another mystery machine
ian j | 27/07/2015 20:44:38 |
![]() 337 forum posts 371 photos | Spotted this small machine at the Anson Engine Museum yesterday. Any idea's on what it was used for? |
Michael Gilligan | 27/07/2015 20:50:50 |
![]() 23121 forum posts 1360 photos | A wild guess ... It looks rather like a spring-making machine. MichaelG. |
Neil Wyatt | 27/07/2015 20:54:03 |
![]() 19226 forum posts 749 photos 86 articles | The Omnibombulator |
V8Eng | 27/07/2015 21:25:13 |
1826 forum posts 1 photos | Posted by ian j on 27/07/2015 20:44:38: Spotted this small machine at the Anson Engine Museum yesterday. Any idea's on what it was used for? Great place to visit. When I went last year the volunteers seemed very knowledgable, did they not know what it is?
IanT | 27/07/2015 23:02:13 |
2147 forum posts 222 photos | My Urfer curled once Neil and it's not something I wish to repeat, which is why I now keep my Rumption in the fridge! IanT |
Vic | 27/07/2015 23:59:40 |
3453 forum posts 23 photos | Posted by Michael Gilligan on 27/07/2015 20:50:50:
A wild guess ... It looks rather like a spring-making machine. MichaelG. That's what I thought. Need to see a few revolutions of it to be sure though. |
john carruthers | 28/07/2015 07:50:09 |
![]() 617 forum posts 180 photos | Now I know why spring was late this year. |
Mark P. | 28/07/2015 09:05:50 |
![]() 634 forum posts 9 photos | Oh come on Neil, everyone knows that it's a machine used in the manufacture of semi-automatic self oscillating flange pins. Mark P. |
NJH | 28/07/2015 09:12:08 |
![]() 2314 forum posts 139 photos | Hey Neil Have you been at the Blue Nun again? ! Norman |
mechman48 | 28/07/2015 19:15:37 |
![]() 2947 forum posts 468 photos | It's actually a throbblewangle that is used to squeeze the remaining biformucating juice from the remnants of the clockwork onion that is used to refill the jungle juice powered time display in the village square which always runs two drips slow... George |
Clive Hartland | 28/07/2015 20:18:10 |
![]() 2929 forum posts 41 photos | No, it's definatly an, 'Ockle Cockle maker' You pull the lever and it goes, 'Ockle Cockle, Ockle Cockle' Clive |
Lionel Titchener | 03/08/2015 20:18:15 |
26 forum posts 5 photos |
I wonder is it could be a small chain making machine? Just looking at the cams and levers.
Brian Oldford | 03/08/2015 22:08:20 |
![]() 686 forum posts 18 photos | It'll never work properly until the laughing shaft is connected to the giggling pin. |
Muzzer | 03/08/2015 22:50:20 |
![]() 2904 forum posts 448 photos | Looking like a spring maker or something similar that bends and forms. There are quite a few cam operated levers and no sign of any actual cutting (swarf), so doesn't look like a cam operated machine tool. This is the sharp end of a (helical) spring making machine - not a state of the art CNC type but still electrically programmed to some degree (a couple more in my album). In the above photo, you can see the wire coming in from the left and being bent by the 2 fingers that are at 45 degrees. There is only 1/2 a turn at this point, as the previous spring has just been cut off (you can't see the blade which is outside the picture). Setting all the angles and distances takes a fair bit of trial and error, so hardly in the "one minute exchange of dies" territory. The mystery gadget doesn't look easily reprogrammable, so probably intended for making large numbers of identical parts in the same way that a cam lathe's operation is "programmed" by the metal cams. It's probably for making something like the spring used in clothes pegs! The action seems to be happening in the area at the very bottom of the middle of the photo, whatever it is. Murray Edited By Muzzer on 03/08/2015 22:54:59 |
John McNamara | 04/08/2015 08:15:27 |
![]() 1377 forum posts 133 photos | I think Lionel may be on the right track A chain maker? or maybe curtain hooks? A few closer and at an angle photos would help work it out. Regards
HomeUse | 04/08/2015 08:20:48 |
![]() 168 forum posts 12 photos | I think the main bits are missing 🐸🐛🐜🐜🐌😜 |
