Remote alarm for garage / workshop
Speedy Builder5 | 13/03/2018 15:37:45 |
2878 forum posts 248 photos | I am building a garage which is remote from the house and mains electricity / telephone etc. I am devising a simple alarm system built around an old smart phone and a mains failure app (free of course). |
Brian Sweeting | 13/03/2018 15:50:21 |
453 forum posts 1 photos | Good idea, make sure that you audible alarm complies with the regulations regarding length of time sounding etc. You don't want the council noise snoopers spoiling your day. |
Samsaranda | 13/03/2018 17:21:40 |
![]() 1688 forum posts 16 photos | Your specification bears some similarity to the wonderful inventions of Heath Robinson, seriously though if it works it’s got to be good. Dave W |
Martin Cargill | 13/03/2018 18:00:56 |
203 forum posts |
I bought a caravan alarm for my old lockup. Worked from a 12 volt battery and with its own sim card it could be switched on/off with its keyfob remote or by text message. If activated it could text 3 different numbers and phone the main number (so that you could hear the burglars at work!). It would also inform you of which circuit had tripped. It could also activate a relay to switch on lights and/or a camera, All for £130 Martin
V8Eng | 13/03/2018 18:09:47 |
1826 forum posts 1 photos | Posted by Speedy Builder5 on 13/03/2018 15:37:45:
I do not see any mention of remote disarming if there is a repeat false alarm and you are miles from home etc? That might be a consideration. Edited By V8Eng on 13/03/2018 18:10:47 Edited By V8Eng on 13/03/2018 18:11:49 |
Speedy Builder5 | 13/03/2018 18:20:06 |
2878 forum posts 248 photos | I don't think it will be a problem as the alarm has its own cutoff after a predetermined time. |
I.M. OUTAHERE | 13/03/2018 18:25:08 |
1468 forum posts 3 photos | Would also make an interesting arduino project ! |
Howard Lewis | 16/03/2018 16:29:20 |
7227 forum posts 21 photos | As security, additional the 5 or 6 lever lock / hefty padlock, may I advocate fitting hinge bolts? If the hinge pins are externally accessible, driving out the pins would allow the door to be lifted away from the striking plate. With hinge pins, this is much less of a possibility. My door is a recycled fire door with a 6 lever mortice lock, but the hinge pins are just visible, externally. So anyone feeling strong could obtain entry in this way. I made my hinge bolts by turning the heads off No12 woodscrews. The screws were screwed into the wooden door, using a drill chuck. The door was then partly closed so that the pins marked the door frame. Holes were than drilled on these marks, to act as sockets for the pins. If you have windows, cover them, internally when not in the shop. If the lowlife cannot see what there is to steal / vandalise, they will look elsewhere, certainly if entry is going to be difficult. Howard |
pgk pgk | 16/03/2018 17:01:47 |
2661 forum posts 294 photos | Sadly my experience with such devices..a hugely sophisticated multi-bell & light alarm system, cctv etc was that the neighbours ignored it, the criminals just rammed through the door wearing hoodies and gloves and caused more damage than they got in usable goods. They were gone inside 5 mins. Plod just issues a crime number and asks if you know who did it. A bucket of dye above the door would be better since we're not allowed to wire in really effective tomb rader type traps..... |
Mike | 16/03/2018 17:49:48 |
![]() 713 forum posts 6 photos | When I first started reading ME, I think some time back in the 1960s, there was a letter from a chap who got totally fed up with break-ins at his workshop, which was in a rural location. His answer was to buy a redundant electric factory hooter, and wire it to an alarm system so that most of the sound was directed inside the building. I seem to remember that the first low-life to break in ran straight through a glass window in his hurry to get out, and the second was led out, a gibbering wreck. After that, word got around and the break-ins ceased. Pity you couldn't get away with such a trick these days! Edited By Mike on 16/03/2018 17:54:43 |
mick H | 16/03/2018 18:34:08 |
795 forum posts 34 photos | Posted by Mike on 16/03/2018 17:49:48:
