Ian S C | 17/03/2012 12:25:18 |
![]() 7468 forum posts 230 photos | Because. Ian S C |
Terryd | 17/03/2012 12:34:55 |
![]() 1946 forum posts 179 photos | Why the Big Bang? Because it did! T |
AndyP | 17/03/2012 15:08:10 |
189 forum posts 30 photos | Google is your friend ! try this |
Paul Boscott | 17/03/2012 15:47:26 |
![]() 99 forum posts 21 photos | May I rephrase the question to its more common form. Why does a steam engine not work.
MichaelR | 17/03/2012 16:47:42 |
![]() 528 forum posts 79 photos | For that matter, Why does a IC engine work when it's trying to blow it'self to bits Mike.
Jeff Dayman | 17/03/2012 17:17:50 |
2356 forum posts 47 photos | "Why does a steam engine work ?" 'cause it has to feed the kids and pay the mortgage? (That's the reason I work....) Cheers JD |
Richard Parsons | 17/03/2012 17:49:56 |
![]() 645 forum posts 33 photos | this is like the old conumdrum 'Why is a mouse when it spins' It is not a question it is a statement which defines a spinning mouse as 'WHY' . I am off to feed the dogs an ger a beer or three Rdgs Dick |
NJH | 17/03/2012 17:57:12 |
![]() 2314 forum posts 139 photos | Richard
No doubt on your return from the "beer or three" you will have an answer to the question - how authorative that may be is questionable! I'm more concerned in the answer to the question " Why will MY ***!!!***!! vacuum engine not work! ( Google didn't help with that one!) Anyone want to make an offer for a carefully and lovingly made doorstop! Regards Norman Edited By NJH on 17/03/2012 18:01:24 |
wheeltapper | 17/03/2012 18:34:01 |
![]() 424 forum posts 98 photos |
I'd like to make an offer but I've got so many doorstops I'm running out of bl**dy doors.
Roy |
Bazyle | 17/03/2012 18:54:57 |
![]() 6956 forum posts 229 photos | Norman. Picture? Published design? Possibilities. Too hot to condense. Too cold and condensation too fast. Not enough volume at TDC for air content of charge. Flame not big enough to supply vapour charge. Which came first the Mule or the Baby Mule? Well it is a simple question. And as you all know the answer why is there a problem with chickens and eggs. |
Speedy Builder5 | 17/03/2012 18:56:42 |
2878 forum posts 248 photos | It could be the reason why windscreen wipers only break down in the rain. I guess your steam engine does not get steam in the right place at the right time. Like most engines - its a matter of timing. |
Stub Mandrel | 17/03/2012 19:27:05 |
![]() 4318 forum posts 291 photos 1 articles | The interesting question is why does a steam engine work so differently on air to steam?
Neil |
Terryd | 17/03/2012 20:26:36 |
Posted by AndyP on 17/03/2012 15:08:10:
Google is your friend ! try this That is HOW not WHY, said he, most mysteriously!! |
Terryd | 17/03/2012 20:27:14 |
Posted by Stub Mandrel on 17/03/2012 19:27:05:
Neil Hystersis T |
Steve Withnell | 17/03/2012 20:50:29 |
![]() 858 forum posts 215 photos | How dare you accuse my steam engine of hysteria when running on air!
Nicholas Farr | 17/03/2012 22:18:45 |
![]() 3988 forum posts 1799 photos | Hi, maybe it is something to do with Newton's Third Law. Regards Nick. |
Robert Dodds | 17/03/2012 22:40:54 |
324 forum posts 63 photos | Hi, As an apprentice I took Heat Engines as part of my HNC. Didn't do particularly well at it but I'll never forget the " Steam Entropy Tables" that we had to resort to to work out the power output from steam engines, turbines etc. Its somthing to do with the energy of the water molecules in addition to the energy from the compressed gas that makes performance on steam so different to performance on compressed air . There's a lot written on Google about Entrpy of Steam and I still can't get my head round it! Bob D
Steamshy | 19/03/2012 20:03:09 |
38 forum posts 2 photos | Hi, Steam engines have to be warmed through properly to run, I`m guessing that as things heat up, so they expand, not all materials or parts are the same thickness either,[ not counting dissimanal metals which heat at different rates]. So maybe friction may have a bearing on why a steam engine wont run on steam but air it`s ok. Once it runs ok on steam it usually does after quite well. I know on Large turbines prior to running there is a steam chest warming sequence, which allows the control pistons and large mass of metal in the steam chest to expand correctly, Andy |
Stub Mandrel | 19/03/2012 21:07:21 |
![]() 4318 forum posts 291 photos 1 articles | The heat difference is the key. A steam engine is a heat engine. It gains most of its power from the steam giving up its heat to do work in expanding, something that is further improved by superheat. Air going through a steam engine has far less energy stored in it and can do far less work for the same pressure. A steam engine can be made more efficient by adding a cold condenser to create an exhaust vacuum. If you made an air engine create its own vacuum, it would take more energy than you got out, unless it was so cold it liquified the air. It'sa fascinating subject that I'm only beginning to understand - the likes of Watt, Woolf etc. were very clever folk. Neil |
Ian S C | 20/03/2012 11:27:21 |
![]() 7468 forum posts 230 photos | Running a steam engine on air, could the exhaust be connected to the suction side of the compressor as well as the pressure side to the intake, would that have a similar effect to a condenser on a steam opperated engine? Ian S C |
