Here is a list of all the postings Ziggar has made in our forums. Click on a thread name to jump to the thread.
Thread: blackgates |
04/01/2015 15:04:30 |
just out of curiosity, also checked using Safari and Torch. Both work fine in viewing online using inbuilt pdf readers and downloading
Z
Edited By Ziggar on 04/01/2015 15:04:38 |
04/01/2015 14:32:00 |
its you. it works fine for me viewing online and downloading the file using my 2010 iMac 27" using Fireofx as my main browser
Z
Edited By Ziggar on 04/01/2015 14:32:08 |
Thread: Myford 3 phase motor upgrade |
02/10/2014 01:05:58 |
i bought my belts from here one at a time [not rich enough to do both at the same time] i got the Fenner easy fit type and ive had no problems at all since changing them
Z
Edited By Ziggar on 02/10/2014 01:06:10 |
01/10/2014 23:17:35 |
no experience of three phase but i also had severe vibration when using the highest speeds on my S7.
z
Edited By Ziggar on 01/10/2014 23:18:14 |
Thread: mill motor direction. |
23/09/2014 12:50:39 |
i used a simple DPDT switch on my WM14 using this wiring diagram
doesnt take long to fix up
Z
Edited By Ziggar on 23/09/2014 12:52:15 |
Thread: lever action chuck ? |
29/08/2014 13:59:20 |
why has the photo gone???????
Z
Edited By Ziggar on 29/08/2014 13:59:31 |
Thread: warco 6x4 band saw Blades |
25/08/2014 15:32:44 |
Z
Edited By Ziggar on 25/08/2014 15:33:22 |
Thread: Myford Super 7 - Adding Power Cross Feed |
06/02/2014 23:09:53 |
theres one on ebay for sale
http://tinyurl.com/nsow87z
Z
Edited By Ziggar on 06/02/2014 23:10:01 |
Thread: Faceplate was the cause |
03/02/2014 14:04:05 |
OK so your on about a chuck backplate - NOT a faceplate.
Z
Edited By Ziggar on 03/02/2014 14:04:14 |
03/02/2014 00:19:32 |
whether the faceplate is out of true or not, surely you use a DTI or something similar to center work pieces so that they run true ? can you not simply turn the faceplate so that it does run true ? from what ive learnt over the small amount of time ive put in ive learnt that you dont rely on chucks or faceplates to ever be true to your spindle unless you have worked them to be so
Z
Edited By Ziggar on 03/02/2014 00:20:04 |
Thread: Lost thread? |
31/01/2014 20:48:13 |
Edited By Ziggar on 31/01/2014 20:51:09 |
Thread: Myford Speed 10 Headstock Damage Control |
26/01/2014 19:51:25 |
when i had my ML10 it was at least 3 months before i realised that the headstock holding bolts were actually loose. i discovered this one day when trying to drill something with the drill in the tailstock and pushing into the chuck held part, the actual headstock casting slid backwards against the force of the drill in the tailstock being pushed forward. I then had to take the time to retighten the bolts holding the headstock in place and hope that they were tightened correctly and with enough torque . could this perhaps be something to do with your problem? one of the headstock holding clamps being loose allowing the headstock to twist a little, giving you an increased runout ? something to check maybe
Z
Thread: Carbide Parting inserts |
25/01/2014 07:58:04 |
perhaps you simply need to learn how to part off with your lathe its not as simple as it looks, although it isnt rocket science either, just needs to be done right you seem to be blaming the supplier for what seems to be your fault, probably being too aggresive with tthe tool learn to part off properly - or at least better, and the inserts are a great way of doing it have a look on youtube for examples of how to do it
Thread: Virus on this website? |
10/01/2014 17:15:00 |
it is obviously an incorrect url to an intended ad for this website simply typing in the ip address of the url takes you to http://www.adbutler.com/ where you can draw your own conclusions i will once again suggest that adblock plus is installed in all browsers to stop these crappy ads appearing |
Thread: Aldi this Thursday 9th jan |
06/01/2014 19:16:31 |
and lidl
Thread: Stuck clutch - Mk2 Super 7 |
30/12/2013 20:57:41 |
i think the clutch has to be engaged when making the adjustment - so that is the clutch lever towards the left - in towards the clutch mechanism i think .................. try it
Z
Thread: Poly V Belt Conversion |
16/12/2013 18:12:42 |
unfortunately i only have the one lathe available [the S7] so wouldn't be able to do this conversion it would be a nice touch if hemingways were to offer a pre machined pulley if wanted/needed perhaps something for them to think about ?
Z
Edited By Ziggar on 16/12/2013 18:13:43 |
16/12/2013 11:12:09 |
thanks for that
i always thought that the catalogues would simply reflect the website contents seems i was wrong off to hemingways site i go
Z
16/12/2013 11:04:01 |
do you have a link to the kit you are referring to because all i can find is the kit for the main 4 step pulley arrangement between the countershaft and the mandrel
Thanks
Z
13/12/2013 19:47:10 |
i didnt realise that the motor pulley was part of the deal, nor does it say anything about it on the hemingways website. unless you mean the countershaft pulley. either way, im looking forward to regular updates from you on this. lots of photos and updates as you go along good luck with it
Z
