Lidl cast steel vice-16.99
Ady103/02/2012 00:02:16
6137 forum posts
893 photos
Spotted it tonight on their sheet, on offer from today and IF IT IS cast from solid steel then it's a bitofabargain
4 inch capacity
torque: 250 N·m (180 lb·ft);
But did some searching about...if it looks too good to be true etc....
Yet the same thing in Eire is described as "solid cast iron" and so it looks like it could be a misdescription
If I'm in there at the weekend one will be liberated from its box and I'll be tapping it with a little hammer...see if I can get lucky...
Out of interest has anyone bought one of these Lidl ones?
John Baguley03/02/2012 01:06:35
517 forum posts
57 photos
It looks like the same brand as a swivel base one that I bought from Lidl some years ago. I regret buying it. Very poor quality.
Terryd03/02/2012 05:03:08
1946 forum posts
179 photos
Hi Ady1,
It says available from the 6th Feb on the link you posted. That's next Monday, so I think it might be a wasted journey this weekend.
Best regards
Terry
Jeff Dayman03/02/2012 05:04:47
2356 forum posts
47 photos
Unless you are giving a vise a hell of a beating every day, as in an auto garage, even a cheap cast iron vise may be OK for general hand tool use -with a few caveats below.
- The moving jaw must be a decent fit in the stock, with no excess play up down or sideways
-the screw must be decent quality steel, be an acme style thread with lands between the valleys (must not be a regular 60 degree sharp thread) and run smoothly in the nut
-the swivel base must fit decently , not allow any rock, and the screws must lock it securely.
A big list for 16.99 UK pounds, but you never know, you might find a good one.
I wouldn't do any heavy bending or hammering on it though. Probably fine for filing or light drilling.
Note - I have found a couple of top quality ex-industrial vises for that sort of money at estate sales, flea markets etc. though, but it takes time to find a usable good one amongst all the worn out and cheap junk. Wilton and Record are two good makes.
JD
blowlamp03/02/2012 09:19:06
1885 forum posts
111 photos
The electric cable hoist looks like good value for the money.
250kg lifting capacity, swivel arm and 3 year warranty for £59.99
Martin.
Gray6203/02/2012 20:09:10
1058 forum posts
16 photos
Don't trust anything from Lidl. Aldi or any of the cheap s%t sellers.
What they sell are budget items which are aimed at the DIY, not a lot of work, weekend bodger. They are definitely not suitable for even the average home shop model engineer. They lack fit and finish,accuracy and longevity, i.e hit em hard enuf an they WILL break, trust me, I've tested them!
If you want a decent vice, pay the money and get something from a reputable manufacturer that can give provenance to their product and back that up with a guarantee that is truly supportable.
Try taking something back to Lidl or Aldi that costs more than £9.99 and see the hoops you have to jump through to get them to honour their so called guarantee. I will never buy a product from these charlatans again.
Stub Mandrel03/02/2012 20:19:46
4318 forum posts
291 photos
My 4.99 set of three HSS step drills from Aldi have proven excellent. Bought a glue gun there today for £4.99. i don't expect miracles so I'm rarely disappointed.
I smirk again that MY Record No.3 was free from the tip
John Stevenson03/02/2012 20:52:16
5068 forum posts
I have one of the electric cable hoists over the big CNC mill to lift the vises and 4th axis into place. They do go a bit fast so I have mine doubled up to slow it down.
Note it's only 125kg on single lift, 250 on double.
Been an ace piece of gear for what it's used for. Took a set of torque screwdrivers back the other week as the small one was missing out the set, just wanted a new set but as it was the last one they had to refund me and I had no problems.
I do buy odds and ends there but realise that for the money you are buying consumables, sometimes i feel peoples expectations are far higher than their wallets.
John S.
Nicholas Farr03/02/2012 21:51:50
3988 forum posts
1799 photos
Hi, well I bought a set of ratchet spanners comprising of 8, 10, 13, 14 and 17 mm for £12.99, a while before Christmas from Aldi and have been using them frequently most days on an installation job, and they haven't failed on me yet. Paid for themselves I'd say, although the 13 mm one fell outa me overall pocket straight down into a wall cavity, but I found a replacement Silverline one at Ally Pally for £3.50, and that seems just as good.
Regards Nick.
Wolfie03/02/2012 21:57:09
502 forum posts
Lidl had a plastic compartment box going a couple of weeks back, Brilliant for nuts bolts etc. Under 3 quid too and quite substantial. I bought half a dozen.
jason udall03/02/2012 22:00:35
2032 forum posts
41 photos
"pay peanuts"
But then sometimes we want peanuts.
