Mick B1 | 08/02/2020 09:32:36 |
2444 forum posts 139 photos | Posted by Steviegtr on 07/02/2020 22:56:00:
Wouldn't it be awesome if we went back to imperial. Stuff the rest of the world. Rule BRITANNIA. Britannia rules the waves. Steve. I think you're forgetting the cost, in working ships and men, sunken ships and dead men. |
Spurry | 08/02/2020 09:40:40 |
227 forum posts 72 photos | Posted by Chris Evans 6 on 08/02/2020 09:19:11:
Post Brexit will we buy petrol by the gallon again ? Nudging £6 a gallon will make folk stop and think ! Yes that's a good one! One of the bigger cons I think, selling petrol by the litre. My most expensive, to date, was paying 147.90p/L = £6.72 per gallon. Doesn't seem that long ago it was 5 bob/shillings per gallon, but that's showing one's age... Pete |
martin perman | 08/02/2020 09:52:08 |
![]() 2095 forum posts 75 photos | Can somebody explain why we buy timber as inch x inch x metres.
Martin P |
JasonB | 08/02/2020 10:06:57 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by martin perman on 08/02/2020 09:52:08:
Martin P Have you actually measured that "4x2", I think you will find it is 47mm x 100mm not 51mm x 102mm Edited By JasonB on 08/02/2020 10:08:38 |
John Haine | 08/02/2020 10:07:29 |
5563 forum posts 322 photos | Please could we have a moratorium on the hoary old topic? |
JasonB | 08/02/2020 10:09:41 |
![]() 25215 forum posts 3105 photos 1 articles | Yes lets get back to the Collet in questing and whether it is worth trying to machine it out to 1/4". |
Russell Eberhardt | 08/02/2020 10:20:08 |
![]() 2785 forum posts 87 photos | Posted by JasonB on 08/02/2020 07:27:44:
Posted by Steviegtr on 07/02/2020 23:32:08:
pipe fittings are still in BSP.
Depends where you are getting them, most of the metric world works with "G" threads now Well, here in France, where the metric system was invented, all threaded pipe fittings for domestic use, including taps etc., are BSP but sold by the thread diameter in the nearest whole number of mm. Russell |
Eric Cox | 08/02/2020 10:49:17 |
![]() 557 forum posts 38 photos | "For what it's worth, in the mid 70s I was fortunate enough to be working as a ships draughtsman on the T22 frigate which became HMS Broadsword. This ship was all metric, and I was told that it was the first ship classified as "metric" to be designed and built by the MOD(N)" Even Richard Burton worked in Imperial as he was always asking for the conversion "Broadsword to Danny Boy" Edited By Eric Cox on 08/02/2020 11:00:29 |
Nick Wheeler | 08/02/2020 10:55:11 |
1227 forum posts 101 photos | Posted by Speedy Builder5 on 08/02/2020 07:20:59:
As my Dad used to say - Can you imagine a simple plate 1m x 1m, now put 1Kg load on that and slip your hand under one corner of it. No Can't imagine that. Now, take a simple plate 1ft x 1ft, place 1lb on the plate and do the same - yes, I could imagine that. But we move with the times. Yes, and no in that order. And it's for the same reason you and he were the other way round, it's what we are all used to. The human brain isn't programmed to work in any of the entirely arbitrary units in use, but is trained to use whatever is favoured in that situation.
As for reverting to Imperial, what would be the point? Even America uses metric, they just fudge it by overlaying older units for everyday use. |
larry phelan 1 | 08/02/2020 11:02:23 |
1346 forum posts 15 photos | Steviegtr, I think it,s many a day since Britannia ruled the waves, or have you not noticed ? Good while it lasted, but all good things come to an end. Move with the times. |
Bob Unitt 1 | 08/02/2020 11:09:59 |
![]() 323 forum posts 35 photos | What's next on the agenda, reverting to Pounds, shillings and pence ? Why go for half measures, bring back the Ell, Hogshead and Groat !!!
Andrew Tinsley | 08/02/2020 11:42:31 |
1817 forum posts 2 photos | I am never too sure why metric versus imperial gets so emotive. I work in both sets of units and have metric and imperial kit. I move between one and the other without barely noticing. Andrew. |
Brian H | 08/02/2020 11:56:04 |
![]() 2312 forum posts 112 photos | Plus one for Andrew Tinsley's comment. I usually work in Imperial because I model old engines that were made in Imperial measurements but if I were to model a continental engine then I would use metric measurements. What's the problem? Brian |
Mick Henshall | 08/02/2020 12:08:27 |
![]() 562 forum posts 34 photos | As I remember in the Queen's Navy "Scantlings" were used when measurements were considered, and thickness of steel plate was measured in pounds weight, eg a 12" x12" x1" thick weighed 40 lbs,1/2" thick 20lbs,1/8" plate weighed 5lbs and so on, I only use imperial and at my age will continue to do so Mick 🇫🇴 |
John Baron | 08/02/2020 12:16:47 |
![]() 520 forum posts 194 photos | Posted by Andrew Tinsley on 08/02/2020 11:42:31:
I am never too sure why metric versus imperial gets so emotive. I work in both sets of units and have metric and imperial kit. I move between one and the other without barely noticing. Andrew. +Another 1
S.D.L. | 08/02/2020 13:18:06 |
236 forum posts 37 photos | Posted by Brian H on 08/02/2020 11:56:04:
Plus one for Andrew Tinsley's comment. I usually work in Imperial because I model old engines that were made in Imperial measurements but if I were to model a continental engine then I would use metric measurements. What's the problem? Brian Even that is a simple choice of preference. model railways have been 4mm and 7mm to the foot for decades. nothing to stop some one modelling 10mm to the foot, convert to decimal inches and divide by 10. but do whatever suits you best steve
Gerard O'Toole | 08/02/2020 13:48:17 |
159 forum posts 13 photos | Posted by Steviegtr on 07/02/2020 22:56:00:
Wouldn't it be awesome if we went back to imperial. Stuff the rest of the world. Rule BRITANNIA. Britannia rules the waves. Steve. I am always open to be converted. Can you tell me what advantages using the Imperial measurement system would afford me?
martin perman | 08/02/2020 13:59:27 |
![]() 2095 forum posts 75 photos | I did my engineering in metric and following employment but my hobby of stationary engines has me working in imperial as I did at school. The one thing I find in metric is there are less decimal points to work with than when using imperial. Martin P |
Mick B1 | 08/02/2020 15:51:01 |
2444 forum posts 139 photos | Posted by John Baron on 08/02/2020 12:16:47:
Yep, and one more... |
geoff adams | 08/02/2020 17:01:47 |
214 forum posts 207 photos | worked in the aircraft industry for many years making instruments the only machines that could use mertic where the cncs which i programmed all the manual machines in the shop where english drawing office produced a metric instrument drawing really funny dims 3.175 reamed hole guess what its an 1/8 dims all other the drawing like this it was an english to metric conversion .we had to work with europe (concord) and america had to use both the metric and english dims and easiest system is metric but i still convert back to english for tolerances english and american threads are nightmare give me metric all day long and iam old school Geoff |
