Aircraft General Discussion
This is where all the off topic discussion about aeroplanes should go
V8Eng13/10/2015 10:09:18
1826 forum posts
1 photos
Apparently BBC Breakfast had some items about the Vulcan this morning (Tuesday), Might be interesting, have to see if it is available on the I Player.
Ian S C29/10/2015 10:19:37
7468 forum posts
230 photos
The Vulcan may be grounded, but it appears that a Victor may be on its way to take it's place, there is also a Shackleton being restored. From what I'v heard it's a bit of a race to see which is first, although I think the Victor go air bourn on a fast taxi.
Ian S C
Paul Narramore29/10/2015 10:54:37
34 forum posts
6 photos
You will have to search for it but somewhere on YouTube is a video of a Victor taxiing at speed when it unfortunately began to lift off, much to the consternation of the pilot. I did land safely though, and just in time as it was going to run out of runway.
Cornish Jack29/10/2015 11:48:40
1228 forum posts
172 photos
"a Victor taxiing at speed when it unfortunately began to lift off" ... Must have been the later Mk, although even those were 'ground huggers'! One of the 'moments of interest' when we were on standby S&R in Cyprus was watching the Victor take-off with guesses as to how little runway would remain before lift-off. Probably the best looking of the V force, but better IN the air than getting there!
rgds
Bill
Neil Wyatt29/10/2015 12:52:53
19226 forum posts
749 photos
86 articles
It made a final flight around Robin Hood airport yesterday. About 20 minutes with a veteran at the controls.
Gordon A29/10/2015 15:50:06
157 forum posts
4 photos
I think this shows what the old girl was still capable of
https://youtu.be/7kuE9A8bOzQ
Gordon.
Paul Narramore30/10/2015 09:29:32
34 forum posts
6 photos
Re the Victor which accidentally took off, I found a second video yesterday with the actual pilot, a veteran Vulcan pilot. He explained that when he ordered his co-pilot to shut the throttles, the co-pilot simply froze. The pilot then had to let go of his controls and lean across to shut the throttles himself hence the brief take off.
Ian S C30/10/2015 12:13:36
7468 forum posts
230 photos
Howard Hughs had similar problems with the Hercules/Spruce Goosecheekywink
Ady130/10/2015 15:23:10
6137 forum posts
893 photos
Posted by Gordon A on 29/10/2015 15:50:06:
Gordon.
Gives ya goosey bumps
Geoff Theasby31/10/2015 08:47:11
615 forum posts
21 photos
I have a question. I know of the Doppler Effect, where the pitch of an approaching train horn or whistle rises, then falls as it passes and recedes. I have, however noticed that the whine of a jet aircraft, whether the Vulcan or the local police helicopter, appears to rise in pitch as it recedes. Any idea why this is?
Geoff
JA31/10/2015 09:57:04
1605 forum posts
83 photos
Posted by Geoff Theasby on 31/10/2015 08:47:11:
Geoff
Unlike a horn or whistle a jet engine is a complex device with each major component producing noise with a range of frequencies and amplitudes. In addition the "radiation" of these noises is not uniform around the engine. I would say that the rise in pitch as the engine recedes from the listener comes from the turbine.
The old Hawker Hunter had a distinctive drumming noise from the compressor. It was very obvious when the aircraft was flying straight at one.
JA
Neil Wyatt31/10/2015 16:55:38
19226 forum posts
749 photos
86 articles
I'm not someone who get particularly excited about airliners (at least modern ones) but I was up on Barr Beacon this morning and it was obviously smack under the final approach for Birmingham Airport in the lovely bright, still but hazy conditions. A great opportunity to flex the zoom and image stabilisation capabilities of my camera:
martin perman31/10/2015 20:25:01
2095 forum posts
75 photos
Having watched the Victor at Bruntingthorpe many times I cant see how it could "just lift off" as it leapt quite a distance off the ground, makes me wonder if they gave the stick a tug to much.
Martin P
Ian S C01/11/2015 09:55:14
7468 forum posts
230 photos
Martin, I did mention Howard Hughs and the Spruce Goose. I imagine it has happened with other aircraft.
Ian S C
Clive Hartland01/11/2015 10:34:03
2929 forum posts
41 photos
I always understood that there were 2 points about taking off, V1 where they could abort the take off and V2 where the speed then committed them to lift the plane as an abort was then a crash? The Victor was unladen and therefore light and the flight characteristics totally different,. Taxiing at a low speed just enough to show the public a moving aircraft. Luckily the Victor came to a stop before it hit the end of the runway and even then I think it went onto the grass.
Nick_G09/11/2015 22:48:04
1808 forum posts
744 photos
Not a short video but worth watching. So make yourself a cuppa first.
Nick
Paul Barrett10/11/2015 08:18:26
59 forum posts
16 photos
Posted by Clive Hartland on 01/11/2015 10:34:03:
V1 is the rejected take off max speed. It varies depending on weight, runway length and conditions etc but is a ground only speed. All other speeds are aerodynamic. Once over V1 you are committed to fly. Vr is the rotate speed and V2 is the minimum speed for climb on one engine (or 2 engines if you want to go up like a bat out of hell) (Best angle of climb) for obstacle clearance. Once reaching Aa (acceleration altitude) usually 1000 feet above aerodrome altitude you accelerate to Vfs (which on 2 engines you will probably be above) which is flap retraction speed.
Airliners are normally trimmed before take off for a V2 climb ready in case of a engine failure and re trimmed after take off when safely in the climb.
Clive Hartland10/11/2015 08:51:53
2929 forum posts
41 photos
Thanks for explaining that Paul, I have only ever heard of the V1 and Vr/V2. I understand there is a standard procedure for takeoff .
Speedy Builder510/11/2015 09:04:57
2878 forum posts
248 photos
As an apprentice in 1963 - 1968, I helped to build fuselage jigs and later helped fit the the Auxillary Air intake doors for the TSR2. Until a few years ago, I used sample cockpit glass as small surface plates. These were glass / silicone sandwiches about 1" thick.
BobH
David Clark 110/11/2015 09:29:43
3357 forum posts
112 photos
10 articles
I seem to remember a model of the TSR2. I think it was on a cornflake packet or similar. Lasted longer than the real one!
