Here is a list of all the postings Eric Cox has made in our forums. Click on a thread name to jump to the thread.
Thread: James Bond Aston Martin DB5 |
16/07/2023 10:45:20 |
Sounds like the Airfix model that was about 10 long. |
Thread: What fuse is required |
27/06/2023 10:52:25 |
I've just called Chester and they said a 13amp fuse would be ok. seems a bit high as the motor on my WM14 mill is protected with a 2amp fuse. not done it yet, the link you posted was to this forum posting. |
26/06/2023 20:04:22 |
That's for the mains plug
26/06/2023 15:27:10 |
I've just blown the fuse on the front panel of my conquest super lathe. I can see the fuse is F rated but can't read the current. Does any know what size fuse is required. Edited By Eric Cox on 26/06/2023 15:28:04 |
Thread: Brought some rubbish back from the "recycling centre" |
09/06/2023 10:45:35 |
If you took something from the tip and it then caused injury to yourself or others then the council could be held responsible and open to legal action,
Thread: 3D Printer |
21/03/2023 10:31:45 |
Thread: Lake Macquarie Live Steam Rally |
07/03/2023 10:17:42 |
Had to laugh at the model engineers version of skate boarding at the end of the video |
Thread: Flying scotsman |
05/03/2023 11:00:45 |
Just watched an interesting on the fFying Scotsman here |
Thread: Metric end mills |
24/02/2023 10:33:27 |
Are the threads on metric end mills metric or imperial. If they are metric, does this mean I will have to buy a metric arbour. or is there a way that I can utilise my imperial arbour. |
Thread: Yet another scam |
03/01/2023 10:53:45 |
I received a text message yesterday telling me that I had a failed parcel delivery as no one was in but if I followed the link I could arrange another delivery if I paid £1 20. I was in and wasn't expecting a parcel also schedule was spelt incorectly Quick search on google confirmed it was a scam.
Thread: SpamScam Phone Calls |
22/12/2022 10:44:37 |
Makes a change from Indian accents
Thread: Hi or Low |
25/08/2022 10:09:33 |
I know what you mean I did the same as I used a slitting saw for the first time. |
25/08/2022 09:55:07 |
On a WM14 mill is it preferable to run 620 rpm in the high ratio or 620 in the low ratio? |
Thread: No refund |
10/06/2022 10:34:54 |
I recently contacted the ME magazine publishers to cancel my subscription as I no longer wished to receive the magazine. They responded by telling me they had cancelled my subscription and that I would receive 14 more issues. I told them that didn't want the magazine and would they please refund me for the cost of the remaining 14 issues. They told me they didn't do refunds so I'm now out of pocket and will be receiving a magazine I no longer want. |
Thread: aluminium sticking to end mill |
24/05/2022 09:59:44 |
I dropped the speed down to 1000 rpm.and it worked fine, |
23/05/2022 11:09:02 |
I have been cutting some slots in aluminium using a 1/4" end mill running at 2800 rpm and hand fed with a depth of 30 thou. The aluminium is sticking to the end mill and closing up the flutes. How do I over come this |
Thread: Create a "transfer" |
28/04/2022 11:24:12 |
If you don't have any transfer paper you can create "transfer" in the following way select design reduce to correct size and print out on ordinary printer paper when ink is dried apply two coats of clear nail varnish allow drying between coats cut out and soak in water rub off paper and you'll be left with a "transfer" ready to be applied. |
Thread: A Remarkable Model Engineer |
25/04/2022 10:08:50 |
Love the term " manually fabricated " |
Thread: Can you identify these hand tools? |
23/12/2021 10:09:47 |
Not forgetting striped or tartan paint. |
Thread: 2021 Christmas Cracker-ish humour |
20/12/2021 10:16:59 |
What do you call a man who has a bird of prey on each shoulder and vacuums the house at night.
Hawk kestrel man hoovers in the dark (say it fast) |
