Chris Parsons | 02/09/2013 10:40:23 |
![]() 118 forum posts 37 photos | My new mill is being delivered on Friday (wahoo) and I am trying to anticipate what I need to get started, with the proviso that having just stumped up a lot of money *sob* I am looking for the minimum at the moment? I have bought an ER32 collet chuck, collets from 6 - 12mm, a set of workpiece clamps, and will nip up to Tracy Tools in the next couple of days to get some HSS end and slot mills - they do sets from 3 - 12mm which I thought would get me started, perhaps with a few extra spares - not sure which sizes to get extra having said that.... I have the normal stuff for using with my lathe, measuring, marking out and so on - can anyone suggest anything else that they would consider to be really essential to get going? Thanks Chris |
jason udall | 02/09/2013 10:55:49 |
2032 forum posts 41 photos | Something to chew on other than the bed or work holding?.....![]() |
JasonB | 02/09/2013 12:51:55 |
![]() 25215 forum posts 3105 photos 1 articles | DTI to set the work and vice true. Edge & centre finders
J Edited By JasonB on 02/09/2013 13:36:20 |
Geoff Theasby | 02/09/2013 13:09:13 |
615 forum posts 21 photos | A drill chuck...? Regards, Geoff |
mechman48 | 02/09/2013 13:21:19 |
![]() 2947 forum posts 468 photos | Chris What mill are you getting? ER 32 collet sets come with up to 20mm dia cutter collets, have you bought them separate? could end up more expensive buying them individually? Rotating tailstock center ! Regards George |
PekkaNF | 02/09/2013 14:06:24 |
96 forum posts 12 photos | Two pieces of advice: 1) Stop spending. Don't buy any cheap tools until you absolutely need them. Then buy ONLY tools you need and quality. 2) If you are any new to milling buy a book "Milling: A Complete Course" Harold Hall. And in meantime visit his site: http://homews.co.uk/page463.html Some of the clamps and other workholding equipment can be bought, but quite a bit is least as good when made at home. PekkaNF |
Thor 🇳🇴 | 02/09/2013 14:14:12 |
![]() 1766 forum posts 46 photos | Hi Chris, I agree with the advice given by MikeW. If you want to make your own vice here are a few webplaces that may be of interest: Screwless vice, another one, I made a similar one myself. Dean's version. Regards Thor Edited By Thor on 02/09/2013 14:22:46 |
Chris Parsons | 02/09/2013 14:15:24 |
![]() 118 forum posts 37 photos | Jason U - I smiled and then thought good point, most of my 'stock' is round bar! Michael - I am going to have a go at making a 'split' vice as in Howard Hall's book so I can mount work directly on the table, and hold off on the commercial vice - they are expensive (looked at a Vertex VA4 but think it might be too big for the table?) Already got a flycutter on a straight shank but may eventually get one with a taper. Got cutting fluid (use it on lathe and bench drill) Got parallels but good point about packing - might also make some of my own clamps/fences (good practise) Good source for quality cutters? With no experience it's hard to judge good or bad...most of the stuff I get from Tracy Tools seems OK? Jason B - Already got a dial indicator, DTI and an edge finder but not centre finder (yet) Bought a mount to fit the DTI to the quill (looks like an Indicol?) Geoff - comes with a drill chuck fortunately (one less thing to buy) George - got an ER32 set from ArcEuroTrade with chuck and 6 collets in case - 6, 8, 10, 12, 16 and 20mm? Rotating tailstock center??? I have one for the lathe but it's MT2, what would I use this for on a mill? Oh, and the mill is a Sieg SX3 Thanks for all the suggestions, if you don't ask you never learn One other thing is the issue about clouting the drawbar to get the (MT3) taper out - been trying to visualise the various posts about self extracting drawbar modications I went for MT3 in the end so I could use the tooling on the lathe Cheers Chris
Russell Eberhardt | 02/09/2013 14:55:24 |
![]() 2785 forum posts 87 photos | My most useful accesory, after the assorted clamps (homemade) is the angle plate. Russell. |
