Here is a list of all the postings Pete. has made in our forums. Click on a thread name to jump to the thread.
Thread: Dasqua tools? |
01/09/2023 06:27:23 |
Posted by Dave S on 28/08/2023 19:53:06:
Evening all, Contemplating some new micrometers, I need to measure 100 - 150mm range things more accurately/repeatably than with very-near callipers. I don’t really have the budget for mitutoyo, and given M&W seem to be generic Chinese now I looked at the other options. Noticed Dasqua brand - never heard of them, but seem to be cheap enough and claiming DIN compliance. Anyone got actual experience with them? Dave No, two ranges of M&W micrometers are still made in Sheffield. |
Thread: Fuse Rating for VFD |
15/08/2023 23:55:10 |
You've done everything correctly so far, stick the highest rating fuse that will physically fit in there so you don't have to waste time opening it up again. |
Thread: packing box bore clean out tool |
07/08/2023 01:16:11 |
A H16 sounds about the size you're looking for. |
07/08/2023 01:04:21 |
Sounds like an expanding hand reamer is what you're looking for, not particularly expensive at that size, buy a decent one if you're using it for work not hobby. |
Thread: Why do modern car engines have different types of bolt type heads like Torx etc? |
07/08/2023 00:53:38 |
Posted by John Doe 2 on 06/08/2023 18:27:46:
Posted by Pete. on 30/07/2023 00:38:13:
If you're even semi serious about mechanical work it's best to keep every possible fastener type socket to hand, a good selection of Snap On ratchets never hurt anyone either. Agreed, but Snap-On tools really hurt my wallet !! They are a bit on the pricey side, I used to buy most of my stuff from someone selling it privately on behalf of an official dealer at seriously knocked down prices, because they have areas their franchise is only allowed to operate in, so whoever it was just got a friend to sell it for them. All my hand tools have paid for themselves by avoiding garage fees, having worked briefly in a garage when I first left school I've seen first hand the attitude some have to the unaware and ignorant regarding pricing of jobs, and the standard of work by people you wouldn't trust checking your tyre pressures, sadly it's still an industry that attracts a lot of unscrupulous people so I'll continue doing my own work and use it as an excuse to buy more toys, I means tools as and when not really but kinda needed. |
30/07/2023 21:39:59 |
Posted by Bazyle on 30/07/2023 12:54:22:
You don't really want a 16mm socket to be precisely 16mm or it won't fit on a bolt head that had a little more plating. So a sample of plated and stainless fasteners Photo 1, 13mm plated bolt Photo 2, 10mm plated bolt Photo 3, 13mm stainless bolt Photo 4, 14mm plated bolt Photo 5, 11mm plated brake pipe union Photo 6, 13mm plated brake pipe union Photo 7, 13mm OEM bolt from BMW if my memory serves me. Believe it or not, Snap On as a tool manufacturer knows what they're doing. |
30/07/2023 14:31:47 |
You don't really want a 16mm socket to be precisely 16mm or it won't fit on a bolt head that had a little more plating. Never had that problem with them fitting, they're designed as specialist socket to stop rusty fasteners rounding off, after rusting they reduce in size slightly, they also do less visual damage to bolt heads that are aesthetic like motorcycle fasteners that you don't want looking marred up. |
Thread: New Boring Head received-Questions about boring bar indexed-? |
30/07/2023 05:20:39 |
To save time just take a photo with a rule next to it for scale, the vertex catalogue at rotagrip doesn't have a 30mm boring head. |
30/07/2023 00:45:38 |
Posted by JA on 29/07/2023 09:53:03:
What has Malthus got to do with bolt heads? This topic has been taken for a good walk! JA I apologise, I need to wait to be upgraded to Moderater status before making random off topic comments and calling people nutters, luckily Neil likes me 😂 so it won't be long. |
30/07/2023 00:38:13 |
If you're even semi serious about mechanical work it's best to keep every possible fastener type socket to hand, a good selection of Snap On ratchets never hurt anyone either. |
30/07/2023 00:32:34 |
Torx Plus (IP) not the 5 sided are quite simply the best internal fasteners, they're amazing, there's probably a long list of reason manufacturers haven't switched over to using them as a norm, hex fasteners are decided by manufacturer quality and the quality of sockets used on them too, I've given a few of my sockets a rough measure. The top photo is a Snap Flank drive FDX 16mm socket, these are made to precise tolerances, and show exactly 16mm. The second photo is a middle of the road 14mm impact socket that shows 14.2mm The third photo is a 12mm Taiwanese blue point socket showing 12.2mm. The fourth photo is a standard snap on flank drive 16mm showing 16.14mm
Thread: Do you need an oil change with less than 10,000 miles in 10 years? |
16/07/2023 06:27:44 |
Posted by Simon Robinson 4 on 13/07/2023 12:51:06:
My neighbour has a diesel multijet Fiat Panda car. She has had it 10 years since the last oil change but has done less than 10,000 miles as it’s the families second car. I checked the dipstick and it’s the correct level and oil smells ok. It’s black which is normal for a diesel. No oil warning lights. Engine sounds just like a diesel should. I was surprised after such a long interval between oil changes. The car isn’t fitted with a DPF and is a common rail direct diesel injection. I know in a petrol engine, oil changes are needed a lot more often because petrol isn’t a lubricant like diesel is. I’ve also heard of diesels going well over 30,000 miles without any oil change. Can diesels really tolerate such long intervals between an oil change?
