Member postings for ian j
Here is a list of all the postings ian j has made in our forums. Click on a thread name to jump to the thread.
Thread: Kennedy Hexacut machine hacksaw
02/09/2023 09:16:27
p9010892.jpgp9010893.jpgI have a Kennedy model "90" hacksaw, which is much larger than the "60" (Hex bars are 21mm AF)
I've never managed to get the flat belt to run on the centre of the large pulley.
So seeing Graham's Poly belt conversion I decided to do the same to mine.
Been a larger machine the dimensions are different to Graham's.
Large pulley diam. 9.875" (251mm)
Small pulley diam. .96" (24.38mm)
Centre distance of pulleys 6.8125" ( 173mm)
Graham very kindly calculated the Poly belt length as 34" ( 864mm)
This was purchased from "Simply Bearings" Part No. 864PJ/340J-14Rib
As can be seen in the photo the belt now runs nicely on the centre of the large pulley and is far easier to put on than the old flat belt.
Thread: Nineteen year old magazine
14/07/2023 22:33:24
Same with my copy purchased today from my local news agents , only my free " Heritage Railway" magazine was November 1999 !
Ian
Edited By ian j on 14/07/2023 22:36:52
Thread: Sequential numbering on data plates
01/07/2023 08:20:57
Diane.
I've used these people in the past.
Modern Engraving Stoke On Trent
Thread: Rod's Hoglet
11/06/2023 20:06:00
Hi Graham.
I have this one in my favorites, not a youtube one but plenty of photo's and construction detail.
Down on The Farm Boy
Ian
Edited By ian j on 11/06/2023 20:07:35
Edited By ian j on 11/06/2023 20:12:45
06/06/2023 08:58:23
Thanks for that information Rod. I will give it a try. I've only used CamCalc once before for the JH V 4 cam shafts, will have to see if I made any notes.
I may be back !
Graham.
I also have built the JH Farm Boy (two). Another enjoyable build, be prepared for mountains of swarf. I used the minimag ignition system.
Ian
31/05/2023 21:42:56
Graham.
I had read the RCEXL data sheet regarding timing and then completely forgot it and followed Andrew Whale's youtube video!
I'm also running on unleaded petrol with a drop of two stroke oil.
Regarding the fuel tank; It's just a 75mm length of 50mm diam thick walled brass tube I had, with ends, filler hole and outlet soldered on ( if I was making it again I would make it longer and have the supporting struts spaced further apart as it is easy to catch the supports when starting with the drill) It's mounted so the fuel out is level with the carb fuel in (180mm from base on mine) The supporting struts are just 10mm x 25mm aluminum angled at the bottom by 5* so they leans out, with the "pockets" milled 2mm deep and then sprayed satin black, (similar to the rails the engine sits on.)
Now I know it runs I may try the JH 2 jet carb again as they took some time to make.
After all the discussion we had regarding the cam shaft I notice the right hand cylinder exhaust lifter hasn't the same amount of travel as the left hand cylinder. I may remake the cam shaft but don't fancy the Cox method again. So ROD do you have the parameters you used for CAMCALC please?
Graham did you sort out the one cylinder running cooler than the other?
I've enjoyed this build and the exchange of information from members with far more experience than me. I think 3 out 3 engines running is a good result.
What's next?
Ian
30/05/2023 23:12:44
Graham.
Thanks for the link for the carb. from Steve Webb.
The S2535 you bought was out of stock, but they had S2530 which is still 6mm bore, just the needle valve isn't at an angle.
Any way with it fitted the engine now starts and responds to the throttle, so I'm very happy.!
One thing I noticed when setting the ignition timing for 10* BTDC the hall sensor was at the quarter past position but I noticed on yours and others it was at the half past position the engine was difficult to start and run when I rotated the hall sensor to the half past position it was a big improvement. I now have it in that position and it reliably starts and runs.
Hoglet V twin
Edited By ian j on 30/05/2023 23:21:27
24/05/2023 18:05:53
That's brilliant Graham. Seems to respond well to the carb, Which one are you using?
08/05/2023 00:34:27
Well some progress today. After putting to one side for a couple of weeks, I revisited the Hoglet today and managed to get it to run (in a fashion) Using the JH 2 jet carb and Colemans camping stove fuel . It runs very hot and is impossible to restart until it cools down.
