Achieving a long-term quality finish on brass?
S K24/08/2023 21:43:03
288 forum posts
42 photos
Hello forum members,
What are your favorite methods of preparing (sanding, etc.) and finishing brass for a long-lasting bright finish without tarnishing and staining?
Thank you.
Pete Rimmer24/08/2023 21:46:14
1486 forum posts
105 photos
Paint it
John Haine24/08/2023 21:48:04
5563 forum posts
322 photos
Renaissance Wax
Paul Lousick24/08/2023 22:41:15
2276 forum posts
801 photos
One of the main problems with steam engines is keeping the brass shiny. I have found that elbow grease is the best.
speelwerk24/08/2023 23:05:41
464 forum posts
This **LINK**keeps brass shiny for a long time. Niko.
S K25/08/2023 01:49:53
288 forum posts
42 photos
No, I'm not painting it! 😄
This is the kind of thing I'd like to finish. I'm not fully satisfied with the sanding. Maybe a bit more tooth?
I think I'll try the suggested wax.
Thank you!
JasonB25/08/2023 06:54:11
There are thinks like Rustins metal lacquer that protect the metal, Myself I just leave the metal bear as I'm nit a fan of excess bling
John Haine25/08/2023 07:09:48
5563 forum posts
322 photos
I'm sure there are 🇺🇸 stockists.
David George 125/08/2023 08:03:45
2110 forum posts
565 photos
Sand with fine emery paper and or scotch brite then polish with Solvol Autosol polish, somtimes use buffing wheel, then clean with a quick drying solvent cleaner and finnish with Renassance wax. if it is going to get hot in use just go to solvol Autosol.
David
JohnF25/08/2023 09:29:05
1243 forum posts
202 photos
For similar purposes I have used car paint lacquer [spray can] bought from Halfords, the last recent job was a quantity of brass domed nuts to be used in my daughter-in-laws kitchen - time will tell how they weather the steam/kitchen conditions etc ! Other past items have worked well.
The Renaissance wax works well but you do need to keep re-applying it and maybe a refinish now and then.
bernard towers25/08/2023 10:13:39
1221 forum posts
161 photos
Plus one for Halfords clear lacquer.
not done it yet25/08/2023 10:24:54
7517 forum posts
20 photos
Preparation(sanding)
Not done any brass since buying my surface grinder, but surface ground steel items most certainly resist tarnishing - far better than when machined on the mill. Any surface imperfections will be points where tarnishing will be initiated, but surface coatings should avoid that factor (and adhesion of those coatings may be superior on a ‘rougher. surface, compared to ultra-smooth metal finishes).
Mick B125/08/2023 13:28:17
2444 forum posts
139 photos
Posted by JasonB on 25/08/2023 06:54:11:
The metal lacquer works fine, so long as your brass is very clean and dry when you apply it.
Alan Wood 425/08/2023 13:39:04
257 forum posts
14 photos
The late William Smith's website still sells his Rub n Brite polish and protector.
I find it is very good for the initial polish while also giving a very long term protection.
S K28/08/2023 22:34:31
288 forum posts
42 photos
Thank you all for your advice.
I went with Renaissance Wax. I first sanded the parts back to 400 grit, trying a little for a uniform grain direction, and I felt this gave a better finish in brass. The wax is easy to apply, and it seems to resist fingerprints to a degree. I'll be interested to see how well it holds up.
Here's an example after waxing. Thanks again.
John Reese29/08/2023 23:01:40
1071 forum posts
See Clickspring's videos. After he achieves the desired finish, I believe he uses clear lacquer. As I remember, he thins it 1:1 with denatured alcohol.
