KWIL | 31/10/2012 11:30:41 |
3681 forum posts 70 photos | Gray, It all boils down to, you know what you are doing and can, they did not have a clue and did not know it! K Edited By KWIL on 31/10/2012 11:31:21 |
Stub Mandrel | 02/11/2012 21:43:15 |
![]() 4318 forum posts 291 photos 1 articles | Hi Gray, Why not convert to belt drive? Neil |
Michael Cox 1 | 03/11/2012 11:45:55 |
555 forum posts 27 photos | Hi Gray, I have done a belt drive mod and a power feed on my X1, see I am sure you will make much better mods than I did but it is always good to see how others achieve a result. Kind regards Mike |
Pat Bravery | 03/11/2012 11:52:21 |
![]() 96 forum posts 24 photos | Hi, Your X1 is the same as my Clarke CMD10 and the gears also failed on mine. When I looked at it I found that the 4mm key was too short and only engaged about half of the keyway slot this caused undue strain in driving the gear and stripped the keyway. I replaced the gears from Arc and fitted a longer 4mm key and it has been fine since. |
Gray62 | 10/04/2013 14:47:24 |
1058 forum posts 16 photos | Gray, As always an over engineered but perfectly excecuted set of modifications. Over engineering as you is never a bad thing as you rarely need to revisit. The quality of your work never ceases to impress me. Looking forward to seeing how you approach the belt drive mod. I have an X2 clone (of mitsubishi origin) which shed its plastic change gears at the first sign of a light cut. I did a quick and VERY dirty belt drive mod to get it up and running, then progressed very quickly to an Ajax AJT4 so the x2 sits lonely in the corner of the workshop and is rarely if ever used. One day it will get a cnc conversion and a rebuilt belt drive (once I find a suitable bucket of inspiration) These little machines are ok as they go but benefit from a little TLC Graeme |
Tony Pratt 1 | 10/04/2013 17:17:50 |
2319 forum posts 13 photos | Graeme, 'over engineered' how so? Tony |
Gray62 | 10/04/2013 18:21:44 |
1058 forum posts 16 photos | Tony, This was not meant as any form of criticism, merely an observation of Grays excellent perception of engineering and making things to last. G |
Stub Mandrel | 10/04/2013 19:59:20 |
![]() 4318 forum posts 291 photos 1 articles | Another very lovely job; there is a real aesthetic sense there, a lttle more than form follows function. I was not overly keen to use the machine due to having to do mental arithmetic just to convert the numbers on the existing dial to read Millimetres, (2mm pitch feedscrew and dial graduated 0 to 80).
My X2 has 1.5mm pitch leadscrews with dials graduated 0 to 75. i plan to replace them with 0-60 so I don't have to do mental maths either Funny old world! Neil |
Ady1 | 11/04/2013 00:43:07 |
![]() 6137 forum posts 893 photos | Hi Gray, Why not convert to belt drive? ---- Now there's a challenge... not really a challenge... a mission Make it easier for future muppets
he-he...looks like you're not as obsolete as you hoped...
live long and prosper buddy
ady
btw I have yet another metric threads on an imperial lathes system to throw out there its based upon the interruptor gear used in ww1 machine guns which fired through propellors (was reading about it on wiki and thought...uhh... hang on a minit...) adyedit: miles simpler than my digital system
been drinking tonite...
damn.. being alive is so... WONDERFUL
Edited By Ady1 on 11/04/2013 01:15:01 |
Ady1 | 11/04/2013 01:54:38 |
![]() 6137 forum posts 893 photos | Heck, lets get it out there girls, before someone claims it as their own What revolves constantly, like a propellor, with one way in and out? A leadscrew clutch da-da-da-da-da da-da-da (or duh-duh-duh-duh-duh... lol) What revolves non-constantly in time with the leadscrew clutch? The headstock !!! So if you have a locking leadscrew AND a headstock collar CONNECTED to that leadscrew pull-in-bar it stands to reason that there's only one position you can pull that leadscrew into position
The correct position
A double interruptor gear
da-da-da----da-da---da----da-da-----da-da-da
simples ! |
Ady1 | 11/04/2013 02:07:27 |
![]() 6137 forum posts 893 photos | Your search - "double interruptor gear" - did not match any documents. It's a bit disconcerting Interruptor gear was about 100 years ago and 100 years later double interruptor gear still does not exist ?
