Facing off with carbide tip tool causes hardening of workpiece?
Steve Withnell23/03/2014 14:10:24
858 forum posts
215 photos
I've just been facing off to length some 1/2 inch square bar (Columns for a Stuart James Coombes). Faced off and centre drilled a couple with an HSS knife tool and no problem at all. I needed to set up left and right hand carbide tip tools, so used the facing off to check the tool height.
Faced off a length off the bar and broke the centre drill. Decided I'd been careless. So faced off the other end and took more care with the centre drill. Snapped the tip off. (Using a No.2 size centre drill) . The tips are the typical triangular indexable types, been using them for years.
Reverted to the HSS knife tool, no problem at all.
My assumption is that the carbide tip tool has "twisted off" the material as it got it centre, rather than shearing it off, causing it to harden.
The bar was sold as EN1, but it might be EN3.
(PS I'm not using the round bar in the James Coombe castings kit, because I have a specific design in mind for the columns...which I thought would be good turning practice and hopefully will look really smart if I get it right)
Steve
Ian P23/03/2014 14:32:55
2747 forum posts
123 photos
Steve
You've not been near the drinks cabinet have you?wink
Unusually your description is very confusing.
You centre drilled with knife tool?, 'the No2 size bit was the usual triangular insert?
Are these carbide slocumb bits? but not what I would call triangular.
A better explanation would help me if possible
Ian P
JasonB23/03/2014 16:13:27
I'd say you are a bit above ctr height with the carbide tools which leaves a conical bump on the end of the work which is pushing the Ctr drill to the side. Or not actually going all the way past centre so teh radius on te insert is also leaving the same shape bump
Steve Withnell23/03/2014 17:50:11
858 forum posts
215 photos
Let me try that again!!
I've just been facing off, to length, some 1/2 inch square bar (Columns for a Stuart James Coombes).
Faced off with an HSS knife tool, then centre drilled without a problem (Using a No.2 centre drill).
Next I set up a carbide tip tool, the indexable triangular type, adjusted the height, and then faced off a length of the square bar. When I centre drilled the bar I broke the centre drill. Decided I'd been careless. So I faced off the other end and took more care with the centre drill. Snapped the tip off.
I'll re-check the tool height, sounds best explanation, though the material didn't show any signs of a dimple and the drill didn't show any signs of wandering off. Pretty sure it's not key steel.
In terms of EN1/3 not hardening,  would that hold true if I literally twisted a length until it sheared into two pieces? I'd have expected the sheared ends to be harder than the bar in it's natural state.  So not hardening through machining, but by dint of being stretched beyond it's elasticity.
Hopefully, the Neurons fired in the right order this time, instead of some random sequence!
Steve
Edited By Steve Withnell on 23/03/2014 17:55:33
julian atkins23/03/2014 22:29:50
1285 forum posts
353 photos
hi steve,
you are not alone!
ive centred axles for miniature locos in batches then usually on the last one the blessed tip of the centre/slocombe drill breaks off in the work. no logical reason why other than a bit 'gun ho' as the jobs progress.
this has happened twice in 30 years. i still cannot fathom why it should happen. i am a little more careful these days and less haste etc...
cheers,
julian
Michael Gilligan24/03/2014 06:54:57
23121 forum posts
1360 photos
Steve,
It doesn't explain why you have this problen, but the solution should be simple:
"Catch" the centre, using a Watchmaker's Graver.
... It only takes a few seconds with a Lozenge-shaped graver [*]
... if you don't have a Hand-Turning Rest, just put a length of rod in the toolholder
[ Please remember to wear good eye-protection ]
[*] Edit: also known as a Diamond graver; but be aware,
that's the shape of the tip, not the material.
Edited By Michael Gilligan on 24/03/2014 07:05:38
Gordon W24/03/2014 09:07:03
2011 forum posts
Could also be a bit of dodgy steel, esp. if EN3b. I ve had this a couple of times lately, maybe a bit of scrap ball-bearing got in the mix.
jason udall24/03/2014 11:03:32
2032 forum posts
41 photos
My thoughs..yes probably the shape of pip left after facing..is the culprit.
The nice thing about hss is you can grind with zero left hand radius if thats what you need...
This is why in industry hss part off blades still have a market.
Ady124/03/2014 11:17:52
6137 forum posts
893 photos
Weird things can happen around the centre area because you have almost infinite torque, zero speed and rapid changes of direction (360degrees) in a tiny workzone
HSS is more flexible and forgiving but carbide breaks
I drill a depression/hole in the centre before facing off, if the job allows it
Edited By Ady1 on 24/03/2014 11:21:19
Ady124/03/2014 11:28:24
6137 forum posts
893 photos
My favourite centring tool is one of those carbide tipped dead centres, I ground half the tip away so it can now be pushed in and pops a centre hole instantly in the workpiece like a d-bit drill
Russell Eberhardt24/03/2014 12:01:10
2785 forum posts
87 photos
Very few of the above replies address the difference between facing using an HSS tool and a carbide tipped tool. I would agree, Steve that a possible culprit is work hardenning of the surface due to the fact that the carbide tips are not as sharp as a well honed HSS tool.
Michael, while EN1/3 cannot be hardened by heat treatment I think it can be work hardenned, or am I talking out of the top of my head?
Russell.
ian cable24/03/2014 14:02:28
40 forum posts
hi ya, try it the other way round centre drill first then face off, unless your piece of material is sawn/cut at a really bad angle this is quite a safe way of keeping your slocam drills intacked.in my personal experience ive never known eni/3 to work harden,but anything is possible ian c
jason udall24/03/2014 14:55:36
2032 forum posts
41 photos
Like that Michael..
If it is work hardening then it is.
Ok so en1a or en3 shouldn't. .but if it does then now you know something new.
Please share.
Ian S C25/03/2014 10:58:43
7468 forum posts
230 photos
I feel that you are making too fine a cut, and the tool is rubbing on the work, this gets worse as you near the centre of the bar. With a carbide tool you need to take a good size cut, and feed it in fairly hard. Me, I'd stick to HSS.
Ian S C
