How often do you oil your lathe ways?
Blue Heeler31/05/2019 21:58:13
342 forum posts
David George 131/05/2019 22:12:22
2110 forum posts
565 photos
Hi I lubricate at least every other time I use it and wipe it with an oily rag most times I use it to clear swarf etc.
David
Neil Wyatt31/05/2019 23:10:19
19226 forum posts
749 photos
86 articles
Depends! I regularly use neat cutting oil so more usually I'm cleaning off the excess... I go round the oil nipples once a month, which includes the saddle.
Andrew Johnston31/05/2019 23:13:30
7061 forum posts
719 photos
When I remember, or they look dry.
Hopper01/06/2019 00:46:40
7881 forum posts
397 photos
Beginning and ending of every session of use.
Beginning for lubrication. Ending for corrosion prevention.
Edited By Hopper on 01/06/2019 01:01:41
not done it yet01/06/2019 06:19:25
7517 forum posts
20 photos
Depends on how long between sessions. Sometimes weeks between sessions. Oil costs very little - lathe beds are expensive. Common sense tells me to keep it lubed, rather than run it to death.
Thor 🇳🇴01/06/2019 06:23:19
1766 forum posts
46 photos
I do pretty much the same as Hopper do, lubricate the ways at the start of the session, afterwards I clean the ways and add a few drops of oil.
Thor
Blue Heeler01/06/2019 07:02:26
342 forum posts
Thanks everyone for the replies appreciated,
I.M. OUTAHERE01/06/2019 10:47:24
1468 forum posts
I have a slightly different regime as i tend to use my machines on weekends mostly so i usually do a clean up on Sunday or Monday then wipe the shiny bits down with lanotec to stop any rusting and this means i have to clean that off before i use the machine - i use cheap spray degreaser ( repco or supacheap etc) and this means i have to oil the bed before use . You can never apply to much oil to a machine and i use chain bar oil, its cheap , it works , it sticks in there and it don’t stink . If I’m machining cast iron i wipe the machine down so the only oil is between the carriage and bed - cast iron dust and oil = grinding paste !
I’m currently working on a mini dehumidifier for one of my lathes using a peltier module and the arduino code that was described by Silly old duffer in a past issue of MEW, so far results look promising but testing has been hindered by dry - low humidity weather . If it works it will hopefully put an end to the painting on of a thick coat of lanotec to stop rusting in winter as the condensation can be horrific in winter here in western Sydney.
JohnF01/06/2019 11:09:33
1243 forum posts
202 photos
My machines are in a heated workshop under the house so no problems with condensation etc nevertheless I lubricate at the beginning of every use, bearings, bed etc and clean off all swarf when finished. My apprenticeship boss an ex army chap insisted we cleaned our machines and put all tools away -- oil is cheap machines are not -- it pays dividends in the long term.
SillyOldDuffer01/06/2019 11:37:54
10668 forum posts
2415 photos
Posted by Blue Heeler on 31/05/2019 21:58:13:
When they need it, which is often.
Lubrication is an obvious reason, but - in my workshop - maintaining cleanliness is probably more important.
Steel and aluminium swarf aren't a major problem compared with brass and cast-iron. But it pays to get rid of steel fragments laid on the ways in case it rusts - Iron Oxide is an abrasive. Brass often comes off in fine particles that get stuck into moving parts to create a kind of junior sandpaper. Cast-iron is the worst; cutting it creates a fine powder some of which - like bits of hard skin or casting sand - make a decent grinding paste. And it's filthy. A good way to clean the ways is to wipe them off regularly with generously oiled paper towels or lint free cloth.
When the lathe is going to be laid up for more than a few weeks, I treat it to some proper Way Oil, which is sticky. Otherwise, it gets plain oil, Lawnmower Oil at the moment. I avoid fancy motor oils because of the additives, but I doubt they make much difference.
I'm not as obsessive as the above might suggest. My lathe is Chinese and it's never going to be a much loved heirloom!
I.M. OUTAHERE01/06/2019 12:14:38
1468 forum posts
Hi Dave ,
Not wanting to drag this post off topic i have sent you a PM .
Ian.
Mick B101/06/2019 13:43:15
2444 forum posts
139 photos
I make oiling the ways the last op in any clean-down, which happens whenever I become disgusted with the state of it. The threshhold for that varies with the quantity and perceived interest level of what I'm doing.
old mart01/06/2019 19:58:59
4655 forum posts
304 photos
Since renovating the museums Smart & Brown model A's apron, the built in pump not only lubricates the gears and shafts inside, but also the leadscrew nut, cross slide and ways. It gets topped up about once a fortnight. I t gets semi synthetic 5W40 motor oil and also for the 70 year old spindle bearings which have no measurable wear.
Edited By old mart on 01/06/2019 20:03:02
clogs01/06/2019 22:13:48
630 forum posts
12 photos
I pretty often oil up the lathe bed and most of those stupid recessed ball bearing oilers are now changed for drippers....mostly home made....
tho the best aid to cleanliness I added to my lathes was tin covers fitted with magnets to the carriage ....
these stop virtually all swarf and coolant directly where I'm machining....
quite like the "Rage magnetic swarf wand"
have a dedicated paint brush for cleaning and another for applying oil....
oil is always Synthetic engine oil 5w-40....
Blue Heeler01/06/2019 22:14:47
342 forum posts
Posted by XD 351 on 01/06/2019 10:47:24:hopefully put an end to the painting on of a thick coat of lanotec to stop rusting in winter as the condensation can be horrific in winter here in western Sydney.
XD what causes this condensation? I get it in my shed about two months of the year as well. Usually in the dead of winter July/August I'll go into my shed and everything metal will be dripping/sweating with beads of water?
I setup two fans on timers to go all night and this alleviates it.
Neil Wyatt01/06/2019 22:54:38
19226 forum posts
749 photos
86 articles
Do other folks slather on neat oil like I do?
I'm more likely to worry about it pooling up on the ways than them looking dry!
Brian John02/06/2019 02:49:49
1487 forum posts
582 photos
And if your lathe does become rusty (through a combination of neglect and tropical humidity) then what is the best way to remove it from the ways, lead screw, tailstock and jaws ?
Blue Heeler02/06/2019 03:13:23
342 forum posts
Posted by Neil Wyatt on 01/06/2019 22:54:38:
Yes, I do go overboard Neil.
Pete Rimmer02/06/2019 07:50:13
1486 forum posts
105 photos
Yes my hobber oil pump leaks from the stuffing gland so I keep a roses tin under the pump. As it fills up I pour it into a jug which I keep on the lathe with a brush in it. The sump was full of dark sulphurised cutting oil when I got it and I marvelled at how good the ways were for a 70 yr old machine, so I figured I would continue the tradition.
