Is it possible to convert a 1968-71 model Myford Super 7 to metric
Tom Davies 114/09/2015 11:24:49
5 forum posts
Hi
I have 2 early teenage grandchildren who are showing an interest in engineering and in particular using my myford. I am a ft and inches person, and when I talk in imperial they look at me as if I am mad.
The question is- Is it possible to convert my Super 7 fitted with a gearbox to permanent metric measurements. If so what do I need in addition to the new dials. I hope I have explained this properly.
I already have a metric wheel thread cutting set for the gearbox.
Thanks
Tom
Rex Hanman14/09/2015 11:53:18
121 forum posts
Back in the 1970's when this country pretended to turn metric the school workshop where I taught metalwork had 4 Boxford lathes and 2 Colchesters, all were of course imperial. To promote metric teaching I was provided with metric "conversion" dials for each lathe. This was fine for small increments but as soon as the dial turned greater than a full revolution things became totally confusing.
After a chorus of complaints across Hampshire we were eventually supplied with new metric feedscrews, nuts and dials. They didn't provide new leadscrews so metric screwcutting wasn't possible.
This is really the only way to convert an imperial lathe to metric and I suspect it might be quite pricey to do now.
It's some time since I used a Myford, but if I recall correctly, some have a dial at the end of the leadscrew. In your case it would be hard to convert this without changing the leadscrew too.
There must be examples of people converting Myfords so maybe there is a conversion kit available? Others may know more than I do.
Bob Brown 114/09/2015 12:05:27
1022 forum posts
127 photos
Been asked before see **LINK**
The parts to convert are or seem to be available from Myford Ltd but could prove expensive, may be easier to teach them feet and inches only cost is time.
Personal the vital bit of kit in my workshop is a calculator as my machines are metric and the locomotive builds are imperial so if it says 1.25" I simply convert to metric 31.75mm in this case.
Bob
Edited By Bob Brown 1 on 14/09/2015 12:09:34
daveb14/09/2015 12:07:15
631 forum posts
14 photos
Metric Super7s came with metric cross and topslide screws and dials, the leadscrew and gearbox remained Imperial, the metric conversion set being used to cut metric threads (clasp nuts to be kept engaged). This is why you need to be able to reverse your lathe. Probably cheaper to buy the young ones a metric mini lathe.
Martin Kyte14/09/2015 12:17:29
3445 forum posts
62 photos
You may like to have a chat with Myfords (or eMail them) regarding a new lamps for old refurbishment.
The last show I was at, they said that many people trade in their old Myford for a reconditioned one. They may be willing to go to a metric rather than like for like.
If you are going to replace the leadscrew, leadscrew handwheel, cross slide screw and nut + micrometer dial, topslide screw and nut + mocrometer dial, you are already in for some reasonably serious dosh.
If you change the leadscrew presumably you are going to mess up all your gearbox ratio's too which will need to be addressed.
regards Martin
Martin Kyte14/09/2015 12:21:25
3445 forum posts
62 photos
. . . . or you could just fit DRO's and ignore what the lathe micrometers say.
Martin
John Haine14/09/2015 12:26:41
5563 forum posts
322 photos
I am fairly certain that Myford Ltd. supply metric feedscrews and nuts as well as new dials, and fitting is a doddle. Look at http://www.myford.co.uk/acatalog/Myford_Super_7_Carriage_Assembly.html to see part numbers and also on the site there is a history page that may help to check exactly what parts you need for your model. Or give them a ring. They are quite pricey, so an alternative would be to make your own as trapezoidal feed screw stock and nuts are available e.g. from Zapp Automation or Marchant Dyce. I've made a total of 3 cross slide feedscrews in my cnc conversion, the last one being a ballscrew. (I don't bother with a topslide except for tool setting.)
Alternatively you could keep the imperial screws and fit a cheap DRO system based on capacitive scales, for example from Allandale Electronics.
As for the main leadscrew, as someone said even on the metric version this stayed at 8 tpi which confused me at first. If you have a metric gearbox it won't be an issue for you, but anyway most fixing threads can be cut to an acceptable approximation using the standard imperial gears. I've kept the leadscrew for the moment but I don't care as the computer sorts out the conversion!