Caveat emputure
I think.
Gray6203/02/2012 22:18:16
1058 forum posts
16 photos
Can't agree more, just don't expect more than you are paying for.
I bought a set of core drills, for next to nothing, used them, did the job, threw them away, but they paid for themselves in the job, ( and I still have the aluminium box left over)
The point I was trying to make, and may not have, is that whatever these stores sell are not top quality and that we should not have great expectations of them. Some will exceed those expectations, some will not.
There are bargains to be had however, they should never be considered as 'engineering' grade tools etc.
I have a hoist similar to that which John alludes to and probably from a similar source, cheap and functional, but still of dubious quality. If put to the test ( i.e the load limit) the motor gets hot very quickly, I'm not sure how they work out the rating on these items but I'm sure they are over-rated, if you know what I am getting at
jason udall03/02/2012 22:28:03
2032 forum posts
41 photos
sometimes what you buy is better and cheaper than engineering supplies...and at least available over counter.... Even as starting place for adaption/modification cheaper than kit castings or even metal stock..
alan frost04/02/2012 00:28:43
137 forum posts
For God's sake ,Coalburner,grant us all a little intelligence. Aldi/Lidl prices are about 20-30% of top quality, maybe less. None of us are surely stupid enough to need it pointig out that at these prices the goods are not top quality.
What they are is quite good , usually sufficient quality, often better than goods costing 100% more, sometimes better than goods costing several 100 % more. personally I have found for the only two items I have ever bought that were faulty (among many items over the years.) I did n't have to jump through any hoops to get a replacement, both items were replaced by new and satisfactory items ,without question, very rapidly. They took my word for it and never even bothered with picking up the faulty item. I have rarely had this service bettered even when I've paid for top quality. Good job I\m honest !! Well almost.
John Stevenson04/02/2012 00:49:42
5068 forum posts
I am afraid the world is treating everything as consumable items.
At one time I only bought branded items with a decent warranty. Typical of this were 4 1/2" angle grinders, I use these commercially and they have a very hard life.
At one time I bought Bosch at £85 a pop then one day realised that they last 366 days before going bang - no warranty.
So now I buy 5 or 6 at a time for usually £9.99 when on offer, most last about 7 or 8 months before I manage to kill them, don't bother claiming warranty, just bin it, it's done it's job.
Still don't pay out over a year what one Bosch one used to cost.
Same with printers, these are sold with 30% filled cartridges and they make their money on new consumables. So now just buy one, run it until it runs out of ink then bin it.
Anyone want a Konika colour laser 14 months old, £245 of brand new cartridges fitted but the printer has died. Bought a new one , not Konica for £99
John S.
Russell Eberhardt04/02/2012 10:15:21
2785 forum posts
87 photos
Posted by John Stevenson on 04/02/2012 00:49:42:
..or just refill the cartridges with ink or toner yourself. It's a bit meesy but much cheaper.
Russell.
John Stevenson04/02/2012 10:32:15
5068 forum posts
The newer ones have chips fitted that monitor the ink / toner left. When it says empty just filling it will also still say empty.
You have to replace the chip.
Not cheap and one set we bought wouldn't work and the seller just ignored us. So from now on play them at their own game. They sell the printer at a vastly discounted rate to get you on the consumable merry go round.
Takes a totally different mind frame but you have to accept you are buying a consumable and when it's finished just bin it.
John S.
Steve Garnett04/02/2012 10:53:29
837 forum posts
27 photos
Posted by John Stevenson on 04/02/2012 10:32:15:
Well, since these chips are generally flash-based, they are resettable. Do a google search using the term 'toner chip resetter' and be prepared to be pleasantly surprised. The reason for a search, rather than a direct link, is because there are different ones for different cartridges. Have I tried it? Yes. Does it work? A treat on the Epson ones we 'treated'.
John Stevenson04/02/2012 11:34:15
5068 forum posts
Epson must be different to Konica then, A search found loads of pages for the presetters but only a few with prices.
best price was $580 up to $800, buy a lot of printers for that.!!
Stub Mandrel04/02/2012 12:26:51
4318 forum posts
291 photos
I bought my wife a Samsung laser from Morgan computers for about £70. That was several years ago we are onthe third cartridge and it gets almost daily, but light, use. Third party cartridges are £40.
So I recommend samsung!
The Brother professional 3-in-1 inkjet before that had three new print heads under an extended warranty. According to the net the own brand ink corroded the heads - apparently if we had used cheap ink it would be still going strong. Brother wouldn't admit this, but extended the warranty period - theye even sent an engineer round twice which must have cost as much as teh machine was worth. Got some nice PGMS bars out of it....
