Ian Parkin | 16/01/2013 12:03:01 |
![]() 1174 forum posts 303 photos | I need a new length of steel for my startrite pillar drill column 1.5 metres long would be fine it needs to be 2 3/4 " diameter any suggestions on where to source such material and will it need grinding to size or will bright drawn be ok wall thickness is 4mm or thereabouts
Ian |
NJH | 16/01/2013 13:05:54 |
![]() 2314 forum posts 139 photos | Hi Ian M Machine Metals list a 2.75"dia x 1/4" wall steel tube here ............... SIT DOWN NOW...... AT £27 PER 300mm !!!! Good luck! Norman
Ian Parkin | 16/01/2013 13:21:06 |
Thanks for that they only want £30 for solid steel (per 12" would bright drawn be ok? what would the tolerance be on diameter? any body got any idea where to get some cheaper ( scrap) from? |
David Colwill | 16/01/2013 13:22:51 |
782 forum posts 40 photos | You could try searching "seemless hydraulic tube" and see if you can find someone near you. Dave |
jason udall | 16/01/2013 13:30:41 |
2032 forum posts 41 photos | Schaffold tube? and bushes? |
Phil H 1 | 16/01/2013 15:03:32 |
128 forum posts 46 photos | Ian, Just out of interest - what happened to the orginal. If it is just rust? You might be surprised how well you can recover it. I had to do a lot of work to retrieve my drilling machine and lathe cabinet. PhilH |
Old Elan | 16/01/2013 15:05:10 |
![]() 92 forum posts 34 photos | Ian Have you tried these guys? http://www.machinespares.net/document-library/select-machine-type.php?brand_id=1 They do Startrite spares. Although they have no 'to buy' on the column they may be able to source one for you. Probably not cheap either, though.... |
Ian Parkin | 16/01/2013 16:07:23 |
![]() 1174 forum posts 303 photos | I bought the machine and someone had modified it to a large throat by chopping the column and extending the head out by 24" or so Ive welded it back together but would really like a longer column a s the startrite has a tall base casting and the head has a 2 speed epicyclic gearbox on it as well so room under the chuck is limited
I'll have to trawl the scrap yards round sheffield for a length...the reason or my post was what sort of steel finish do I need to allow the table to move and clamp well......is bright drawn solid OK or is seamless tube OK or does every type need to be ground to 2 3/4 " |
Ziggar | 16/01/2013 18:54:46 |
![]() 115 forum posts 1 photos |
Posted by jason udall on 16/01/2013 13:30:41:
Schaffold tube? and bushes? got to agree with this find some scaffolders iin the area and give them a couple of quid for a length appropriate to your needs
then bush it up to your hearts content most scaffold tubes are 47mm and galvonised
Edited By Ziggar on 16/01/2013 18:55:33 |
David Jupp | 16/01/2013 19:27:07 |
978 forum posts 26 photos | There will be a HUGE difference in stiffness between scaffold tube and 2 3/4" steel tube (especially if you get ally scaffold tube). They didn't use a column of that diameter originally just for fun. |
jason udall | 16/01/2013 23:57:04 |
Posted by David Jupp on 16/01/2013 19:27:07:
There will be a HUGE difference in stiffness between scaffold tube and 2 3/4" steel tube (especially if you get ally scaffold tube). They didn't use a column of that diameter originally just for fun. Good point not least with 70 mm solid vs 47 mm od tube... But would it be stiff ENOUGH?... while we think about that. What would be the consequence of a longer pillar (say double) of the original section be ,to the machines STIFFNESS? |
JohnF | 17/01/2013 00:46:28 |
![]() 1243 forum posts 202 photos | Try a supplier of hydraulic ram material or maybe look for a scrap one, it is chrome plated and very accurate for size. Don't worry about cutting through the chrome you can nick it with a grinder then it will cut with a saw. |
Lathejack | 17/01/2013 01:42:21 |
339 forum posts 337 photos | Hello Ian Bright drawn bar will be fine if you can get it at the right price. It is formed straight and round but the surface finish can vary between batches. It is also usually a few thou or more undersize, but this can also vary. We use bright drawn bar at work and i have once had to use undersize 70 mm bar where 2 3/4 was needed as it was a better fit than the undersize 2 3/4 bar we had. If you wish i can ask them to give me a price for the length you want, i don't live very far from Sheffield. Seam welded steel tube isn't always formed very round, at least not for a good reliable fit in the bore of your drill head and table casting, with or without a bush. Scaffold tube to me just seems too rough and flimsy as a replacement. You might find the table and head being pushed away from each other as the column flexes when using the larger drills that your backgeared drill head can manage. If you are not careful you might just end up with a rubbish drill. I have an Elliot Progress 2G backgeared pillar drill that uses a solid ground steel column of similar diameter to yours, as standard, sat on a tall square cast iron column. I have often thought about using bright drawn bar of the same overall length so that the table can be lowered further to gain more room under the head. I will also have a look and see if we have an old hydraulic ram, as JohnF suggests, lying about. All the best
Edited By Lathejack on 17/01/2013 01:49:15 |
David Littlewood | 17/01/2013 01:42:23 |
533 forum posts | Jason, The deflection of a solid round beam fixed at one end and loaded at the other is proportional to L^3, so doubling its length will increase the deflection by a factor of 8. The formula is Y = 64*F*L^3/(3*pi*D^4) where Y is deflection, F is applied force, L is length and D is diameter. For a hollow round beam, replace D^4 with (D^4 - d^4) where D is outside diameter and d is inside diameter. The formula is different for other cross sections; a Google search should lead to the answer for anyone interested. Incidentally, this shows why (a) stub length drills are so much stiffer than standard length ones, and (b) it's always worth swapping your small boring tool for one of even slightly greater diameter as soon as it will fit the hole. David Edited By David Littlewood on 17/01/2013 01:46:09 |
Ian S C | 17/01/2013 10:43:52 |
![]() 7468 forum posts 230 photos | If you get tube I think you should get at least twice as thick as the 4 mm you suggest, particulary if you are going to extend the length, you want ridgidity, and minimum vibration. I,d be looking for old hydraulic cylinder, or ram of suitable size, with any luck the ram might be straight, If its over size, you might need to borrow a bigger lathe. Ian S C |
Ian Parkin | 17/01/2013 11:01:30 |
![]() 1174 forum posts 303 photos | Thanks for all your replies I would not consider using scaffold tube far too flimsy and rough surface finish to take the table and be able to move it I was only wanting an increase in length of about 6-12 inches over what i have available now Lathejack if you do find an old ram I look forward to hearing from you
Ian |
Gordon W | 17/01/2013 12:18:32 |
2011 forum posts | If you do find a piece of tube with the correct outside dia. but thin wall ,it would be worth filling it with concrete, maybe with a wire or two for added strength. |
Peter G. Shaw | 17/01/2013 13:43:59 |
![]() 1531 forum posts 44 photos | Alex Weiss in ME 07 Apr 1995 page 434 extended a NuTool DIY13 by 100mm/4inch using a piece of scaffold tube. I have used his idea on a NuTool CH10 but had to use a solid extension piece due to the difference in column size. Regards, Peter G. Shaw
Michael Cox 1 | 17/01/2013 13:54:24 |
555 forum posts 27 photos | I have extended my pillar drill by 150 mm, see **LINK** Mike |
