Milling machine drawbar
beshopkins24/10/2018 16:06:32
2 forum posts
I need to make a metric drawbar for a milling machine which does not involve any machining?
JasonB24/10/2018 17:26:50
Buy a length of suitable metric studding (all thread) and a matching nut plus a large washer and you will have a working draw bar. Ideally saw off the excess length of the studding.
Michael Gilligan24/10/2018 17:31:58
23121 forum posts
1360 photos
Some indicative sizes would help ... but you should get-away with a suitable length of all-thread [a.k.a. studding, or threaded rod], plus some nuts and washers.
Jason beat me to it.
Edited By Michael Gilligan on 24/10/2018 17:32:34
Neil Wyatt24/10/2018 17:51:29
19226 forum posts
749 photos
86 articles
Posted by JasonB on 24/10/2018 17:26:50:
You've just described my metric drawbar.
I must get around to making one with a collar to fit the self-release system I made with an imperial one!
beshopkins24/10/2018 18:25:57
2 forum posts
I had thought of using metric studding with a nut, which assume needs silver soldering or welding to one end of the studding.
Thank you to all those forum members replied to my question.
JasonB24/10/2018 18:36:23
No just leave the nut loose.
My M10 drawbar is just that, as I only have one tool with that thread which is seldom used I have not bothered with anything posher.
Michael Gilligan24/10/2018 21:06:36
23121 forum posts
1360 photos
Posted by beshopkins on 24/10/2018 18:25:57:
If you feel the need to put a 'head' on the studding [which Jason clearly does not], it's a simple matter to lock two nuts together tightly, or to fix one in place with 638 Loctite or similar.
Mark Rand24/10/2018 22:35:17
1505 forum posts
56 photos
Yes, my two drawbars (1/2" BSW and M12), although they were threaded on the lathe, have nuts on the top glued on with Loctite. It just works!
Nick Wheeler24/10/2018 23:18:59
1227 forum posts
101 photos
Posted by JasonB on 24/10/2018 18:36:23:
That's how my imperial one is done. It's not worth spending any more time on something so simple.
Mike Poole25/10/2018 00:31:06
3676 forum posts
82 photos
I had a nut welded and a loose nut on mine but I had easy access to an expert welder so why not? Whatever you do if it works the jobs a good un.
not done it yet25/10/2018 09:00:39
7517 forum posts
20 photos
Posted by Mike Poole on 25/10/2018 00:31:06:
You needed an expert welder to fix a nut on a threaded rod? smiley
Suitable grade of loctite would do (as MG above)? Mine mostly have a simple locknut under a longer nut (for easier fitting of a spanner). But it must be comforting to have someone else make it for you! smiley
Vic25/10/2018 09:25:32
3453 forum posts
23 photos
I made a self extracting drawbar for my VMC, the hexagon section is pinned to the shaft.
JasonB25/10/2018 10:01:09
Don't pins and welding need machinessmile p
larry phelan 125/10/2018 11:28:13
1346 forum posts
15 photos
I thought that was the way most guys made their draw bars ?
Not exactly rocket science.
Ian S C25/10/2018 12:20:18
7468 forum posts
230 photos
When I needed a drawbar, I grabbed two 1/2" bolts, cut the heads off and welded them together, must have done it right enough, it's still holding together after about 25 years.
Ian S C
Muzzer25/10/2018 13:02:52
2904 forum posts
448 photos
The reason you might want to use a more complex(??) solution is because often the bore in the spindle is larger than the threaded part of the drawbar. In that situation, if you just use studding, it won't self-centre. Not a show stopper but at the sorts of speeds you should be using it will be out of balance with nothing to locate it. Given that most of us here have the machinery to do it properly, it seems a pity to see the handbags coming out - some sort of inverse snobbery there!
One other "simple" option is to drill and tap a hole in the end of a piece of round stock, then Loctite in a piece of stud or the end of a bolt. At the other end you can simply Loctite a collar in place. That way you get the best of both worlds. It's how I did mine before I replaced them with a quick change system.
Murray
JasonB25/10/2018 13:17:46
I assumed the OP did not have the machinery and that is why he asked how to do it without machining. I can imagine several first time buyers of mills who don't have a lathe may face the same problem.
Vic25/10/2018 14:37:43
3453 forum posts
23 photos
I assumed the OP had a milling machine as he wants to make a draw bar for one? thinking
Michael Gilligan25/10/2018 15:07:06
23121 forum posts
1360 photos
Posted by Vic on 25/10/2018 14:37:43:
But is a milling machine without a drawbar actually a milling machine ?
... that is the question !
Edited By Michael Gilligan on 25/10/2018 15:07:55
Frances IoM25/10/2018 15:20:43
1395 forum posts
30 photos
maybe he has a non-metric machine + tooling with a 3/8th drawbar - I've had to make such a drawbar to use some MT2 tools on my otherwise metric machine