Edited By Simon Robinson 4 on 13/07/2023 12:52:02 Nothing wrong with that, my car gets an oil and filter change every hundred thousand miles whether it needs it or not, it's only £25 and 20 minutes work so why not? |
Thread: a machinist making a knife |
16/07/2023 06:10:34 |
Posted by John ATTLEE on 15/07/2023 11:47:30:
Personally, I would prefer to use what modest skills and facilities I enjoy to benefit society! John Society would be pretty screwed without knives. |
16/07/2023 06:06:44 |
Posted by roy entwistle on 15/07/2023 11:02:17:
It would be illegal to carry it in UK Did he suggest you should carry it around with you in the UK? |
Thread: Dead-Blow Hammer Recommendations Please |
04/03/2023 21:30:33 |
Posted by JasonB on 04/03/2023 20:58:42:
So why was the Narex suggested if copper is better with regards bounce
Because an opinion on dead blow hammers was asked for. Because a specific task was mentioned, tapping work down in a vice, my copper mallet leaves copper smeared on what I use it on, so it wouldn't be my first choice for using on workpiece. I use both for different things, dead blow hammers come with many different faces, because it has a dead blow feature shouldn't change the face material chosen for a specific task, I don't use my copper mallet for centre punching because it's a small area and digs in to the face, I do use my dead blow ball pein though. |
04/03/2023 20:45:50 |
Copper naturally absorbs shock it will always be better than plastic in this regard, if you want a copper version (didn't mention in original post) I would have recommended the copper faced version below, or rubber faced faced option etc...
Thread: A photo for anyone who ever claimed a Myford wasn't a "Proper Industrial Lathe" |
04/03/2023 02:34:04 |
Posted by Tony Pratt 1 on 03/03/2023 17:15:22:
Posted by Pete. on 03/03/2023 15:12:34:
Some highly opinionated views from someone who I've never seen upload a single photo of anything they've done in their workshop in the entire time I've been on this forum, where do such strong opinions come from? Who are you talking about? Tony Just someone who seems to spend an inordinate amount of time picking pedantic fault with anything and everything for the enjoyment of winding people up, the devil makes work for idle hands, very idle hands. |
Thread: Mini Lathe ~ best modifications? |
03/03/2023 15:21:10 |
Posted by JasonB on 03/03/2023 07:04:27:
Best Mod - buy something bigger as soon as you outgrow it I do agree there are much better lathes out there, but the relative low cost of the machines on the second hand market and availability of cheap replacement parts means people learning have the confidence to try some creative projects that most would never consider on a more expensive machine, it helps beginners understand how machines work and aspects that make them work better, I find the creativity aspect of it quite fun seeing what people come up with.
03/03/2023 15:12:34 |
Some highly opinionated views from someone who I've never seen upload a single photo of anything they've done in their workshop in the entire time I've been on this forum, where do such strong opinions come from? |
03/03/2023 06:24:05 |
You should upload some photos of your modifications, I'm mulling over ideas for my project mini lathe, I have a couple of ideas I don't think I've seen anyone else do, but these machines are so heavily modified by so many people it's quite possible someone somewhere has already done it. There's a young German lad with a channel called "we can do that better" who almost exclusively does videos on modifying his mini lathe, he's done a few nice additions well worth taking a look. |
