Member postings for Ronald Morrison
Here is a list of all the postings Ronald Morrison has made in our forums. Click on a thread name to jump to the thread.
Thread: Replacement lathes. Recommendations?
09/05/2023 11:12:57
Change gears do not normally transmit much power so 3D printed gears can be used. If you specify what gears you need by describing width, how many teeth, pressure angle, and hole diameter it is likely someone could print them for you for a nominal fee and send them to you. People who have used 3D printed gears say that they hold up well and if they break or wear too much, are easy to print new ones.
Thread: Retro fitting a Closed Loop Drive Board to a Type 34 stepper motor
28/04/2023 11:03:35
Before you spend a lot of money changing the stepper motors, think of a cheap solution. Steppers lose steps because they don't have quite enough power to make the full step and then fall back to the previous step. If you are only losing a few steps occasionally, think how to increase the power slightly. I simply increased the power supply voltage a little to get rid of the missed steps.
Thread: Grit value for honing carbide tools
28/04/2023 10:52:45
Posted by Sonic Escape on 27/04/2023 21:27:27:
I'll buy only one. They are not cheap and it is not a necessity, more a curiosity. I have one of those small USB microscopes and I'm curious how the edge of the tool will look after honing.
Also look at the edge after using it to see if the fine edge you get from honing will hold up under machining. Let us know what you find so we can use the information to make decisions on our own carbides.
Thread: Creating rectangular blind hole
17/04/2023 11:22:09
Posted by Rowan Sylvester-Bradley on 16/04/2023 16:17:58:
Posted by duncan webster on 15/04/2023 20:37:47:
Can't you redesign it away?#
I can't see how. It is a tool that has to fit an existing piece of machinery, so I can't change any of the dimensions. I made it a blind rather than a through hole because I think I need the additional strength that this will provide.
Rowan
Instead of making this a difficult project with the blind hole for strength, can you change the material to gain the extra strength with an open hole?
Thread: how to make best use of my (unused) 3D touch probe? Linux? Arduino? Raspberry Pi? Mach 3?
29/03/2023 11:25:55
Posted by Andy_G on 28/03/2023 15:45:57:
Too late to edit the above, but you may also like to take a look at bNC which (I think) will run on the Rasberry Pi to use in conjunction with your GRBL controller.
I haven't used it, as it requires python to be installed on a Windows machine.
https://pypi.org/project/bCNC/
Edited By Andy_G on 28/03/2023 15:49:03
I have Universal Gcode Sender as well as bCNC installed on my Raspberry Pi. Universal Gcode Sender insists on taking the mill Z axis to the top of its travel before it starts. bCNC starts where I tell it and only raises enough to clear any part that may be in its way as is defined in the gcode. YMMV
Thread: LED light with magnetic base for milling machine
03/02/2023 11:02:41
Look for sewing machine lights. Nice little magnetic mount with a switch, multiple LED's in a fairly narrow head. I have one on my mini lathe and may put one on my mill too. Cheap as they are, if one goes bad you just replace it, no crying over the cost.
Thread: Sieg X3 milling machine
08/01/2023 12:04:51
Posted by JasonB on 07/01/2023 13:36:05:
The X3 does not have a knee.
My mistake. I saw the extra control at the bottom of the table set at an angle and expected it to control a knee but instead it raises and lowers the head. That does some of the function of a knee but keeps the entire mill base at benchtop. A larger mill would have a fixed head and a knee to bring the work to the necessary height but requires a floor level base with a knee to bring the work to the proper level. It's a compromise.
Thread: Preparing for long period of disuse...
07/01/2023 12:29:09
Posted by DiogenesII on 07/01/2023 07:46:49:
..don't leave machine drive belts under tension..!
The fan belts on my tractors spend their entire lives under tension and the tractors may set unused for 6 to 8 months at a time. I don't think modern belts need to be relieved of their tension. The only factor I see with drive belts left under tension (my larger lathe, 10 X 24) is that the belts may take a set on the curve of the pulleys and cause a slight uneveness at startup but that goes away in the first few seconds of operation. If it is reasonably easy to relieve the tension, go ahead and relieve them. It is very difficult on my lathe so it doesn't happen.
07/01/2023 12:02:32
A bigger and beefier version of the Seig X2 with the addition of the knee it should be relatively easy to adapt it to CNC in the future if that is your desire. It isn't a big mill with huge engine horsepower and the weight of a big mill for stability and rigidity but used as a small mill with appropriate size cutters and depth of cut and speed it should do good work for you.
Thread: Improvised CNC Lathe
07/01/2023 11:54:56
Can the g-code for the crown be derived from treating the rim of the flywheel as a section of a sphere?
Thread: R8 Tooling for Warco Super Major Mill
11/12/2022 10:56:15
A drill chuck is intended to hold drill bits....which are not high precision. Their purpose is to make a hole, not necessarily a round hole and not to an exact size. You don't want the drill bit to wobble about but a tiny bit of runout in the chuck isn't going to affect the making of a hole. If you want a more precise hole you use a center drilling end mill in a collet.