I tried to embed the youtube video but failed.
Hoglet V twin engine first run on youtube
Edited By JasonB on 08/05/2023 06:56:58
Thread: Myford super 7 tailstock thread
24/04/2023 18:49:20
Posted by David Haythornthwaite on 04/02/2023 11:38:54:
I have spent hours trying to upload a drawing of mine to my album - or simply to a forum post and cannot remember how to do it.
Are there instructions on the forum? Yes I know it has to be Jpeg which isn't the best, but I have converted from PDF to JPG and still cannot get it into my album.
Yes I know that I am getting old - but is there a pointer to instructions on how to do this?
Can anyone help?
Kind regards
David H
Hi David.
I've uploaded YOUR drawing for you here.
Ian
Edited By ian j on 24/04/2023 18:53:38
10/04/2023 13:03:58
Graham.
The way mine is, looking from the front (gears facing you)
39* position North facing, Left hand cylinder.
120* position South facing, Right hand cylinder.
I can get mine to fire but not run. I think it's the carb, I've tried the Jerry Howell one I made and one off a small RC aero engine.Tried with Coleman's camping stove fuel and normal unleaded with no success.
Ian
10/03/2023 22:58:16
Well done Rod, it looks and sounds fabulous, You must be very pleased with the end result.
I must revisit mine as I now have the ignition. To be honest I've been holding back to see how you got on.
I need to make a starting dog and Hall sensor attachment. I've made the Jerry Howell two jet carb. (made two as the
same carb is used on his V4 engine which I need to get back too as well!)
Ian
Edited By ian j on 10/03/2023 22:59:21
Thread: Abrafiles
08/03/2023 23:06:19
Just found these on Ebay
Abrafile clips
Ian
Edited By ian j on 08/03/2023 23:12:44
01/03/2023 15:35:16
Graham.
I followed your advice and gave them a call. The ignitions are in stock ( web site just not updated) Got one on the way and the fun trying to get the engine to run starts then !!
Thank You
Ian
28/02/2023 19:03:11
Hi Graham.
Can you just confirm the "Just Engines" web site that shows the V twin ignitions are available, because when I look it says they are out of stock.
Just Engines
Ian
29/01/2023 20:52:25
It's looking good Rod.
I finished mine some time ago, but having trouble sourcing the RCEXL V twin ignition, They are out of stock at "just engines". Plenty of the single hall sensor ones available but I can't find the two sensor type .
Just to add I secured the crank pins on mine using grub screws threw the the crank webs.
Edited By ian j on 29/01/2023 22:09:53
Thread: Another stepper motor powered rotary table
13/01/2023 16:37:35
Mike.
I like this setup so much I'm planning to build two for my 4" rotary tables both fitted with stepper motors and Steve Ward controllers. By studying your excellent photo's I think I get the general idea. I'm guessing you used a 2 : 1 ratio on the toothed pulleys? What size did you use ? MXL type ? number of teeth? Belt length?
Ian J
Edited By ian j on 13/01/2023 16:38:43
Edited By ian j on 13/01/2023 17:34:08
12/01/2023 21:27:18
Posted by Baldric on 12/01/2023 05:31:29:
https://www.automationshop.co.uk/sy57-back-cover-ip40.html
I have previously designed & printed my own using 4-pin XLR connectors, the two motors I have, both same NEMA size, have diffeent mounting holes, but the one linked to seems to cover that option.
Baldric
I've just tried to buy one from "https://www.automationshop.co.uk" but they have a minimum order of £100 !!
IanJ
10/01/2023 22:52:30
David.
When I measured the barrel with a digital caliper I measured 1,115" like you I thought it was a odd ball size but pot it down to me so rounded it up to 1.125", Just measured it again with digital micrometer and get 1.114". I suppose it's just has to be a nice clearance fit in the tailstock casting.
Ian
10/01/2023 20:04:09
Mike.
Looks very good. Did you 3D print the back cover or buy it? If you bought it could you point me in the direction of where from. I've found sites where you can down load the files to 3D print it, but as I don't have a printer that's not an option.
Ian J
