John Stevenson | 10/10/2012 09:20:45 |
![]() 5068 forum posts 3 photos | Probably the steam engines as with it we had the start of the industrial revolution bringing on more discoveries including the tractor.
Previous to the tractor we had plowing engines.
Howver a good post Grey as we all have our own interpretation of what is the best invention, we will leave it up to Ady to re-invent the wheel |
Eric Cox | 10/10/2012 09:21:12 |
![]() 557 forum posts 38 photos | It has to be the clock It regulated the working day, made accurate navigation possible and thus opened up trade routes. It syncronised the railways. The list goes on had I more time to add to it. |
Paul Lousick | 10/10/2012 09:24:05 |
2276 forum posts 801 photos | How about a lathe. A machine that can repair itself. Without it you could not make a tractor. |
blowlamp | 10/10/2012 09:25:05 |
![]() 1885 forum posts 111 photos | The lathe, as it enabled all the above things to happen. Martin.
EDIT: Paul. you beat me to it Edited By blowlamp on 10/10/2012 09:26:05 |
DerryUK | 10/10/2012 09:26:28 |
125 forum posts | Internal combustion engine. |
Niloch | 10/10/2012 09:38:06 |
371 forum posts | The WHEEL (and its axle). NO CONTEST. (Shouting intended!) |
Michael Gilligan | 10/10/2012 09:47:54 |
![]() 23121 forum posts 1360 photos | An excellent thread, Gray I will sponsor Archimedes' Screw Originally devised as a means for lifting water, it is now being used "in reverse" as the Turbine for small scale Electricity Generation. MichaelG. |
Mike Poole | 10/10/2012 10:01:52 |
![]() 3676 forum posts 82 photos | The lathe gets my vote, it is the mother of all machine tools and can be powered by a man,water, steam or electricity or any other power source you can think of. Mike |
Boiler Bri | 10/10/2012 10:11:40 |
![]() 856 forum posts 212 photos | Hand tools as none of the above would have been possible without them.
Boiler |
Eric Cox | 10/10/2012 10:27:05 |
![]() 557 forum posts 38 photos | Sorry Boiler Bri but hand tools are not mechanical. |
Terryd | 10/10/2012 11:00:11 |
![]() 1946 forum posts 179 photos |
Posted by Eric Cox on 10/10/2012 10:27:05:
Sorry Boiler Bri but hand tools are not mechanical. Hi Eric, Hand tools may not be part of a machine, but they can be described as mechanical, Quote - Dictionary.com: "6. pertaining to the design, use, understanding, etc., of tools and machinery: the mechanical trades; mechanical ability." There is a great little book about the importance and development of the screwdriver and screw - I forget it's title just now but will look it out. The screw in all it's forms is generally regarded as a mechanical device. Perhaps the most important mechanical device is the screw generating machine to generate the first accurate screw thread which led to easy assembly and disassambly of other mechanical devices and led to the concept of interchangeability and hence volume production methods. The screw also allowed the development of accurate end delicate instruments and clocks (previously rather crude blacksmith made devices to regulate the religious day) which allowed finer and finer engineering to be undertaken. Best regards Terry Found it! the book is called One Good Turn: a Natural History of the Screwdriver and the Screw, by Witold Rybczynski
Edited By Terryd on 10/10/2012 11:07:58 |
Michael Gilligan | 10/10/2012 11:04:21 |
Posted by Terryd on 10/10/2012 11:00:11:
Perhaps the most important mechanical device is the screw generating machine to generate the first accurate screw thread which led to easy assembly and disassambly of other mechanical devices and led to the concept of interchangeability and hence volume production methods..
Best regards Terry
Terry, Would you therefore agree regarding Archimedes' Screw ? Everything you mention lies between the two extremes that I highlighted. MichaelG. |
Ian S C | 10/10/2012 11:19:45 |
![]() 7468 forum posts 230 photos | I suppose it's all chicken and egg really, but my vote for a machine would be the lathe, in one form or other, that includes such things as the potters wheel, and the lathe type device used to turn round stone collums of ancient buildings. Ian S C |
Ady1 | 10/10/2012 11:20:15 |
![]() 6137 forum posts 893 photos | we will leave it up to Ady to re-invent the wheel ----
My first thoughts were canned food, antibiotics and clean water.... most valuable mechanical invention made to date What made the steam engine possible? What made large scale metal production possible? The blast furnace, the foundry? But industry A feeds industry B which feeds industry C which makes improvements for Industry A and so on. Synergy. The sum of the parts being greater than the whole
I would go with the steam engine, which was originally rubbish but then someone put tubes into it and its efficiency was massively increased
The Steam engine was the first time a machine could do real useful work anywhere it was needed This resulted in an explosion of output, the industrial revolution |
Bubble | 10/10/2012 11:43:12 |
75 forum posts 6 photos | Hi all Joseph Whitworth's inspired invention of the method of producing a true flat surface plate using three plates scraped to all fit together. Two plates could be flat or spherical, three plates could only be flat. He achieved accuracies of a millionth of an inch in the1840's This invention allowed the production of precision measuring instruments and machine tools from which all else in precision engineering stemmed. Jim |
Ady1 | 10/10/2012 11:49:27 |
![]() 6137 forum posts 893 photos | A steam engine meant you could power an overhead drive to make any machine you want to realise its full potential So a place with 5 painstakingly made hand fettled lathes and planers could suddenly make 5 a month instead of 1 and do this 24/7
Output soared exponentially, the poles melted and all the polar bears drowned |
Eric Cox | 10/10/2012 11:56:40 |
![]() 557 forum posts 38 photos | "Hand tools may not be part of a machine, but they can be described as mechanical" In the context of the question "mechanical" refers to machinery. As for the suggestions of the lathe, try turning without a clock, ie rpm and ft/min plus the time you take. It's definately the clock |
Michael Gilligan | 10/10/2012 12:14:43 |
Posted by Jim Cahill on 10/10/2012 11:43:12:
Jim, A couple of publications that I think you would enjoy:
Trevor Wright | 10/10/2012 12:53:57 |
![]() 139 forum posts 36 photos | Would go for the steam engine, but without the blast furnace there was no quality steel for the boiler, without the lathe the cylinders could not be bored. Without Iron ore and coal in the ground the blast furnace was pointless.....without power the the lathe would not turn..... To me the industrial revolution may not be a machine in itself, but as a whole it happened because of all the above mentioned factors and the world changed for ever.........for good or bad...... Waiting to be shot down........ Trev |
GoCreate | 10/10/2012 13:14:48 |
![]() 387 forum posts 119 photos | The crank shaft, without which your wonderful reciprocating engines would have limited use and the industrial revolution may not have happened. Nigel |
