Adam Harris | 02/02/2023 15:04:15 |
533 forum posts 26 photos | An old subject I know but with the increase in availability of LED lights in recent years, does anyone today have a recommendation for a magnetic based LED light with bendy neck for use on milling machine and/or pillar drill, 240v plug, preferably with rubber boot over switch and preferably with switch mounted on lamp head ? Edited By Adam Harris on 02/02/2023 15:04:40 |
Pete. | 02/02/2023 15:12:16 |
![]() 910 forum posts 303 photos | Chronos and Warco both sell what you're looking for. |
Adam Harris | 02/02/2023 15:41:11 |
533 forum posts 26 photos | Yes thanks Pete, there are some on Amazon too. Just wondered if anyone had personal experience of one that is particularly worthy of recommendation |
Martin 100 | 02/02/2023 16:21:32 |
287 forum posts 6 photos | The one chronos supply with a halogen lamp is fine, I’ve got several around my workshop and as they use a proper wound transformer rather than an electronic one it can be upgraded to led (far better IMHO than getting one supplied WITH an LED) You just need a 12v led that conforms to the dimensions of the original halogen lamp, with no forward protrusion as it sits behind a piece of glass. I’ve a stash of Philips 12v gu5.3 8w 621 lumen LEDs (equivalent to a 50W halogen without the heat) that fit just perfect. But the magnetic base is sold separately and not available at the moment so you’d need to bolt it down. https://www.chronos.ltd.uk/product/dustproof-halogen-gooseneck-lamp/ https://www.chronos.ltd.uk/product/magnetic-base-for-halogen-led-lamps/ Edited By Martin 100 on 02/02/2023 16:26:55 |
Adam Harris | 02/02/2023 16:50:24 |
533 forum posts 26 photos | Thanks Martin - does the neck droop at all if you mount base onto a vertical surface and extend the neck out horizontally? |
Adam Harris | 02/02/2023 16:52:44 |
533 forum posts 26 photos | I see B&Q are having a clearance on those bulbs you mention at £1 each
Martin 100 | 02/02/2023 17:12:26 |
287 forum posts 6 photos | No droop that I’ve noticed. They always hold position. |
Packmule | 02/02/2023 17:28:26 |
133 forum posts 6 photos | Hi Adam, I wanted a light for the mill and on a trip to IKEA I noticed a clip on led light with bendy arm for £15 it had to be worth a try and it works really well. Navllinge prod no 104.498.91 Regards, Bob
Robert Atkinson 2 | 02/02/2023 17:30:56 |
![]() 1891 forum posts 37 photos | " Equipped with built in transformer for high speed transmission. " Things that make you go Hmmm Robert |
Pete. | 02/02/2023 18:36:13 |
![]() 910 forum posts 303 photos | Posted by Adam Harris on 02/02/2023 15:41:11:
Yes thanks Pete, there are some on Amazon too. Just wondered if anyone had personal experience of one that is particularly worthy of recommendation I bought one with permanent fixed base from chronos or warco, I can't honestly remember which without checking, they were virtually the same, it's what you'd expect from a good quality machine light, the neck is stiff enough to need it firmly mounting to bend with one hand, it'll never droop. Do the ones on Amazon have low DC at the business end? I've seen a lot that look like they do not. Do the the IKEA lights people mention have 24v dc at the business end? Are they made to resist water spray? They don't strike me as being suitable to attach to a machine tool.
Adam Harris | 02/02/2023 19:12:28 |
533 forum posts 26 photos | Thanks Pete and Martin - I think I will go for the Chronos one then, albeit there does not seem to be a rubber boot covering the switch. |
Oldiron | 02/02/2023 19:42:42 |
1193 forum posts 59 photos | Posted by Packmule on 02/02/2023 17:28:26:
Agreed Bob. I have one of those. Works well. Also have a Chinese one from Ebay on the lathe has worked ok for the last 18 months or so. regards |
Clive Hartland | 02/02/2023 22:09:00 |
![]() 2929 forum posts 41 photos | My Ikea magnetic light reacts to the machine vibrations and slowly reclines downards. |
Peter Greene | 02/02/2023 22:35:13 |
865 forum posts 12 photos | I found that lights attached to the mill inevitably got in the way at some point. I now have two small ceiling-mounted spotlights aimed at the machining point and I'm much happier with those. I also have them over the lathe and benches. |
Ronald Morrison | 03/02/2023 11:02:41 |
98 forum posts 4 photos | Look for sewing machine lights. Nice little magnetic mount with a switch, multiple LED's in a fairly narrow head. I have one on my mini lathe and may put one on my mill too. Cheap as they are, if one goes bad you just replace it, no crying over the cost. |
David George 1 | 03/02/2023 11:11:41 |
![]() 2110 forum posts 565 photos | I made a lamp from a strong magnetic base, a goosneck microphone flexible stem and made my own lamp from some aly tube and bits from scrap bin. I fitted an LED lamp and holder from local supplier. The only problem is the swarf sticks to the magnet and in turn some damage to the paint on the mill head where I move it about. David |
noel shelley | 03/02/2023 12:16:40 |
2308 forum posts 33 photos | A good starting point for mag lights( DIY) is the magnet out of a big speaker ! Same magnet in a plastic bag makes a good swarf collector. Noel. |
Sakura | 03/02/2023 15:23:19 |
86 forum posts 1 photos | I use the ones from Lidl with a clamp or a flat base that I put magnets in. About a tenner and are brilliant. |
Adam Harris | 04/02/2023 00:54:54 |
533 forum posts 26 photos | Any ideas where to get a suitably strong magnetic base which one can tap 4 screw holes into since Chronos don't know when they will be back in stock? Eclipse in Sheffield have a 60mm diameter disc which is the largest i can find (E1106) for £15 + vat special clearance price very cheap but min order £100 and somewhat overkill with 105 kg pull force (how would one move it!) and not really big enough anyway - would prefer a 70+mm square plate or 100 mm diameter disk to fit 4 screws with 60mm pcd... Edited By Adam Harris on 04/02/2023 00:55:52 |
Michael Gilligan | 04/02/2023 08:13:51 |
![]() 23121 forum posts 1360 photos | Posted by Adam Harris on 04/02/2023 00:54:54:
. Any ideas where to get a suitably strong magnetic base which one can tap 4 screw holes into […] . Probably cheaper and easier to add suitable magnets to a convenient base The ones I bought from Zoro were £1.75 each, and have a holding force of 10kg MichaelG. . Ref. __ https://www.model-engineer.co.uk/forums/postings.asp?th=184286 Edited By Michael Gilligan on 04/02/2023 08:16:00 |
