I need to drill a 40 thousandths hole in a piece of 1/16 piece of silver steel. The hole dimension isn't critical. Presumably I need to anneal it but any pointers to colour and length of time and treatment afterwards greatly received. |
Thread: Lathe light |
20/09/2020 08:05:30 |
Good tips thanks. Points taken about 240 volt conversion and safety issues. The bulb fitting is bayonet (which I could easily change) so I have with this , looks like it will be a while coming from the east. |
19/09/2020 22:30:36 |
I am restoring a DSG lathe. I thought the light had long since been disconnected. After blowing very fuse in the machine ( pump wiring contacting chip tray .. 415v) I had to replace them all and found that the light had 36 volts so I have painted it. I now need a 36 volt bayonet ( Standard B22 I think) bulb, preferably bright and led. Failing that converting to led within the shade. I want o keep the original light as I am hoping to keep the lathe as original as poss. Any recommendations where I can get a bulb? Edited By capnahab on 19/09/2020 22:31:35 |
Thread: insert identification |
06/05/2019 16:48:41 |
No box. No they are brand new and it's just my rubbish photography. Many thanks, yes they look very like the ISCAR catalogue. Related tool comes up with a range of tools but none for 3mm. Will keep searching. |
06/05/2019 16:08:38 |
These inserts were sold by ebay chap as Iscar. I am looking for a holder. They are 3mm wide and have absolutely no markings. They are double ended and one end is upside down wrt the other. I have spent a lot of time with Google to no avail. Can anyone identify them?
Edited By capnahab on 06/05/2019 16:09:33 |
Thread: Anyone recognise this optical magnifier |
10/02/2019 12:00:14 |
It is indeed a pocket microscope, the bevelled end for letting light in is the giveaway.
Thread: Siezed Drill Chuck in a Tailstock |
10/01/2019 15:01:44 |
or you could make some.
Edited By capnahab on 10/01/2019 15:02:11 |
Thread: Forum Video Size |
27/12/2018 11:09:18 |
Looks a great refuge Ron. If you can ignore the snarky comments This Old Tony seems to be doing a series on the Minilathe. The second one on bearings is good. . |
Thread: model aero engine plans ?, where. |
24/12/2018 21:16:07 |
Good write up here of the Gordon nano. I am after Nexus plan PE40 for it. (yes I have heard all the warnings ). Its a 0.1cc and difficult to get to run. http://modelenginenews.org/nano/index.html |
