Member postings for Martin 100
Here is a list of all the postings Martin 100 has made in our forums. Click on a thread name to jump to the thread.
Thread: Boxford spindle thread type
28/02/2023 14:53:33
Going back maybe 10 years or so ago an ER32 spindle nose fitting collet chuck from a well known UK supplier didn’t fit either of my Boxfords, one dating from 1954, the other from 1960/61, nor did it fit a brand new spindle sourced from Boxford themselves. The thread of the spindle in all cases is 55 deg, 1.5” x 8tpi
The collet chuck measured something very close but didn’t thread more than two turns. The replacement was just the same. The supplier said they had no others returned. Suspected the collet chuck might be a Southbend 60 degree one but couldn’t be bothered wasting any more time as a job needed doing so I just bought a backplate and one of these
Thread: Boxford Little Giant
04/02/2023 11:46:32
Further to my post a few days ago, 280mm long and 10mm wide is the correct belt size …but I can’t at the moment find the supplier I used.
Thread: LED light with magnetic base for milling machine
02/02/2023 17:12:26
No droop that I’ve noticed. They always hold position.
02/02/2023 16:21:32
The one chronos supply with a halogen lamp is fine, I’ve got several around my workshop and as they use a proper wound transformer rather than an electronic one it can be upgraded to led (far better IMHO than getting one supplied WITH an LED) You just need a 12v led that conforms to the dimensions of the original halogen lamp, with no forward protrusion as it sits behind a piece of glass. I’ve a stash of Philips 12v gu5.3 8w 621 lumen LEDs (equivalent to a 50W halogen without the heat) that fit just perfect.
But the magnetic base is sold separately and not available at the moment so you’d need to bolt it down.
https://www.chronos.ltd.uk/product/dustproof-halogen-gooseneck-lamp/
https://www.chronos.ltd.uk/product/magnetic-base-for-halogen-led-lamps/
Edited By Martin 100 on 02/02/2023 16:26:55
02/02/2023 13:39:00
Posted by Roy Birch on 01/02/2023 17:52:09:
Apparently the belts are available at
https://simplybearings.co.uk/shop/Belts-Flat-Drive-Belts/c4601_8093/index.html
300mm, the shortest they and many other suppliers do is too long and outside the range of any adjustment, iirc it needs to be either 280mm or 290mm. I will check but it might be a few days. There is a uk source (plus there was a German source) much cheaper than Tony Griffiths, something in the order of about £8 iirc, again it’ll take a few days to dig out.
Thread: Q-Cut inserts
07/01/2023 17:59:13
Posted by duncan webster on 07/01/2023 12:18:58:
Using a countersunk screw in shear is not ideal. It would be better with a close fitting dowel at the business end and the screw just behind. Then the dowel would take the shear and the screw would just hold it to the tongue. As you are not trying to make 2 out of one it can be a bit longer.
What I did in terms of fastener & fastener mounting centres was exactly emulating the original Greenwood setup, just slightly less (& wasted) blade overhang away from cutting tip.
A bit of a bodge but so is much on a smallish lathe (Boxford)
07/01/2023 10:58:54
Many apologies, felt sure I’d bought them individually many years ago when I also bought a sandvik parting tool blade from RileyShutt as mine from greenwood was becoming a bit tired and prone to losing grip on the insert.
The double ended sandvik one can be cut in half, drilled and countersunk to replace the greenwood sourced items, the result is blade a bit shorter overall but it still parts off the same diameter. (This was sometime before sandvik QD arrived)
06/01/2023 15:18:13
Posted by Bob Unitt 1 on 05/01/2023 19:35:23:
Posted by DC31k on 05/01/2023 19:17:56:
The insert for the one pictured is the 151.2 code, similar to the one here:
https://www.zoro.co.uk/shop/cutting-tools/parting-inserts/n151-2-250-5e-insert-grade-1145/p/ZT1006152P
Ouch, £160 for a minimum of 10 surprise Does anyone know of a source of single inserts ?
Incidentally - the tool is 2-7/8" long, and the insert 3/8" long.
https://www.rileyshutt.co.uk/Products/001100020001
A bit cheaper than zoro and in singles
Edited By Martin 100 on 06/01/2023 15:26:25
Thread: Will they honour these prices, I wonder
06/12/2022 18:58:39
Posted by Clive Foster on 22/11/2022 09:27:10:
Decimal place error in the pricing. They will honour it, the online system won't even notice.
I'd lay odds that all the big "thousands of items in the catalogue" firms have at least a couple of similar lurking somewhere in the list. When you stop to think creating these catalogues is a major, major undertaking.