Tom Davies 114/09/2015 13:13:24
5 forum posts
Thanks all. I had not thought of the DRO route, will need to explore this option and at least as an interim option find out how to source and fit these.
Ralph H14/09/2015 13:28:18
74 forum posts
Almost 100% they will find DRO's easier to understand. It is the main way or working now in teaching colleges etc. and industry and all my peers that I learned with (not being much older really) found them much simpler and more useful than the dials. And my regards and best of luck to them and yourself for teaching them , there are not enough young people in this hobby!
Edited By Ralph H on 14/09/2015 13:29:15
Neil Wyatt14/09/2015 13:32:29
19226 forum posts
749 photos
86 articles
Rather than converting the lathe and making it more difficult to use yourself, perhaps buy a small metric lathe for learning on, which could, ultimately, be given to one of the youngsters when they get their own space?
INeil
Ralph H14/09/2015 13:42:36
74 forum posts
That's my plan, except they will learn the English way as well I have found it very useful at work to have a good understanding of both.
KWIL14/09/2015 13:53:05
3681 forum posts
70 photos
Before DROs became generally available I had a set of Top slide and Cross slide leadscrew and nuts for one of my Myford Super 7s.
Once DRO was fitted, that was it. Now full DRO and metric/imperial screwcutting is the order of the day.smiley
Ian S C14/09/2015 14:04:03
7468 forum posts
230 photos
It would be good I they learn imperial working as well as metric, in industry it is often required that new workers have to be taught about feet and inches because a lot of stuff out there is pre metric, and a small workshop may only have an imperial lathe that's been there for the last 60 years or more.
Ian S C
David Clark 114/09/2015 14:20:12
3357 forum posts
112 photos
10 articles
Teach them to use a calculator. More trouble than it is worth to convert lathe to metric.
Brian Wood14/09/2015 15:36:38
2742 forum posts
39 photos
Hello Tom,
I would also endorse the DRO route, it adds enormously to the versatility and I for one would never go back to dials and counting. You and the grandchildren can then both feel happy with just one switch to alter the 'language' as and when you feel like it. There are other advantages too, such as instant resetting on stepped work. and zeroing the tool on the chuck jaws or face, to then cut work to length from those references with complete confidence..
It may well be a cheaper alternative to rebuilding the lathe with new feed screws, nuts and calibrated collars, the youngsters might even take an active interest in fitting the system as well and learn something of how the lathe works while doing so..
Tom Davies 114/09/2015 17:44:57
5 forum posts
Hi Brian
I think your suggestions are the route I will take. You are probably right that they will take an interest in the fitting of the DRO system
Now all I need to do is source the best system to fit.
Any ideas?
Rgds
Tom
Alex Collins14/09/2015 18:27:11
147 forum posts
38 photos
Hi. I have done this.
Myford supply all the required parts though they are not low cost.
You need:
Top and Cross slide feed screws and Nuts.
2 X new Dials.
Tailstock Quill
You can cut Metric Threads on an Imperial Myford with the addition of a few Change Gears. There was a series on this in ME / MEW.
Alex
Brian Wood14/09/2015 18:36:16
2742 forum posts
39 photos
Hello Tom,
Far be it for me to tell you what is best, that is bound to be inflammatory! All I can do is describe my own system and why I chose it.
Having had some industrial exposure I saved hard and bought the expensive Newall Microsyn system; it is rugged, supremely accurate and traceable to national standards with performance test records for each scale and reader. I took the view that industrial users will chose kit that has a good reputation and I believe Newall are as good as you can buy.
Both the scales and readers are fully sealed and immune to coolant, swarf and other such contaminants, they will operate fully submerged if necessary.The guarantees were also impressive, lifetime on the scales. I don't know how that compares to other competing systems that are a lot cheaper.
So, as in all things, you get what you pay for---I have no regrets. I also equipped my mill from the same stable.
Edited By Brian Wood on 14/09/2015 18:36:34
Vic14/09/2015 18:57:07
3453 forum posts
23 photos
You can't beat magnetic encoders Brian but sadly most folks can't justify the cost.
I'd love that Spherosyn system on my mill! wink
