What Did You Do Today 2019
Clive India21/03/2019 08:52:47
277 forum posts
Posted by Terry Kirkup on 20/03/2019 21:53:13:
I've just finished this for my lathe. laugh if you like, once a biker always...
(I'm a better biker than machinist).
Me too - but then I'm no good at biking either.
No doubt golfers might come up with something familiar to them.
Magazine editors might use a part from a linotype machine? Link
Whatever floats your boat, but I can't help thinking there are other, more comfortable, handles.
Raised a smile, thanks for posting.
Ian Hewson21/03/2019 09:37:29
354 forum posts
33 photos
Wouldn’t want to get those cables caught up in it Terry, nice as it is lol.
Edited By Ian Hewson on 21/03/2019 09:38:05
Brian H21/03/2019 10:28:17
2312 forum posts
112 photos
Finally solved my problem with windows updates; I have an identical PC in the workshop that I cancelled the update on.
I've swapped PCs and now don't have a problem because the one in the workshop is only used for quick internet checks for information.
Brian
Neil Wyatt21/03/2019 10:43:01
19226 forum posts
749 photos
86 articles
Posted by Danny M2Z on 21/03/2019 08:12:34:
Today I started test flights on a new Free Flight model from a 1952 design that has kept me busy in the workshop for the last month (Aussie Nats in April). It's looking promising
Only use of the C3 Mini-lathe was to manufacture the fuel shut-off and tweak the ports of the equally ancient FROG 150 model diesel engine.
If anybody is interested in such things, here is a linky **LINK**
* Danny M *
I have a KeilKraft Ladybird made in 1952 by my late father in law.
I flew it once (at Sutton Park) when it was 50 years old using a DC Merlin. I do keep meaning to re-restore it and perhaps add micro RC for rudder, just to keep it in sight!
Neil Wyatt21/03/2019 10:44:21
19226 forum posts
749 photos
86 articles
Who needs a VFD, eh?
Ian Skeldon 221/03/2019 12:27:10
543 forum posts
54 photos
Great day so far......
Day off from work smiley, MEW mag dropped through the letter box and shortly after that the Vertex rotary table I bought second hand from forum member David Corner arrived.
David I commend your packing sir and I can't thank you enough for being such a gent to deal with.
Many thanks,
Ian
Terry Kirkup21/03/2019 14:02:32
108 forum posts
82 photos
Clive India I was hoping to find an old 1950s Raleigh type pedal with a loose central spindle, removing the rubbers and the end shells would have left me with a lovely chrome plated handle!
Roderick Jenkins21/03/2019 21:22:24
2376 forum posts
800 photos
I'm making a pallet for my rotary table. Lots of M6 tapped holes. With this in mind I bought an Archer auto reverse tapper from ebay.
Rod
Edited By Roderick Jenkins on 21/03/2019 21:25:18
Nigel Graham 221/03/2019 21:57:03
3293 forum posts
112 photos
Examined my Myford VMC mill to see how best to fit the Allendale DRO magnetic-strip profile. Not easy to find anywhere suitable, really!
If I put it directly along the front edge of the bed I will need either to make little dovetail nuts or drill and tap the back wall of the slot in which the bed stops work. Only they won't be there any more.
A fraction too high and the profile and its cover are above the bed surface. A fraction low and it fouls the oil-nipples. Also if for any reason I had to remove it from the bed, I'd have to destroy the strip itself as that is stuck on, and hides the mounting-screws.
So thinks on.... Machine a set of cross-pieces to be screwed into the bed face, outside the profile which would be screwed to them? Not much room available, but it might be possible. I'd still lose the bed-stops, probably also the locks, and risk the oilers being inaccessible.
And that's even before I think about trying to fit the cross and vertical travel encoder profiles on a machine not designed for such luxuries!
By now my stomach was telling me to forage for food, and my brain was fading from all that thinking! So I locked up and retreated to the house for the evening.
Andrew Johnston22/03/2019 20:39:45
7061 forum posts
719 photos
Posted by Mike Poole on 19/03/2019 21:28:16:
It might be worth swinging the Kurt round so the cutting force is against the fixed jaw, it looks as though the vice is big enough to clamp the job endways to still cut in one pass.
