Member postings for MichaelR
Here is a list of all the postings MichaelR has made in our forums. Click on a thread name to jump to the thread.
Thread: What defines BILLET …
03/10/2023 08:53:57
And then we have Billet as in temporarily lodged soldiers frown
MichaelR
Nick Clark3 beat me .
Edited By MichaelR on 03/10/2023 09:00:41
Edited By MichaelR on 03/10/2023 09:01:04
Thread: Myford
23/09/2023 20:08:49
I think they are for fixing a Four Post tool Holder Ratchet pawl.
Edited By MichaelR on 23/09/2023 20:19:09
Thread: Help needed - Firing up my grandads steam boiler
17/09/2023 15:27:03
Matt, Your latest picture solves the valve question, it's the main steam control valve for the engine, the tube on top of the valve body looks like it could be for engine lubricating oil as it seems to have a screw cap for filling.
The first picture was a optical elusion that made me think the valve was a blower and fastened to the boiler.
Enjoy your model. Mike.
Edited By MichaelR on 17/09/2023 15:27:58
17/09/2023 10:06:24
Just had another look at the valve near the exhaust it could be a steam feed for the engine or engine exhaust, could do with a picture of that end of boiler for a better look.
Mike.
Edited By MichaelR on 17/09/2023 10:06:56
17/09/2023 09:14:04
Looking at what the engine is driving I would think a working pressure of no more than 60 lbs will be needed, the valve near the exhaust could be a steam blower to create a draught for the burner gases and will only need to be open a crack you should be able to see a upturned pipe in the exhaust flue if it is a blower.
Mike.
Edited By MichaelR on 17/09/2023 09:16:14
Thread: Oiler roller clutch
22/08/2023 19:03:41
See here Link may be what you need.
Thread: Thrust Bearing Blocks
12/08/2023 09:25:53
Angular contact spindle bearings may suit your project. link
Michaelr
Thread: Stephensons valve gear
10/08/2023 09:53:35
Most traction engines (Three Shaft Engines) run link down to save wear and tear on the lifting link pins, on a Four Shaft Engine which the crank shaft runs backwards, in order to get the link down in forward gear the eccentric rods have to be crossed.
Michael
Thread: 1950 Myford
30/07/2023 17:50:18
I remember a new Myford ML7 for sale in our local ironmongers shop in the early 1960s, and it was grey I viewed that lathe with envy can't remember the price but it was out of my pay scale at that time.
MichaelR
Thread: What is it and what is it for
28/07/2023 20:36:38
See here LINK not the one you have but it gives the idea of use.
MichaelR
Edited By MichaelR on 28/07/2023 20:38:24
Thread: Help me identify this 3 1/2 Guage Part Built 4-6-0 Tender Model
27/07/2023 11:23:11
Martin, Have a look at this Model Engineering forum post regarding the Bonds Royal Scot, you may find some help.
Link
Edited By MichaelR on 27/07/2023 11:24:08
Thread: Alyn RLE Last and First
23/07/2023 10:51:42
Jason, Nice to see the RLE castings being available again, the RLE was the first IC engine I made, a ideal engine for the beginner.
Looking forward to your build thread.
MichaelR
Thread: Spiders
19/07/2023 15:40:34
Just make sure your spiders don't make a home on your body as here Link
Thread: Bubbles in the floor - help!
10/07/2023 16:16:24
I think the problem could be the sub floor that the latex has been applied too, something has leached out or still is leaching out to cause the blow holes, all you can do is fill the holes.
MichaelR
Edited By MichaelR on 10/07/2023 16:19:20
Edited By MichaelR on 10/07/2023 16:19:48
Thread: what is this
23/06/2023 19:45:51
Search for Atterton and Ellis, could be a lawn mower cylinder blade grinder Link
Edited By MichaelR on 23/06/2023 19:59:25
Thread: Rolling road construction
11/06/2023 11:18:57
Good pictures of rolling road Link The links not working it should have linked to Station Road Steam.
MichaelR
Edited By MichaelR on 11/06/2023 11:22:37
Thread: Well I never knew that - Cluppert Ring
08/06/2023 09:49:55
Posted by Tim Stevens on 07/06/2023 22:42:28:
No-one has offered answer, so I feel an article comming on ...
Tim, Its all here Link
MichaelR
Thread: My First Steam Layout
03/05/2023 16:10:24
For a small live steam garden railway Gauge 1 are the ideal size IMO, however this Link will take you to a radio controlled 5" gauge Black 5 although much larger than 31/2" gauge it gives a idea what can be done
MichaelR.
Edited By MichaelR on 03/05/2023 16:11:31
Thread: 'Out there' machining techniques.
26/04/2023 15:08:19
Posted by vic newey on 26/04/2023 09:11:53:
please use the link button option, it's on the left of the Youtube button above where you typed this post, it's easy and avoids people having to cut and paste
No need to cut and paste, Highlight the youtube address in the post right click the highlight and you get a drop down list which will have, go to youtube address will be listed and click that, and you will get taken to the you tube video.
Thread: meths feed tube?
24/04/2023 14:59:29
This Link may help, much the same as the info Bazyle posted but with drawings.
