Here is a list of all the postings Tom Davies 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Is it possible to convert a 1968-71 model Myford Super 7 to metric |
14/09/2015 17:44:57 |
Hi Brian I think your suggestions are the route I will take. You are probably right that they will take an interest in the fitting of the DRO system Now all I need to do is source the best system to fit. Any ideas? Rgds Tom |
14/09/2015 13:13:24 |
Thanks all. I had not thought of the DRO route, will need to explore this option and at least as an interim option find out how to source and fit these. |
14/09/2015 11:24:49 |
Hi I have 2 early teenage grandchildren who are showing an interest in engineering and in particular using my myford. I am a ft and inches person, and when I talk in imperial they look at me as if I am mad. The question is- Is it possible to convert my Super 7 fitted with a gearbox to permanent metric measurements. If so what do I need in addition to the new dials. I hope I have explained this properly. I already have a metric wheel thread cutting set for the gearbox. Thanks Tom
Thread: Myford Super 7 Serial number |
14/09/2015 11:02:08 |
Thank you Neil Found it - Made between 1968 and 1971. Thanks again Regards Tom |
14/09/2015 10:40:56 |
Hi I have a Super 7 fitted with a gearbox which I have owned for about 20 years+ (I have lost the invoice). I had a reason to to determine which model I have and looked for the serial no (on the front lh side of the bed) there is nothing stamped on the bed in that area. I have looked all over the lathe and cannot find one anywhere. What pointers are available to tell me what version of the lathe I have. Thanks in advance Regards Tom |
