Member postings for Pat Bravery
Here is a list of all the postings Pat Bravery has made in our forums. Click on a thread name to jump to the thread.
Thread: Brush motor repair
14/06/2020 12:01:12
In the UK a new motor for a DC14 for £18 or less, are they much more in NZ? Regards Pat
Thread: Minilathe/Mill motors
28/03/2020 12:58:34
I think that you will find that the motors are 180v DC, I stand to be corrected though. The motors are the same but the boards are different to accommodate the different voltage supplies. Regards Pat
Edited By Pat Bravery on 28/03/2020 13:00:19
Thread: ME in deepest Norfolk
19/03/2020 07:41:32
Hi Shaun, Where in Norfolk are you? I am in the NR29 area and always interested in meeting like minded model engineers. Regards Pat
Thread: Bandsaw woes.
19/12/2019 05:32:34
I believe that you are picking up small bits of aluminium in the teeth of the blade causing the problem, when the clunking starts stop the saw and look closely at the teeth and you will see chips of ally stuck there. I had the same experience and once you have cleared the teeth you are back to normal. Regards Pat
Thread: Hi from darkest Norfolk
08/12/2019 21:15:30
Hi Derek,What part of Norfolk? I live in the NR29 area. Regards Pat
Thread: Aldi Metal Bandsaw
18/10/2019 20:35:54
Hi Bill, I just printed off the email receipt and took it to my local Aldi where they issued the refund without any problem at all, it appeared in my account the next day. Regards Pat
18/10/2019 05:59:32
Did you read the ‘destruction’ manual? If it says cut dry it probably means cut dry.smiley
At the risk of making myself look stupid, where in the instructions does it say to use the saw dry? I have read it a few times and I can't see it but then I am getting on a bit. Regards Pat
17/10/2019 11:12:02
Hi, I have dug out the manual and I can't see any mention of the use of cutting oil, I always have used a lubricant when doing any cutting on machinery and surely that is standard workshop practice. Is it a normal practice to cut dry on bandsaws? Regards Pat
16/10/2019 17:23:45
I have had to return my Aldi bandsaw today as it kept throwing the saw blade, I checked it out and the rubber tyres on the drive wheels had started to disintegrate. It was probably caused by using thin oil as a lubricant when making cuts, has anyone else experienced this? I have always used this method so I will try using the saw dry when the new one arrives. I have to say that Aldi were very good and the refund was no problem at all. Regards Pat
26/09/2019 17:17:07
I bought one last year and I have found it very good. I had to do some minor tweeks and now can cut very thin slices of steel. There are a few comments about the vice not holding tightly enough, I have found my one to be fine and it will cut through 127mm which is about 5 inches. Regards Pat
Thread: Holbrook Lathe Information Please
13/08/2019 13:38:51
holbrook lathe2.jpgI am trying to get information on a Holbrook lathe, on the brass speed data plate is Model SC2, I can find no reference to that model on either the Holbrook website or 'lathes.uk' site. The lathe is a gap bed type and I am afraid that the photo's are not the best in the world but hopefully someone might recognise it. Thanks for looking, Patholbrook lathe1.jpg
Thread: Chester Machine Tools Forum
16/07/2019 06:58:13
Hi John, I contacted Chester Tools some time ago about the missing forum and was told that they no longer support it. I did contribute some mods regarding the Chester 16v mill to the forum so if I can be of any help then feel free to use the private message facility. My mods concerned moving the up & down handle from the vertical to horizontal and making a fine quill adjuster and fitting a motor to the longitude axis, I also fitted a cooling fan to the motor. Hope that this helps, regards Pat
Thread: Mystery Bamford engine
26/06/2019 18:43:22
I have removed the capacitor so that I could match it up but I have now decided to get the CO1 from Brightspark which seems to be the best way forward. The magnet is firmly clamped on my metal top bench and I have cleaned everything ready for assembly. Thanks all for your help and I will post the results of my labours good or bad in a few weeks. Regards Pat
26/06/2019 17:05:42
I will probably fit the later type of condenser either a CO1 or CO2 which fit on the points plate depending on the rotation which I need to work out. The internals came apart fairly easily and it has been a very interesting journey. Thank you so much for all of your help. Best regards Pat
26/06/2019 11:23:50
Following on I have just found the Brightspark page which shows how to do the job chapter and verse, I will try to digest it and report back on the results. Thank you all for your help and I do feel that I have taken up a disproportionate amount of your good nature. Best regards Pat
26/06/2019 11:15:05
img_0284.jpgThanks for all the replies. I have got the armature out and still can't see an obvious capacitor, I have taken photo's and the first one shows a small brown cylindrical object with a wire from the winding going into it, if it is I can't see how to remove it. Help! Regards Pat
25/06/2019 22:30:43
Where would the condenser be? there is not one on the points plate where I would expect to see one, I have not completely stripped it down. I am on a big learning curve here. Thanks for everything, I will have another look tomorrow. Regards Pat
25/06/2019 20:35:44
Thank you for that information, there must be a short elsewhere in the points. I am recalling my Morris minor days when the two sides of the points were insulated from each other when the points opened to cause the coil to energise, I am assuming that it is the same with a magneto. Regards Pat
25/06/2019 20:16:08
I have just had another look and it seems that the long centre shouldered bolt that holds the points to the shaft is lacking an insulator. I will see if I can locate one or even make one. Regards Patimg_0280.jpg
25/06/2019 19:54:36
Hi Martin, Thanks for your reply, I did a continuity test across the points and there is still a circuit when the points are parted so there appears to be an insulation fault there. I have not looked beyond the distributor cap and points yet but there does not seem to be a condenser fitted anywhere near the points. I think that the reality of it is that it will wind up as a static display but I would like to get it running. Regards Pat