Maths has advanced hugely in 100 years, producing unlimited interruptor gearing |
Ady1 | 11/04/2013 02:27:52 |
![]() 6137 forum posts 893 photos | It's got sod -all to do with "me" We invented the industrial revolution we invented the jet engine and patented it... and didn't have 30 quid to maintain the patent... we invent a wooden aeroplane like the mosquito and Goering watches them buzz all over occupied Europe
...it's definitely a Brit thing |
Steamer1915 | 11/04/2013 08:15:08 |
![]() 171 forum posts 42 photos |
Head a bit sore this morning is it? Steve. Edited By Steamer1915 on 11/04/2013 08:29:15 |
Stub Mandrel | 11/04/2013 11:27:29 |
![]() 4318 forum posts 291 photos 1 articles | Hi Gray, It's definitely 1.5mm pitch on the X2. The dials have 75 graduations at 0.02mm - and they must be right as my gears come out with the correct depth teeth! Remember the mini-lathes have fine-pitch leadscrews as well, 1/16" on the imperial ones. Xan you confirm if the metric ones are 2mm or 1.5mm - from memeory I think it's the former. I hope Ady can find the paracetamol this morning... Neil |
Ian P | 11/04/2013 12:56:16 |
![]() 2747 forum posts 123 photos | I have a Clarke CMD10 and I am sure that it has 1.5mm pitch leadscrews (definitely so on the Z anyway) Its not accessible at the moment but it has a silly number of graduations on the dials but with DRO fitted its irrelevant.
Ian P
Thor 🇳🇴 | 01/04/2014 16:53:29 |
![]() 1766 forum posts 46 photos | Hi Gray, that's a neat power feed. I assume there's a worm gear inside the aluminium housing? And a way to disconnect if you want manual feed? Thor |
Michael Cox 1 | 01/04/2014 18:22:17 |
555 forum posts 27 photos | Hi Graham, I really like your power feed but what attracted my eye was that beautiful little vice mounted on the table. Is that a commercial item or something you have built yourself? If the latter do you have ant drawings? Mike |
Russell Eberhardt | 01/04/2014 20:20:16 |
![]() 2785 forum posts 87 photos | Gray, That power feed looks neat. Any chance of a look inside? Russell |
Martin Cottrell | 01/04/2014 21:19:36 |
297 forum posts 18 photos | Posted by Graham Meek on 01/04/2014 19:05:28:
Hi Michael, The vice is something that I designed specifically for this mill, the base was made from a piece of Cast Iron continually cast section, the moving jaw is Mild steel as is the vice screw bearing bracket. The Jaws are Ground Flat stock, or Gauge Plate, and the Vice Screw is made from EN 8 with a 2 mm pitch Trapezoidal thread. Un-like a convention vice this design is such that it pulls the work down into the vice, it also ensures that there is more contact between the milling machine cross-slide slideways, (less overhang), for the majority of work. There are some drawings but currently they need tidying up to get them up to date, when I originally designed the vice I had intended to write an article on the build but now I am not so sure. Gray, Hi Gray, I'm sure a construction article on your vice would be well appreciated by many readers. I for one could learn a great deal from the techniques you've used to get such a nice finish on the parts even if I didn't have an immediate need to build the vice. Likewise your power feed would be of interest to many mill owners, myself included! Regards, Martin. |
Mike Clarke | 02/04/2014 10:37:00 |
![]() 95 forum posts 2 photos | Posted by Michael Cox 1 on 01/04/2014 18:22:17:
Hi - it, and the other items, sure are beautifully made. If you want something similar that's commercially available, then you may be interested in the 60mm machine vice available from Pro Machine Tools (I bought one for my Emco mill several years ago and was always very pleased with it). It is very similar in design to Gray's. Regards, Mike. |
