Martin King 2 | 20/12/2017 16:55:04 |
![]() 1129 forum posts 1 photos | Hi All, We get a lot of these small needle files and Bedford is a common make at the upper end of the quality tree after Grobet, Vallorbe, Stubs and a Portugese make that I cannot remember at the moment. They are often very flexible but never seem to break even when pushed hard. All very good news from a selling point of view, they fly away when listed. Cheers and Season's Greetings to all, with many thanks to all the members here who have been kind enough to help me out over the last year. Martin
dcosta | 20/12/2017 17:13:15 |
496 forum posts 207 photos | Hi Martin, Dias Costa |
Martin King 2 | 20/12/2017 18:04:26 |
![]() 1129 forum posts 1 photos | Spot on! Obrigado! Martin |
Mike Poole | 20/12/2017 18:40:24 |
![]() 3676 forum posts 82 photos | Bedford were a decent Sheffield toolmaker, they made a variety of tools spanners cold chisels and files at least, I still use the Bedford spanners I bought as an apprentice abut 45 years ago. Mike |
Neil Wyatt | 20/12/2017 18:48:46 |
![]() 19226 forum posts 749 photos 86 articles | If you think the Swiss files we use, look what this one costs. But it is for a higher-precision purpose... Neil |
Martin W | 20/12/2017 18:59:57 |
940 forum posts 30 photos | Neil I thought that the Swiss were completely metric I didn't know that they still make and sell imperial files Wishing all a Happy Christmas and Fruitful New Year. Martin W Edited By Martin W on 20/12/2017 19:00:33 |
JohnF | 20/12/2017 19:29:46 |
![]() 1243 forum posts 202 photos | Another use for thin files such s these is cutting slots in screw heads for watches, clocks, guns etc -- I have some but also use modified fine tooth hacksaw blades -- grind the teeth away on each side of the blade to between 10 & 25 thou thick and they work well. Some screw slot files are also produced in a diamond cross section. |
terry simpson 1 | 20/12/2017 20:46:16 |
18 forum posts | The file in question is one used for refreshing magneto points having seen one being used. The occasion being during weekends as members of the ATC in 1950, at RAF Thornaby , being instructed as to how the systems work for routine servicing of aircraft and to how the fitters completed the work and signed off all actions they were responsible for. One instance demonstrated was the cleaning of engine electric breaker points, if I recollect was completed on an Anson engine, using a very fine file just like the one subject of this post. I cannot remember how awkward the access was to the magneto in this instance. One assumption regarding the subject file handle 1.5mm square, surely if working in a confined space, one would need to know that the one or two flat file surfaces were in the correct plane to complete the work where as a round handle needle file correct positioning could not be guaranteed. |
John Reese | 20/12/2017 21:16:31 |
![]() 1071 forum posts | Definitely a distributor breaker point file. They used to be quite common. |
Ian P | 20/12/2017 21:53:35 |
![]() 2747 forum posts 123 photos | Posted by terry simpson 1 on 20/12/2017 20:46:16:
. One assumption regarding the subject file handle 1.5mm square, surely if working in a confined space, one would need to know that the one or two flat file surfaces were in the correct plane to complete the work where as a round handle needle file correct positioning could not be guaranteed. When using the file (for its designed purpose) there is no need to know the precise plane of the blade. The opposite sides of the file both have the same tooth pitch and when trapped between the points of a contact breaker the cutting pressure comes solely and equally on both faces from the spring holding the contacts closed. Obviously the contact breaker points need to be separated to insert the file and the file flexibility allows it to more or less to self align whilst is is pushed and pulled. The files thickness (or thinness really) mean the two contact faces are virtually parallel ensuring good contact area. Ian P
OldMetaller | 21/12/2017 09:55:10 |
![]() 208 forum posts 25 photos | Posted by Neil Wyatt on 20/12/2017 18:48:46:
If you think the Swiss files we use, look what this one costs. But it is for a higher-precision purpose... Neil Blimey! I didn't realise some people's feet were so toxic! Why not use a bit of wet and dry stuck to a 99p cooking spatula?! Regards, John. |
martin perman | 21/12/2017 10:40:54 |
![]() 2095 forum posts 75 photos | Posted by Neil Wyatt on 20/12/2017 15:31:40:
It's a 'Bedford' file, famously used by Bedford Council for filing paperwork by enlarging the gaps between existing documents, so they could cram even more bureaucracy into a each filing cabinet. I can't believe you didn't know that. Neil Sadly Neil you are very close to the truth, as a resident in Bedfordshire the biggest problem this area has is its Councils including the Borough. Edited By martin perman on 21/12/2017 10:41:41 |
jimmy b | 21/12/2017 10:41:10 |
![]() 857 forum posts 45 photos | Posted by OldMetaller on 21/12/2017 09:55:10:
If you think the Swiss files we use, look what this one costs. But it is for a higher-precision purpose... Neil Blimey! I didn't realise some people's feet were so toxic! Why not use a bit of wet and dry stuck to a 99p cooking spatula?! Regards, John. you should see my feet.......
jim |
Philip Rowe | 20/10/2022 17:15:07 |
248 forum posts 33 photos |
Gentlemen, I realise that this is a very old thread but I have found in the box that the "contact file" was in, yet another peculiar needle file. This has an overall length of 90mm and if you look carefully the cutting portion of the file is approximately 55mm long. The tip measures 0.5 x 1.5mm and it tapers to approximately 1.25 x 2.5mm, the cut is extremely fine, it barely makes any mark on brass (haven't tried it on steel) and I can barely see a mark when running it across a finger nail. Using a 10x magnifier l can't find any markings on the plain portion ie handle. Have any of you any ideas what this could have been for? I did think that it might have had a clock/watch connection but I've not been able to prove/disprove this idea. Phil |
Bazyle | 20/10/2022 17:59:13 |
![]() 6956 forum posts 229 photos | It sounds like a pivot burnisher..... |
Michael Gilligan | 20/10/2022 18:08:52 |
![]() 23121 forum posts 1360 photos | Phil From your description, that sounds like ‘cut 6’ [where ‘cut 0’ is the coarse one] MichaelG.
V8Eng | 20/10/2022 18:36:06 |
1826 forum posts 1 photos | Is it anything like this? They come in various other shapes as well. Edited By V8Eng on 20/10/2022 18:37:24 Edited By V8Eng on 20/10/2022 18:39:46 |
Bill Phinn | 20/10/2022 18:40:31 |
1076 forum posts 129 photos | Posted by V8Eng on 20/10/2022 18:36:06:
Is it anything like this? Edited By V8Eng on 20/10/2022 18:37:24 It won't be one of those, V8; those aren't toothed [like the one in Philip's picture] but have diamond particles [or some sort of abrasive material, at any rate] embedded in them. Edited By Bill Phinn on 20/10/2022 18:42:59 |
KWIL | 20/10/2022 19:08:53 |
3681 forum posts 70 photos | Even the cheaper diamond plates make a good foot file and so much cheaper than Neil's |
DMB | 20/10/2022 19:28:43 |
1585 forum posts 1 photos | Kwil, I uttered a certain word starting with F, upon reading Neil's Swiss advert and seeing the price, but I guess that as usual, you get what you pay for, if you're lucky. I think that you may have missed the fact that the Swiss version is Stainless and can be sterilised to prevent cross infection. John |