GaryM | 02/09/2013 15:49:24 |
![]() 314 forum posts 44 photos | An IKEA Jansjo lamp? £10 Gary |
Stub Mandrel | 02/09/2013 22:00:41 |
![]() 4318 forum posts 291 photos 1 articles | Most used accessory? After the vice (with apologies to Harold "Clamp Evangelist" Hall!) my home made ER25 chucks, my self releasing drawbar and then my rotary table (but I do like making gears and wheels etc.) Neil To be fair to Harold, he's obviously travelled the road to Damascus, having just given us a series on milling vices! Edited By Stub Mandrel on 02/09/2013 22:01:47 |
GaryM | 02/09/2013 23:03:14 |
![]() 314 forum posts 44 photos | A simple mod I made to mine was to add four M12 washers to the X-axis feed handle to keep the dog clutch permanently engaged. Gary |
Geoff Theasby | 03/09/2013 02:51:04 |
615 forum posts 21 photos | Re: clouting the drawbar to release the taper. I have suggested using a rubber hammer, but I find now that it is less effective than using a light steel hammer to tap the drawbar end. Not a heavy blow, just enough to release it. This implies that you don't need to tighten the spindle very much in the first place. Just nip it up. You will soon get the feel of it. Geoff |
Robbo | 03/09/2013 10:53:09 |
1504 forum posts 142 photos | Just a point on hitting the drawbar. Hard faced Thorex mallet is the thing. If you use a metal hammer, be sure to wind the drawbar nut up to the top of the threads so as not to burr the thread over. Phil |
Paul Lousick | 03/09/2013 11:01:25 |
2276 forum posts 801 photos | I have the same mill and also chose a 3MT version so I could use my lathe tools. Don't overtighten the drawbar. I use an aluminium hammer to release the tools but cringe every time I hit it. As previously said, buy quality tooling as you need them. Keep an eye on e-bay for good used tools. A quality used tool is far better than new asian junk. You can also make lots of your own. Happy machining. |
Russell Eberhardt | 03/09/2013 11:06:01 |
![]() 2785 forum posts 87 photos | Posted by Paul Lousick on 03/09/2013 11:01:25:
I use an aluminium hammer to release the tools but cringe every time I hit it. Same here, but I always lock the quill before hitting it to keep the shock, such as it is, off the rack. Russell. |
Chris Parsons | 03/09/2013 11:25:02 |
![]() 118 forum posts 37 photos | Thanks for the additional information - I have both of Howard Hall's milling books, excellent guides - and will be making a good bit of the tooling myself Think perhaps I am worrying about the drawbar removal too much, I will not overdo it and I already have a copper/hide hammer which I will use to save the drawbar top and locking the quill first is an excellent suggestion Thanks Thor for the links to the vices - the first one was an excellent site, keep me busy for months, there is loads of stuff on there I am thinking about having a go at now Think I have worked out the principle of the self releasing drawbar now so this is an alternative too I don't subscribe to any of the options so missed the series on milling vices which was mentioned - and even if I did now would not get the 'back issues' ?? Two days and counting... Chris
GaryM | 03/09/2013 14:14:53 |
![]() 314 forum posts 44 photos | Chris, the drawbar on the X3 doesn't have exposed threads on the top end. It's a hex socket and so unlikely to damaged. I went for the R8 as a result of reading many threads on which taper to choose. Never needs more than a light tap. Gary |
Bazyle | 03/09/2013 15:16:39 |
![]() 6956 forum posts 229 photos | Doesn't the X3 have a slot in the quill for MT3 tool 'persuasion'? I keep forgetting it is there on my old Warco minor. The other thing for tool removal is a pair of those U shaped wedges. |
Norman Lorton | 04/09/2013 21:33:57 |
31 forum posts 6 photos | I do apologise to all you MT3 people, but I agree with Gary. I am sure that the MT3 works fine in holding tooling but R8 holds and then lets go when you want it to. Edited By Norman Lorton on 04/09/2013 21:40:31 |
