Here is a list of all the postings Spurry has made in our forums. Click on a thread name to jump to the thread.
Thread: What are these clips called? |
20/03/2023 18:09:08 |
Following on from bernard's idea, copy the method used on Makita impact wrenches which is to have a shallow groove which holds an O ring to keep the pin in place. |
Thread: Lathes on casters |
20/01/2023 13:03:12 |
Some good points made there, Dave. Probably picked what I have learnt, the same way as you. My only disagreement would be with the wheels on a lathe. Almost everything I make or use has wheels...it's probably an age thing. The wheels possibly could make the lathe less rigid I guess, but if it ever caused a problem, there would have to be a re-think Still, it's been Ok for 38 yrs so far. Pete |
Thread: Another EVRI calamity. |
08/01/2023 13:54:26 |
We have never had a problem with deliveries by Evri, despite living in a house without a number. Postcode covers only six dwellings though. Others not quite so lucky. https://www.edp24.co.uk/news/23235115.city-evri-delivery-driver-thief-told-pay-back-1k/
Thread: Dissolved Acetylene Suppliers - Rent Free? |
28/09/2022 19:33:15 |
Thanks for the info Steve. I was hoping to be able to achieve something like this. Lead welding. I used to rent the cylinders from BOC but had to cease when the prices soared to silly levels, (for my amount of use) Pete |
28/09/2022 18:59:37 |
Having read the posts in this thread, would anyone have an idea of a gas that could be used for lead welding? (Apart from Oxy/acetylene of course). TIA Pete |
Thread: Help: Cordless angle grinder keeps shutting down? |
09/06/2022 19:23:26 |
I have a Makita one, and the larger capacity packs are recommended. They do tend to pull quite a bit of power, so normally use a 5 or 6Ah one. |
Thread: Green growth on car roof rails |
06/02/2022 15:31:46 |
A pressure washer will definitely get rid of it, on a temporary basis, but be very careful near the rubber seals as they can be damaged with just a little too much pressure. (Experience teaches!) |
Thread: Harrison 250 |
13/01/2022 16:59:34 |
Gavlar These look like the ones I bought from Ebay 154566689162. They have been perfectly adequate for my M250, but you may have needed heavier duty. Pete |
12/01/2022 18:57:06 |
Posted by Norfolk Boy on 12/01/2022 18:11:42:
Hi Spurry, I have an M250 and they are quite low, so can see 2 benefits with that set up, gaining height and flexibilty. I will definitely use that idea. Where did you source the stout looking wheels? I am sure some may think it would affect ultimate accuracy but I would be more than happy with the trade off.
Alan Being 6'3", the increase in bed height does reduce the amount I have to bend. The ability to move the machine at will is a huge benefit too. I guess the wheels would probably have come from Ebay, paid by Paypal 16/6/2010, at cost of £42.50. Cannot recall the exact seller, sorry. Pete |
12/01/2022 17:46:47 |
EGA If you have a look in my album, there are several pictures of the mod. (It is not my original idea BTW.) The actual raising and lowering action results from a cam action, so not much effort is required. The little odd-shaped piece is the auto lock. Pete |
12/01/2022 13:56:34 |
You could always mount on 5 wheels, which makes single-handed movement a doddle. Pete |
12/01/2022 13:46:19 |
Andrew's comment is correct regarding the factory alignment. My M250 was replaced by Harrisons when I bought it in 1986, because of a problem with the bed to stand joint. I would agree with Richard that you could remove such bits as the motor, tailstock, end cover and splashback, to make it a little lighter. Pete |
Thread: Hi from sunny Norfolk (uk) |
28/12/2021 22:53:06 |
Greetings too!! But have to admit it's been a bit wet and grim in my bit of Norfolk today. Pete |
Thread: 75mm x 2000mm Belt Linisher Build Thread |
05/11/2021 11:31:35 |
Clive, I read the title as a linisher for a 2000mm belt, as the tiny linisher I have from Axminster tools uses a 785mm belt. Pete |
Thread: Music on TV Programmes. |
04/11/2021 17:54:37 |
Don't, whatever you do, mention the volume of the adverts compared to the volume of the actual programmes. |
Thread: Back to Imperial |
17/09/2021 19:27:29 |
What's the betting/odds that petrol will not be sold by the gallon? £6.91 for a gallon - you must be joking! |
Thread: Standard Surveying Thread? |
15/09/2021 17:42:09 |
Thanks everyone for all the info. Most useful. I had bought some 5/8" UNC studding, and corresponding tap, on the gamble it was a UNC thread, as BSW is a bit thin on the ground in modern stuff. The studding does fit the laser base without a problem, so as Jason commented, either will do. (I have a couple of tripods, lasers, and adapters but all my measurements were so different, so as not to be much use, hence the search to find out 'exactly' what they should be) Pete
15/09/2021 14:11:48 |
Having read through the interesting thread on the Leica specifications, would anyone have a definitive answer to what exactly is a Standard Surveying Thread. It is used to attach a laser level to a tripod. The most info I can find is that it is 5/8" and 11TPI. The company I purchased the laser from are of the opinion that it is BSW, but cannot say for sure. As a coincidence 5/8" x 11 TPI is also a standard UNC thread, but obviously a 60 deg compared to the BSW 55 deg. In the general run of things, it probably does not not make a great deal of difference, and either would probably be suitable, but only one is correct. I am somewhat perplexed with the difficulty in finding the correct spec. Pete |
Thread: TurboCAD Query - Copying Between Drawings |
03/05/2021 14:23:38 |
If an item is Selected then copied via the drop-down menu for Make Copy, the new copy can end up on top of the old one, so you think has not worked, when in fact it has. When tried several times, this can result in lines stacked on top of one another, one problem being that it just looks like one line. Pete |
Thread: Honda 125 electrics |
28/03/2021 18:04:11 |
I think it certainly worth a try going through your scenario but with the engine running, before delving too deeply into what could be wrong. Pete |
