Member postings for Lionel Titchener
Here is a list of all the postings Lionel Titchener has made in our forums. Click on a thread name to jump to the thread.
Thread: Cost Effective CNC Tools
14/03/2016 13:33:14
Have a look here - I have just got a flyer with offers valid to June 2016
http://www.shop-apt.co.uk
Thread: Torque wrench testing
21/08/2015 22:06:03
I've got a Britool torque wrench same style 1970's vintage, lost the ball bearing many years ago, anyone know what size ball bearing?
I thought it may have been around 1/4"
Thread: Parting off brass
21/08/2015 19:47:53
Anyone mentioned if the tool is parting off above centre? That would also break off the final pip.
Could also the the reason for the tool deflecting and cutting an arc and not straight.
Thread: another mystery machine
03/08/2015 20:18:15
I wonder is it could be a small chain making machine?
Just looking at the cams and levers.
Thread: Stunning Displays at Science Museum
21/06/2015 22:46:44
There is a Science museum in Broad Street, Oxford.
Opposite Blackwell's bookshop, and the BodleanLibrary.
Thread: Tool suppliers in Oxford and Banbury ?
21/06/2015 22:42:28
Go out of Oxford on the A40 and take the A418 to Aylesbury then Aston Clinton to Dunstable.
Chronos Ltd. southfields Road, Dunstable.
I would guess about an hour, used to work in Aylesbury and could get their in about 25 minutes, that't about halfway to Dunstable.
Thread: Flypress
11/06/2015 20:08:02
Another posibility is homeworkshop.org.uk
Updated every evening.
Thread: Smart and brown model 'L' lathe- opinions, please?
17/05/2015 23:18:22
I had four of these all bought from Bracehand in Bigglewade, as reconditioned I think about £6000 each then.
At the price you mentioned, I'd buy it if only to have set up for a particular job when needed or as a spare when other machines are tooled up for other jobs.
One of mine have type 21 collets that go larger than the smaller collet machines, Used to buy collects from Crawford in Witney but they went some years ago.
Thread: Soba Tapping Attachment Help
17/05/2015 22:57:45
Mine all turn in the normal clockwise direction looking down the tap into the hole, like a drill.
I've not used mine on a left hand tap, but maybe the mechanism is adjustable to set it to run in reverse for left handed taps.
Not sure what make mine are, will have to check, one I think is an old archer tapping head.
Does yours let you pull the tap down so you can twist it to stay in that down position?
I think I may have the instruction card in the boxes for a couple of them will check tomorrow
16/05/2015 21:09:16
You might need more "throw" on the mecanism to get it to go into reverse.
I have varous tapping heads and the tap needs to feed out far enough to click into reverse, of you don't wind the handle up fast enough it can drop put of reverse and knock.
I do a lot of blind holes, so first pull the tap down and twist the collet to hold it down on the cam to lock it in the freewheel position, that way it does no bottom out and break the tap if you set the depth in that position, then when it freewheels and you wind the quill back up it goes into reverse on the tapping gearing in the head.
Thread: any idea what this is
16/05/2015 21:00:28
There was a company called Taylor that sold capstan tooling in the Birmingham area back in the 70's
Thread: What type of tip is this?
16/05/2015 18:28:24
Possibly proprietory.
Try Sandvik
16/05/2015 18:15:25
Could be for aluminium.
http://www.shop-apt.co.uk/carbide-inserts-for-milling-uni-tip/apkt-160408-alu-ak10-carbide-inserts-for-milling-ground-and-polished-for-aluminium.html
Thread: Wanted 6" of 7/8" Tubing
13/05/2015 10:27:36
PM sent to Brian Wood, have also ordered a length of brass from the company that Kwil suggested, have a couple of options now.
Thanks all.
12/05/2015 17:05:20
No idea where the smiley came from????
12/05/2015 17:04:43
Thanks Tim, have a few old handlebars around here, as you say a bit on the thick side.
Trying to find a bit of 7/8" x 20g tube, Have an old mop handle, but the wall is too thin, and outside diameter a bit of a loose fit.
The outside diameter is 7/8" (.875" ) and the lead screw is .750" With wall of .036" have a clearance of .053" so have .0265" clearance around the leadscrew.
Been searching to see if it matches a Reynolds size but have not found anything yet.
I would have thought Myfords bought an off the shelf standard size, as it looks like a length of tubing with no machining marks.
Edited By JasonB on 12/05/2015 19:06:26
12/05/2015 15:50:28
Saddle off the Myford, so hoping to get a piece of tube that can be cut to size and cleaned up with a bit of fine emery paper and made to fit.
Headstock is on so can spin the chuck, but cannot turn anything from the toolpost.
Looking at the old part the bore looks smooth, may be a weld mark so could be welded tubing, so I'm hoping that it was fabricated with off the shelf tubing.
12/05/2015 15:36:25
Hi,
I have almost finished putting the Apron back together on my Myford 254.
Where the lead screw goes through the apron there is a tube that it runs through that is a push fit on the apron housing.
It's 7/8" outside diameter, with a wall of .036"
It does not appear in the Myford parts list for the apron.
Has anyone got a piece of 7/8" DOM tube that has a good surface finish that can be used to make a new tube?
The old part has perforated and lets the oil out.
Thanks.
Thread: Myford 254 Apron Rebuild
01/03/2015 20:20:03
Posted by Les Jones 1 on 01/03/2015 10:26:42:
No 25.4mm = 1.000"
Les.
You are correct I was having a bad day.
It should have been 25.4 in original post not 24.4
Edited By Lionel Titchener on 01/03/2015 20:20:24
01/03/2015 10:17:56
Yes 25.4mm is .1000"
It was not a conversion, none of the dual measurement were done as a conversion, I just changed the vernier from imperial to metric to check measurements in both.
Sorry for confusion, if I implied it that way.
I thought maybe 25.4mm may have been used as outside diameter for a Module Gear, and 0.998" for a DP Gear.
John Stevenson put me right telling me to ignore the 0.998" and make it 1000"
No, I did not read your post as picking on me, been around enough forums not to worry what is said in posts.
Grateful for all your help.
Thanks,
Lionel