Indeed it is; the vice will take 8.5" between the jaws. Although given the ends were sawn I wonder if the work might have tilted over instead? Clearly I've still got a lot to learn about man-sized milling on a horizontal. On the high speed range the motor power is 5hp. The spindle is driven by a gearbox so at 100rpm that's a lot of torque. I suspect 'orrid things might happen before the spindle stalls. Thus far I haven't got the motor to sound like it's even working. embarrassed
Emgee22/03/2019 20:54:39
2610 forum posts
312 photos
Good investment Roderick, saves a lot of work, like your quick clamp method.
Emgee
John Reese22/03/2019 23:50:43
1071 forum posts
Today I found the Mitutoyo digital mike that had been lost for 10 months. The one I bought as a replacement came yesterday.
Roderick Jenkins23/03/2019 09:57:25
2376 forum posts
800 photos
Finished the pallet. I don't think my dodgy shoulder would have let me tap the holes by hand.
One half of the disc has holes on a rectangular array and the other half is radial. Not sure if this was a good idea or not. I've got a pallet on the CNC mill that's also waiting for an array of holes.
Rod
Ian S C23/03/2019 11:32:08
7468 forum posts
230 photos
Andrew, could you arrange a method of holding the pieces direct on the table and doing away with the vice, a 1/4" bar across each end, and maybe something each side, I use that method when facing similar bits with the face cutter on the vertical mill and don't have any trouble with the metal getting thrown out side ways ( I thought that might be a problem). I'v only got the useless tilting vice that came with the mill.
Ian S C
mechman4823/03/2019 15:45:27
2947 forum posts
468 photos
Spent some time trying to figure out how to re-arrange my stuff ( take 'trying 'as optimistic thinking ) ended up making an adaptor plate for my compound slide handle to allow me to use cordless drill as auto feed for tapers etc …
not designer chic but hey ! it works...
Didn't have any 8mm hex bar for the centre drive & wasn't going to cut down a piece of 12mm just for a 'make do' set up so used some 8mm screwed rod ,couple of washers, nuts & some thread lock... Bob's your auntie... summat like that.
George.
ChrisH23/03/2019 17:40:47
1023 forum posts
30 photos
George - I really like that idea - turning the top slide handle to take a cut is a pain at the best of times.......
Chris
Nigel Graham 223/03/2019 22:11:04
3293 forum posts
112 photos
If you need to turn lots and lots of tapers, I wonder how feasible it would be to fit a secondary change-wheel train to the saddle, and linking lead-screw or rack to cross-slide, thus generating the taper?
In fact I have seen several You-tube videos of lathes apparently built with this facility - all were in Russia, being used to make large-diameter, quick-taper "wood-screws" the videos went on to reveal are log-splitters.
Nigel Graham 223/03/2019 22:22:33
3293 forum posts
112 photos
John Reese:
AWOL micrometer? One knows how one feels....
Awkward steam-engine design calculation a bit beyond my brain and paper-and-pencil range, and before I had a computer.
Find calculator. Oh, can't find calculator.
Slide-rule? Can't find my slide-rule.
Nothing for it: logarithms, with a quick self-taught refresher lesson.
Next day, bought new scientific calculator (surprisingly, significantly larger than the lost one).
Three weeks later, opening a drawer to retrieve something else, there was the absent calculator.
I'd swear homes and workshops develop black holes. Tiny ones, without the power of the cosmic sort so unable to sustain themselves, consequently dispersing fairly soon and dropping their "eaten" hence temporarily invisible items unharmed wherever they happen to have drifted as they dissolve.
martin perman26/03/2019 21:28:51
2095 forum posts
75 photos
Gentlemen,
I know its not model engineering but my wife and I both engineered the concept thirty eight years ago and yesterday evening our Daughter presented us with our first little engineer and stationary engine lover, a Grandson.
Martin P
mechman4827/03/2019 09:47:36
2947 forum posts
468 photos
Posted by martin perman on 26/03/2019 21:28:51:
Gentlemen,
Martin P
thumbs up... after the initial planning , modifications / upgrades come later.
George.
This thread is closed.