Thread: 3d modelling software
03/12/2022 12:28:02
Posted by Model Enginerd on 02/12/2022 18:58:04:
Synchronous modes are typically a last resort tool for dumb solids but can be handy when you are working with a lot of people and want some sort of history in the design tree.
You can change a hole diameter in a sketch, or you can add a synchro at the end of the design tree and name it to your current rev.
As for migration from any CAD package, it is a good idea to call it a loss and export everything into STEP/IGES. I just eat crow and resketch models if necessary.
I only buy modeling tools I can own for this reason, even if they might be subpar. Alibre, Rhino and Zbrush are still good tools I only have to buy once. Hopefully I don't wake up one morning to find out they snuck a kill switch like Fusion 360 did!
Fusion 360 gave me a start in 3D modeling but it only took one year to learn what Autodesk had in mind, free sample, then reduce the features available to push one toward a purchase. I decided that for my needs (wants?) that FreeCAD would suffice and while it might take longer to learn, the features I learned wouldn't just disappear at the whim of a corporate bean counter. I no longer need to jump through Fusion's renewal process either which I found quite annoying.
Thread: Myford S7 with stepper on cross-slide
30/11/2022 11:39:58
If a stepper motor has power applied it acts as a brake. With power disconnected is turns freely but...it then acts as a generator so it can backfeed any electronics attached to it. Turn it slowly and there is no problem, spin it fast and it can provide too much voltage for the electronics and burn them out.
Thread: strange electronic caliper fault
20/10/2022 12:04:51
Posted by Anthony Knights on 20/10/2022 11:32:00:
Display was OK so battery fine, but checked it anyway. Also looked at contacts when battery was out. Basic stuff which I didn't think worth mentioning.
The display will work with a nearly dead battery. The measurement will not. Battery that is low will display fine but with the wrong readings.
Thread: Advice on how best to convert a 3/16x40 Plug Tap into a Taper Tap
14/07/2022 11:42:23
I've been approaching the threading from a different perspective. Do I really need full depth threads for my fastening needs? Usually not, so instead of selecting the exact drill diameter I choose one of the drills just a few thousands of an inch bigger. Suddenly, starting a tap is so much easier and breakage of the tap has been eliminated.
Thread: Suggest a repair method for broken aluminium alloy casting
02/05/2022 11:14:49
Posted by AJAX on 01/05/2022 21:00:42:
Posted by Pete Rimmer on 01/05/2022 18:22:25:
I'd tig weld that for you if you were able to bring it to me in N Kent.
Pete, that's very kind of you to offer; however, I'm going to get some brazing rods and give it a try on some scrap. I'd like to see if I can do it myself as it could be a useful skill for future tasks.
The aluminum brazing rods will probably do everything you need for this repair. However, do be aware that this is an irreversable repair. Once done, TIG welding is no longer an option. The area to be TIG welded would be contaminated by the brazing rod.
Thread: Blobs on 3D print..
26/04/2022 10:31:58
Octopi will let you download the entire file to its internal memory before printing. That eliminates the network bottleneck and the necessity of saving to an SD card and plugging it in.
Thread: Making a Start in FreeCAD
20/02/2022 12:40:02
Posted by DutchDan on 20/02/2022 08:54:19:
Thanks guys, I'll have to give Freecad another go. Sounds like they made quite a bit of progress.
Thor, an ender 3 can be had for under 200 euros now. Unlike some of the more expensive machines it's made to a price, so you may have to tinker with it a little. But I've had good experiences with mine. Someone of your skill level should have no problems. I'd just recommend making sure the bed isn't warped at that'll be harder to fix, and the quality control on these machines can be lacking.
I replaced the original bed with a glass bed. It needs to be cleaned with isopropyl alcohol (rubbing alcohol) regularly but when nice and clean the filament seems to stick really well. When the bed cools to room temp the print comes off easily.
Thread: Digital Height Gauge Recommendations?
20/02/2022 12:33:08
If you can read a vernier now, will you still have the vision ability to read the vernier in 10 years? The battery of a digital will need replacing regularly but I find that I can at least see the digits. Not so the vernier.
19/02/2022 10:59:32
Posted by Thor 🇳🇴 on 20/06/2019 12:34:32:
Following Dave's excellent tutorial I tried to make a model of something useful, a tray for my ER 16 collets. A friend of mine has access to a 3D printer where he works. I haven't tried printing the model as my friend is on summer vaccation.
I have tried to write an explanation of what I did here, probably many errors so I assume I will have to revise it.
Thor
A project like this would be easy to print on an Creality Ender 3 printer. While not the most sophisticated printer out there nor the largest, if you have the space to put it that printer is fairly inexpensive. Once you have the 3D printer you will be surprised at how many little projects it will come in handy for. Note that I have no ties to the company, just a satisfied user of one. If you do a search for "Creality Ender 3" it should show you the availability and price in whatever country you live in.