There is one item in the Farnell catalogue, stumbled on it by mistake around seven years ago, probably bought in the 1000’s since, regularly restocked and still priced at around £5…which is just 25% of the very best wholesale price. smiley
I would hazard a guess someone sells this item on eBay for a healthy markup.
Thread: Pocketmags issues included in digital subs or not?
10/11/2022 10:48:19
Jason,
Pocketmags requested proof of subscription
A partly redacted copy of my bank statement and a screen capture of my subscription status from www.classicmagazines.co.uk was sufficient
Access now restored
Martin
09/11/2022 17:04:41
Selecting ‘Activate Subscription’ does not even offer either of the two titles on my existing account
The same occurs with a fresh ‘new’ account (different browser) so presumably it’s an issue for new subscribers and not just existing ones
Message now sent to their support system
09/11/2022 13:31:33
I’ve got ongoing direct debit print and digital subs to both mags (a month or so from renewal) I’m still receiving print copies, I have still got access to the digital ones via the archive link but there are no issues beyond august 2022 showing as being available on Pocketmags, either on their website or via the respective apps.
Is this to be expected under the new ownership or do I need to do something?
Thread: How Much is this Costing Me?
07/08/2022 16:49:43
Why estimate usage or use a plug in device when a meter to the exact same standards of accuracy as would be used for your whole house metering, or solar export metering costs in the region of £25 (new)
Fix to the wall, four wires to connect.
https://www.ebay.co.uk/itm/255401007037
Edited By Martin 100 on 07/08/2022 16:52:38
Thread: Flash Removal Tool
22/01/2021 13:43:08
Posted by Neil Wyatt on 22/01/2021 09:59:52:
Good news, everyone... there is work in hand with converting the archives, although it will take a little while.
No rush at all
I have a 100% functioning workaround, that. if 'flash' hasn't been removed, requires one config file editing and one standalone program adding.
it should work with W7-10 without issue (only tested so far on W10) AND it requires zero work at your end.
I'll document it here in time
Thread: The demise of UK fossil fuel Power Stations
20/01/2021 16:40:41
Posted by Stuw on 18/01/2021 12:16:13:
The coal fired power stations / boilers were inefficient (~ 22%)
There wasn’t a single coal fired power station in the UK operating in 1990 with a thermal efficiency under 30 percent
22% is in the region of sub 60MW units dating from the 1950’s and earlier equipped with chain grate boilers, phased out or permanently mothballed in the early 1980’s
The top performing 500MW and 660MW units at the likes of Drax, Rugeley, and Ratcliffe were all operating between 35 and 37%. Even the very worst of the 500MW units were operating at around 31-33% by the early 1980’s, as were smaller two shifting 120MW units on 160 bar steam conditions.
Thread: Back issues & Flash plugin
14/01/2021 16:07:06
It would be interesting to know precisely what native format these flash crippled magazines are stored.
Thread: Have You considered getting a 3D printer
09/01/2021 18:42:06
Built a reprap Mendel sometime in 2010, finally replaced with a prusa i3 mk3 around two years ago.
Thread: Yet another scam lathe sale on ebay to be aware of
08/01/2021 22:26:14
Posted by Tony Pratt 1 on 08/01/2021 12:51:18:
Agree with Gavlar, pay with Paypal & no item is received you get a full refund.
Tony
As I have mentioned here previously you cannot always rely on PayPal ‘protection’ for certain classes of goods.
Equipment used in the home workshop CAN easily fall foul of the PayPal terms and conditions especially when they are in most cases the sole arbiter
For instance:
In the current UK PayPal agreement (link below)
Ineligible items and transactions under PayPal Buyer Protection
  • Industrial machinery used in manufacturing.
https://www.paypal.com/uk/webapps/mpp/ua/useragreement-full
Having experienced the totally dire and utterly bizarre PayPal ‘customer service’ and ‘legal’ department based in Dublin a few years ago upon receiving a counterfeit item I hold the position that they were and possibly remain a company standing well apart from every other high street financial institution operating in the UK and the EU.
Thread: Heat Resistant Clear Material Needed...
06/01/2021 14:18:18
The original is probably Mica
Thread: VAT changes post Brexit
04/01/2021 22:41:05
I’ve heard mention elsewhere that this ‘collect VAT at source across the world thing’ is to be adopted by the rest of the EU later in 2021, the UK is, by virtue of the exit, just ahead of the curve.
Some suppliers of services like web hosting, even where they have no UK/EU presence and where the hosting equipment and the domain name are essentially nothing to do with the EU/UK, have charged VAT at a rate depending on the location of the purchaser for several years. They do supply a legitimate VAT invoice.
But there are suppliers of the same services that simply stuck two fingers up at whoever and charge EU/UK customers the same as everyone else.
