Here is a list of all the postings Blue Heeler has made in our forums. Click on a thread name to jump to the thread.
Thread: Enjomor 6cc Hit & Miss Engine - Last Mods I Think? |
16/08/2023 00:10:28 |
Posted by Ady1 on 15/08/2023 13:18:08:
Nice. Well done you It was with the help of so many kind enthusiasts, I'm more of a steam engine bloke and these IC engines can be temperamental. Its great to be able to get help and advice from like minded people. Appreciate the reply, thank you! |
15/08/2023 03:04:42 |
Enjomor 6cc Hit & Miss Engine - Last Mods I Think? Somehow I doubt it though, these engines are made to muck around with. |
Thread: VE-01 Crossbeam Vacuum Engine added a drive pulley and running some accessories |
10/08/2023 06:41:31 |
VE-01 Crossbeam Vacuum Engine added a drive pulley and running some accessories, a Fleischmann Sausage Man and a DIY Baker Fan.
Thread: Enjomor 6cc Hit & Miss Engine Modifications and running and hit and missing |
07/08/2023 08:34:43 |
Enjomor 6cc Hit & Miss Engine Modifications and running and hit and missing. Many many thanks for all the help & suggestions I've received. Just a REALLY great looking Hit & Miss Engine, any other hints if you think it could run better, much appreciated as always.
Thread: Enjomor Hit & Miss Running! |
01/08/2023 22:45:00 |
Thanks guys, appreciated. It was my fault
https://www.flickr.com/photos/198834535@N04/53087310711/in/dateposted-public/ |
01/08/2023 05:23:28 |
Enjomor Hit & Miss Running! On a temporary board and needs some fine tuning, but running now…..thank you for your help 🙌 |
Thread: Hit & Miss Engine - Help Needed |
28/07/2023 07:42:43 |
Thanks @JasonB Jason really appreciate all the posts trying to help me mate. I've had my wife in the shed now multiple times to test having the spark plug resting next to the spark plug hole with the 3 x 1.5v AA batteries and there's no, zilch, nada, nothing. As soon as I switch over to the 4 x 1.5vAA battery pack instantly there's a really good spark across the gap which has me utterly baffled as I've watched so many YT vids of other owners running their same engines with the 3 battery pack as supplied with the engine (like what I received) but when I emailed the company they said the engine needs a minimum of 6v to fire. Next hurdle is the timing. I'm starting to doubt myself now, so to double check this is TDC isn't it ! Am I incorrect that I adjust the firing (timing?) by adjusting this brass piece that slides on that rail that pushes down on the switch to make contact?
Once again....appreciate the posts. |
28/07/2023 01:50:09 |
Have Spark now !!! |
28/07/2023 00:43:14 |
Thanks one and all for the replies. Sorry for the tardy replies, just in case you don't know I'm in Australia so the time zones play havoc. |
28/07/2023 00:41:52 |
Posted by Trevor Johnson 1 on 27/07/2023 08:49:07:
CDI systems work completely differently to the conventional points/condensor systems. Different wiring connections and colour schemes are used by different manufacturers, suggest as it is a new model/machine you contact the supplier/manufacturer for further help /advice. Always watch your interesting channel and hope you can get this issue resolved. Edited By Trevor Johnson 1 on 27/07/2023 08:49:51 Thanks Trevor, very much appreciated Jim |
28/07/2023 00:41:16 |
Posted by JasonB on 27/07/2023 08:45:57:
Here is one of my S/S ignitions. You can see that the red signal wire from the CDI stops at the futaba socket and I just have the two outer black & white wires from there that I connect to the contacts on the engine. Same Futaba socket will accept a Hall sensor with it's three wires. Thanks Jason for taking that photos and also the many replies, truly appreciated. |
28/07/2023 00:38:36 |
Posted by Michael Gilligan on 27/07/2023 07:06:57:
With apologies if you have already done so … could you please post a clear photo of the text on that yellow box-of-tricks. … or a link to the supplier
Thanks MichaelG. Edited By JasonB on 27/07/2023 07:11:41
Hi Michael, just took these two photos -
https://www.flickr.com/photos/198834535@N04/53076472928/in/dateposted-public/
Edited By Blue Heeler on 28/07/2023 00:39:50 |
27/07/2023 03:15:40 |
Hit & Miss Engine Help Needed - Part 2 Really appreciate all the help and advice that I have had from - Thank You. I've put this second help video up as I'm still stuck getting a spark and the wiring has me really baffled. I've tried to point out in the video what is confusing me, so I hope I have explained it well enough to be able to obtain some help and advice.....as always super appreciated guys. Edited By JasonB on 27/07/2023 07:12:07 Moved to the original thread to save people looking for the first. Edited By JasonB on 27/07/2023 07:12:58 |
Thread: Cleaning a boiler - limescale deposits? |
27/07/2023 00:10:47 |
You can buy a stronger White Vinegar from hardware stores now that they sell for home cleaning. I use that and its works very well on removing scale. |
27/07/2023 00:09:09 |
Posted by JasonB on 26/07/2023 06:49:20:
Easier to put the HT and earth very close together and then make the contacts see here Jason......appreciate that link mate...thank you. |
26/07/2023 00:14:50 |
Appreciate all the replies, thank you all. For someone like me with limited electronics knowledge is there a way to test using a multimeter if the ignition module is faulty? Can I put a probe on the spark lead and get a reading? |
25/07/2023 08:19:19 |
Thanks for the link to the vid Jason, appreciated mate. You maybe onto something else that I need to check out. I took out one of the head bolts and slipped the earth in the bolt and put it back, But I have only been putting the probe on the head of the bolt and not the wire loop. |
25/07/2023 07:21:39 |
I will do that Jason thanks, I just had a look and they aren't touching but they are really really close. Appreciate the comment(s) its frustrating when something just can't get even a spark of life to it. |
25/07/2023 04:50:49 |
G'day all, I have taken more than a few days to build the base for this 6cc Hit & Miss Engine. Really happy how it turned out. I can't get a spark from the plug. Has anyone got any thoughts on what to check out to see why I'm not getting a spark? I've pointed out in the video a few things where I'm stuck.
Thread: P M Research No 4 |
21/07/2023 07:32:29 |
Very nice build of a No4.