When I first started reading ME, I think some time back in the 1960s, there was a letter from a chap who got totally fed up with break-ins at his workshop, which was in a rural location. His answer was to buy a redundant electric factory hooter, and wire it to an alarm system so that most of the sound was directed inside the building. I seem to remember that the first low-life to break in ran straight through a glass window in his hurry to get out, and the second was led out, a gibbering wreck. After that, word got around and the break-ins ceased. Pity you couldn't get away with such a trick these days! Edited By Mike on 16/03/2018 17:54:43 Why not? Mick |
Muzzer | 16/03/2018 19:42:32 |
![]() 2904 forum posts 448 photos | Wouldn't you be better off with a couple of webcams covering the entrances and access road? More likely to be deterred if it's clear you are being recorded. These modern cameras store the video and stills on the cloud and can also send texts (movement detection etc) and allow you to view the feed etc. If you have mobile coverage as you say, the cost of data is peanuts. Loads of people make them nowadays, a sort of fusion of connected / smart home appliances and intruder alarms. Bells and lights won't stop them but you might either deter or identify them - or at least filter out the real lowlife vandals who do most damage. Murray |
vintagengineer | 16/03/2018 19:47:39 |
![]() 469 forum posts 6 photos | These are very effective! https://www.youtube.com/watch?v=4D_3nAfmcqY The other deterrent to use MIG wire stretched across the workshop just above ankle height. |
mechman48 | 16/03/2018 20:07:45 |
![]() 2947 forum posts 468 photos | My garage/ workshop conversion is attached to my bungalow & after being burgled back in 2014 I have installed a separate alarm system that has PIR motion detector plus magnetic contacts on the entry door, the advantage of this system is that when the alarm goes off ( tested ) it gives out a very loud 'wow wow' within the garage itself, way above the decibel level that the human ear can tolerate, plus extra lateral bolts in the roll up door very similar to Mike's posting,... fingers x'd, so far, so good. |
the artfull-codger | 16/03/2018 20:58:08 |
![]() 304 forum posts 28 photos | I have 4 night & day cctv cameras that cover our yard and out buildings barn & workshop,but if they want to be in they will, you can only do your best to protect things,I got turned over a few yrs ago & lost a couple of thousand pounds worth of equipment[pre camera days] the theiving scrap men they probably got £30 for the lot also got a couple of burglar alarms too, cops gave me a crime number and asked if I wanted "counselling" hmm. |
FMES | 16/03/2018 23:00:13 |
608 forum posts 2 photos | Got one of these wired up to the alarm internal sounder **LINK** Luvly Regards Lofty |
Mike Poole | 16/03/2018 23:40:44 |
![]() 3676 forum posts 82 photos | My youngest son has trouble getting up in the morning, I decided to wake him up with an industrial Yodel alarm, it did wake key him up but he yanked the supply out of the alarm(24V) 120dB may be a bit excessive in your bedroom. Mike |
peak4 | 17/03/2018 00:17:16 |
![]() 2207 forum posts 210 photos | A friend of mine was recanting a tale about one of his biking friends. Apparently their shed alarm went off, triggering a text to his mobile and the arming of the web cams and recorder. A couple of local scrotes in the shed got something of a surprise, when householder started shouting something about armed response, and chucked a thunderflash in their general direction. There was further damage as well as the shed though, since one of them ran clean though a larchlap fence panel in an effort to escape. All caught on video, and reckoned to be most amusing to watch.
Until I wired it up to the house alarm, my garden workshop housed a 10" fire alarm sounder inside the shed, which made a bit of a din. Edited By peak4 on 17/03/2018 00:18:54 |
Maurice | 17/03/2018 02:26:20 |
469 forum posts 50 photos | With reference to the hinge pins that Howard mentioned, another way to thwart the removal of the hinge pins, or indeed the hinges themselves, my shed has three hinges, and in line with each is a stout plate that overlaps the doorframe when the door is closed so that the door will not come out of the frame. |
Bazyle | 17/03/2018 10:07:59 |
![]() 6956 forum posts 229 photos | Some more ideas on security on this website. |
