Here is a list of all the postings Robert Dodds has made in our forums. Click on a thread name to jump to the thread.
Thread: Reliance drill grinding attachment. |
11/04/2023 20:42:52 |
Steve, May I reinforce Fowlers Fury's comment re drill point overhang beyond the end of the trough. This should be between 2 1/2 and 3 times the drill diameter. More projection give less back clearance on the flute and less projection gives more back clearance. Regards Bob D |
Thread: MEW 319 - Roofing A Shed?????? |
20/08/2022 22:36:09 |
I’m a Tin Roof person but enough of that. Thanks to Gary’s photo of the proprietary meter I had a look at Dakin and Flathers web site which contains a table of recommended tensions for different uses of their blades, expressed in both kPa and psi, the latter ranging from 15000 to 30000psi depending on usage. E= Stress /Strain From which we get Extension /Original length = Stress/E Would I make one, probably not. For the little bit of use that I put my saw to I’ll carry on Twanging. Regards Bob D |
Thread: FORUM DOWNTIME AND RESULTING ISSUES REPORTING |
20/07/2022 20:06:08 |
Tim, Have you noticed that the Forum is sponsored by "Binders Now Available" and using the Get in Touch link at the bottom of Forum Home gives a 9 till 5 number for Neil Wyatt as an open line to Orpington !! Bob D Edited By JasonB on 20/07/2022 20:22:29 |
Thread: Update on toolpost bolts |
15/07/2022 20:09:15 |
Apologies for a daft question, but have you got a sprocket wheel on the bolt that the toolbox rotates on and that then fits in the recess on the bottom side of your toolbox when its all assembled. If not you won't get a positive index. The plunger on its own wont help much. Regards Bob D Edited By Robert Dodds on 15/07/2022 20:23:06 |
Thread: Nostalgic moment |
25/05/2022 16:58:11 |
This 1935 Ford Greyhound served me well through my apprenticeship from 1954 to 1959. Cost £85 and sold on for £80. We both survived several bumps, rod brakes and all that. It had several engine refurbishments including a broken crank, but as it was 3 bearing, the front half carried on running, no drive to the clutch and flywheel of course and knocking like crazy,. All good fun though. Bob D
Thread: My mobile has "gained" an extra synbol |
25/05/2022 15:35:47 |
I suggest you try and rediscover the "123" number you mentioned. Bob D |
Thread: Removing a retaining washer |
23/05/2022 18:05:21 |
I see Amazon do an assortment box for less than a tenner Regards Bob D |
Thread: Ping - and a screw is lost |
19/04/2022 21:15:09 |
My dear wife is into "beading" and uses a beading mat. Regards Bob D |
Thread: Before calculators |
15/04/2022 20:36:10 |
Hi, "The product of the line segments of two intersecting chords are equal." So in this case 6 x 1 = 2.45 x 2.45 which can be expressed as Sq. root of 6 = 2.45 depending on how accurate you want to measure it. Bob D |
Thread: kerry super 8 problem |
27/03/2022 17:17:28 |
Alan, Silly question but is the spindle rotation correct? Does the drill cut metal/ wood at all. Regards Bob D
Thread: Is this a record fuel price ? |
13/03/2022 18:54:42 |
And who recalls T.V.O. (Tractor vapourising oil) aka paraffin that the Fordson tractor ran on once it was warmed up. Funny old world!!! Bob D |
Thread: Concrete Panel Garage/Workshop |
04/03/2022 19:01:54 |
Michael |
Thread: Diminishing chocolate bar |
04/03/2022 18:09:46 |
Has no one realised that you are being saved from yourselves. Them in charge tell us that all this sweet stuff is bad for our health so we should eat less, hence smaller portions. Bob D |
Thread: hallo from stoke-on-trent |
13/02/2022 12:06:16 |
Brian, Graham, I went to Church this morning and when I got back home my prayer had been answered. Thanks. Bob D |
12/02/2022 16:58:05 |
Graham, What gears have you got? Is there a 70T among st them?. If so you could be in with a chance but as Noel says check Tracy, Standards are but a few quid! Bob D |
Thread: What is this? |
11/02/2022 22:02:31 |
An authoritative explanation of its uses https://www.youtube.com/watch?v=ZaRXvxjUz1Q Bob D |
11/02/2022 21:41:26 |
Graham, Does your lathe bear any resemblance to the blue Viceroy that features towards the bottom of lathes.co.uk entry for Viceroy lathes. One of the pictures of that lathe shows a setting plate that includes 1.75 as one of the pitches that can be set on there Regards Bob D |
Thread: Drain cleaning brushes |
11/02/2022 21:20:21 |
Oh for the days of coal fires and a Flue Brush. Bob D |
11/02/2022 21:09:24 |
A skirmish on Google images suggests this is a fairly common pattern and the profiles are associated with buckles and badges. (not sure exactly how it was applied to them). There are examples of a simple slot version, for Privates, a one hole version attributed to Canadians and even one with a Harrods logo on it presumably for the Doorman and Lift Attendant to use. £6.99 if you want one Bob D |
Thread: That Strange Calculator Again |
15/01/2022 17:59:51 |
Next stop should be The Arithmeum,. Bonn University. It has a museum of mechanical calculators, lots of them are circular and there are 10000 exhibits to check out. Some of the detail is in German so you may need some translation before calculation. https://www.arithmeum.uni-bonn.de/en/arithmeum.html, Bob D |
