Hallite washers
Deric11/07/2020 15:43:49
44 forum posts
27 photos
Hello, all
I have been building Super Simplex fir a long time now and have finally got to the superheater, which is now almost finished. In order to seal the regulator output to the superheater the drawing calls for two 1/32” Hallite washers 3/4” od x 1/2” id. These washers sandwich an Oring and are fitted in the output boss on the boiler and the superheater boss when fitted and tightened compress the oring ti form the seal.
I have asked the usual suppliers if they can supply these Hallite washers and it seems no one does and doesn’t know what they are!
can anyone help me with where I can get these? and if you have built Super Simplex what did you use?
TIA
regards
Deric
pgk pgk11/07/2020 16:02:08
2661 forum posts
294 photos
It looks like Hallite is a UK Co with website, contact phone numbers and on-line expert chat...and google throws up stockists..
https://hallite.com/
Andrew Tinsley11/07/2020 16:03:23
1817 forum posts
The last time i used hallite washers was many years ago. I got them from BSS (British Steam Specialites). It is worth a try if they are still trading.
Andrew.
HOWARDT11/07/2020 16:58:14
1081 forum posts
39 photos
Like wise have used Hallite seals in the dim and distance past, but don’t remember Hallite washers. Having done a web search seams there is Halite washers, note one l. These appear to be from gasket material referenced a few times on my search as used on Lambretta joint faces. So perhaps not a flexible seal material as such.
Robert Atkinson 211/07/2020 17:05:38
1891 forum posts
37 photos
Hallite washers are fibre wahers with a wire mesh reinforcement.
Robert G8RPI.
JohnF11/07/2020 19:45:47
1243 forum posts
202 photos
Hallite seems to have disappeared, I needed [wanted] some a short while back but ended up using an alternative from Ebay -- enter Hallite Gasket Material and search you should find something suitable to make your washers from - easy enough to make a couple of one use punches from the scrap box.
My recollection of Hallite is it was a paper based material with graphite impregnated and some form of reinforcement but I don't remember it as wire ? Stand to be corrected of course.
Brian Sweeting11/07/2020 20:06:33
453 forum posts
Are these bonded seals of any use?
Bonded seals
Brian Morehen11/07/2020 20:22:48
191 forum posts
11 photos
Used to be able to buy this in a rolled up sheet which was about 1/32 thick have used this in the past for seals on steam boilers may have some ofcuts still as left overs will have to look what i have if any interest , years since i bought any..
Regards Brian
not done it yet11/07/2020 23:57:29
7517 forum posts
20 photos
Posted by Brian Sweeting on 11/07/2020 20:06:33:
Bonded seals
You mean a Dowty washer?
Howard Lewis12/07/2020 02:17:08
7227 forum posts
21 photos
Like NDIY, I wondered if Dowty washers would do the job. Depends on the rubber insert having a high enough temperature capability.
You could make your own washers, by punching out from a sheet of gasket material. Punch the hole first, and then the OD!
David George 112/07/2020 08:06:18
2110 forum posts
565 photos
Hi there is a website for Hallite https://hallite.com/contact/ they list a roll of material.
David
Michael Gilligan12/07/2020 08:29:37
23121 forum posts
1360 photos
Posted by not done it yet on 11/07/2020 23:57:29:
Bonded seals
dont know ... I expect Dowty would be pleased to see that  ‘generic’ bonded seals are  not being marketed under their trade name.
Edited By Michael Gilligan on 12/07/2020 08:31:38
J Hancock12/07/2020 08:59:44
869 forum posts
Either the washers or the O-ring make the seal ?
Can't really see why you need both.
Samsaranda12/07/2020 09:05:06
1688 forum posts
16 photos
Bonded seals/ Dowty washers are used to seal banjo type fittings on hydraulic systems, a particularly specialised function.
Dave W
Deric12/07/2020 09:57:29
44 forum posts
27 photos
Here is an extract from the drawing showing the superheater seal location.
i have been offered some glass impregnated PTFE to make washers which I think meant to compress and ‘protect’ the oring. Given that Super Simplex was designed in the mid 80’s Hallite washers were probably the most suitable for this application.
do you think the PTFE will do as good a job, given that it’s good for over 300DegC?
John Baguley12/07/2020 10:27:30
517 forum posts
57 photos
There really is no need for the washers but I presume that you have made the parts to the drawings so the gap for the O ring will be too big for the O ring alone. Your PTFE should be fine to make the washers or you could just make a spacer washer out of brass (put on the boiler side of the O ring) to make the gap the right width for the O ring on it's own.
I've used the O ring seal on several locos and it works very well. Much better than the threaded joints beloved by LBSC which are an absolute pain!
Brian Sweeting12/07/2020 15:57:25
453 forum posts
Bonded seals
That's the name, for the life of me I couldn't remember it. It was only 40 years ago when I used them on a regular basis.
Deric12/07/2020 18:47:45
44 forum posts
27 photos
Thanks to all of who have chipped in, your comments are much appreciated.
im going to go for the PTFE solution.
Thanks again
Deric
not done it yet12/07/2020 19:49:43
7517 forum posts
20 photos
I know the feeling. Used extensively on hydraulics but the name is often forgotten - when one simply goes to the box of washers!
