David G | 28/03/2012 18:28:38 |
![]() 21 forum posts 3 photos | Not strictly a model engineering question but..... I have an instant hot water dispenser in my kitchen and the plastic water dispensing nozzle liner has disintegrated. unsurprisingly a replacement part on its own is not available. I can easily turn up a replacement nozzle out of some brass bar that I have but was wondering whether it would be suitable. The water goes through the nozzle at about 80-90 degrees, I can turn it out of a single piece so there will be no soldering.
As this is used to make tea and coffee I want be sure I'm not going to end growing and extra limb, etc Thanks Dave |
wheeltapper | 28/03/2012 18:45:36 |
![]() 424 forum posts 98 photos | Can't you get hold of a piece of nylon rod? Sounds safer to me. Roy |
Tel | 28/03/2012 19:03:26 |
![]() 157 forum posts 28 photos | I'd use the brass - thousands of water heaters are crammed full of brass fittings. |
Russell Eberhardt | 28/03/2012 20:40:01 |
![]() 2785 forum posts 87 photos | I have a coffee machine in which I have replaced a plastic nozzle with brass and I'm still here - but then when I was young we had lead pipes and they were considered safe. Russell. |
Brian Dickinson | 28/03/2012 21:29:51 |
![]() 62 forum posts 13 photos | Brass will be fine. In time you may get de-zinkification but thats a long way down the road.
Bri |
Stub Mandrel | 28/03/2012 21:58:29 |
![]() 4318 forum posts 291 photos 1 articles | As most taps are made of brass, I'm sure you'll be OK. Neil |
Ady1 | 29/03/2012 00:18:43 |
![]() 6137 forum posts 893 photos | Brass might become a health issue once you reach 175 years of age |
Martin W | 29/03/2012 00:29:05 |
940 forum posts 30 photos |
The bodies of compression fittings and stop cocks etc are all made of brass and approved by water authorities, WRAS approvals, so it's used regularly on potable water supplies and as such shouldn't be a problem. Only thought is do you know what kind of brass you have as some contain lead but even so I don't think you'll come to any harm Cheers
Martin |
Tel | 29/03/2012 03:56:28 |
Posted by Ady1 on 29/03/2012 00:18:43:
Brass might become a health issue once you reach 175 years of age Ya think?????? Now you've got me worried! |
Martin W | 29/03/2012 10:01:28 |
940 forum posts 30 photos | Tel
I will PM you in about 101 years and let you know whether there were any problems in using these materials Martin |
Bazyle | 29/03/2012 10:35:27 |
![]() 6956 forum posts 229 photos | In 175 years someone might ask " The brass nozzle on my Ascot (powered on biogas) has finally corroded away. I have found a bit of 20th century material called plastic for only £25,000, is it safe to use?" Answer " Are you mad? That plasitc stuff is full of horrible chemicals that was in only used for about 50 years before the plastic mines ran dry". |
Clive Hartland | 29/03/2012 14:01:12 |
![]() 2929 forum posts 41 photos | Solve the problem, use a bit of stainless steel.
Clive |
geechr | 29/03/2012 14:56:39 |
4 forum posts | I work in the plumbing trade and we use quite a lot of brass in water fittings. There will be no health risks in using brass in the application you describe. I would not recommend Nylon unless it is grade specifically formulated to work in domestic water systems. Regards Chris Gee |
David G | 29/03/2012 19:53:32 |
![]() 21 forum posts 3 photos | thanks for all the feed back. Brass it is then.
Dave |
simon cochran | 01/04/2012 10:15:38 |
2 forum posts | You say it is an instant hot water dispencer, if so be careful as it may be you are causing a problem by replacing a plastic componant with a metal one. Basically if the water is heated in certain types of "instant" heaters, the water contained is live, and so including a metal part where a plastic part is required may just render yourself or your loved ones liable to shake hands with the national grid. Simon |
wotsit | 01/04/2012 21:28:29 |
188 forum posts 1 photos | I find it very hard to believe that instant water heaters can result in 'live' water - how does this work then? It would be interesting to see the internals of such a heater described. If this is so, then even the original fitting (plastic?) would not reduce the lethal capabilties of such a machine - or do you work for the Health and Safety Alarm and Despondancy Department.
Martin W | 02/04/2012 09:59:59 |
Live Water?? This sounds more like an urban myth than actuality If you have a domestic water heater that delivers LIVE WATER then I suggest you put it in the skip before it kills you!! Cheers Martin |
Ian S C | 02/04/2012 12:03:24 |
![]() 7468 forum posts 230 photos | There is a type of water heater that can cause the "live" water situation, it's illeagal, it can be got round by indirectly heating the water, but even then I don't think its allowed. There are 2 electrodes with a gap, there needs to be a certain amount of impurities in the water for it to work (not distilled). You could try the method (take care)just stick two bare wires in some water, one to phase, and the other to neutral, KEEP your fingers out of the way, switch on the power. This system will only work on an AC current. This experiment is dangerous, don't let the kids do it,(thats when I found out about it). Ian S C ps some early electric jugs used this system. Edited By Ian S C on 02/04/2012 12:04:55 |
geechr | 02/04/2012 14:50:43 |
4 forum posts | It is quite possible and safe and legal to have a "bare wire" or "wire in water" heating elements working at 240V. Dolphin electric showers made over 10 years ago used bare wire heating elements. So do Zip water heaters sold in the UK. Most German intantaneous electric water heaters also use this technolgy. The products are safe because the design makes sure the electrical current, flowing from the bare wire heater to earth, is so low that it is safe. The electrical conductivity of the water coupled with the volume of water between two strategically placed earth contacts at the inlet and outlet water pipes is used to control the current. The plastic outlet of the water heatwer will be downstream of the exit earth and so be safe to replace with brass. |
Steve Withnell | 02/04/2012 19:59:35 |
![]() 858 forum posts 215 photos | It's amazing how a "can I swap a plastic bit for a brass bit" question can produce such a huge amount of collateral learning! |
