Martin Dowing | 06/12/2017 21:17:26 |
![]() 356 forum posts 8 photos | Got a bar of grey cast iron, absolute pig to machine. HSS tool got simply deformed upon attempt to turn it and now need general regrind and carbide tool barely cope with it leaving surface which looks somehow "tortured". How deep such a layer might be? Should I consider this bar faulty and throw it away or after chewing through first 2-3 mm there will be some "normal" iron? Martin |
The Novice Engineer | 06/12/2017 22:47:49 |
85 forum posts 72 photos | I was given some old cast iron sash weights that had a hard surface like yours. I cut anend off with an angle grinder and then tested the core with a centre punch to determine the depth of hard ness, some went to the scrap man! I then used a carbide tool to get through the surfaces of the ones I felt usable.
Hope this helps Steve
Ady1 | 07/12/2017 00:24:19 |
![]() 6137 forum posts 893 photos | Slow speed high torque on the backgear with a 5% (or 10%) cobalt tool for 95% of the job Finish off with carblde at high speed (or cobalt if you resharpen it) (If your lathe is stiff enough the backgear part of the job will look not bad) Use a live centre with fixed steady support to increase stiffmess if possible GL Edited By Ady1 on 07/12/2017 00:27:39 |
Maurice | 07/12/2017 01:55:18 |
469 forum posts 50 photos | Try annealing it. Find a friend with a coke boil er or stove. Put the cast iron into the centre of the fire. Bring to red heat, then cover with fuel and let it "cook" for a few hours, then let the fire go out. Leave the casting in there till it has all cooled down. It worked for me on a set of Clarkson casting that I had, which were un-machineable. Maurice |
JasonB | 07/12/2017 07:20:50 |
![]() 25215 forum posts 3105 photos 1 articles | Very unusual for cast iron bar as that is a joy to machine, sounds like you have a bit of old round sash weight or similar which can vary a lot in how easy they machine.. As Maurice says if you can get the whole bar to bright red and hold it there for half an hour and then allow to cool as slowly as possible you may find it easier to machine but for the effort and cost of the gas you may be better off paying for a decent bit of continuous cast iron bar. |
Chris Evans 6 | 07/12/2017 07:47:51 |
![]() 2156 forum posts | When faced with chilled castings I put em in the woodstove for an evening and fish them out next morning. |
Ian S C | 07/12/2017 12:06:47 |
![]() 7468 forum posts 230 photos | The last chilled window weight I had made it's self known to me before it went in the lathe, I dropped it, and it fell in half, the fracture was shiny, silvery, crystaline. I did try it in the lathe, and with a Carbide tool managed to turn off the rough outer skin, and face the end. Its in the scrap bin, I may try to anneal it one day if I get desperate. Ian S C |
mechman48 | 07/12/2017 16:29:27 |
![]() 2947 forum posts 468 photos | I have some cut offs from sash window weights as well, was going to light up the BBQ & soak them until the BBQ went cold so far the BBQ has remained stored away since we've only had 3 days of summer this year hence I miss the opportunity... ah well there's always next summer... |
John Purdy | 07/12/2017 19:08:36 |
![]() 431 forum posts 252 photos | To echo Maurice, I too had some Clarkson castings that were severely chilled in areas. I put then in my kiln at 1400 deg F for about 2 hours and left them in the kiln overnight to cool. They then machined beautifully. If you can find a friend with a small pottery kiln that is the way to go John |
Neil Wyatt | 07/12/2017 19:43:22 |
![]() 19226 forum posts 749 photos 86 articles | Many years ago the corners on the valve face of my 10V were chilled, first time I encountered this. If you have a chilled sash weight, the best thing to do is drop it on your foot as this will hurt less than trying to machine it. Neil |
Martin Dowing | 07/12/2017 22:01:57 |
![]() 356 forum posts 8 photos | Many thanks for your comments. All of them helped to understand the problem. My material is a bar. Smelter peoples have said that they are making such bars from excess of smelt as occassionally they sell and if not, they can always be remelted. It is not a sash piece. Had few and they were actually OK. I have managed to turn it after all. Once diameter have gone from 42 to 38 mm no more troubles was encountered. Ordinary carbide insert was good enough to chew by hard part. HSS stood no chance. I have few CBN inserts for hard materials but in this case it would be wasteful to deploy them. Regarding heat treatment - I have large fireplace so with enough of wood it might do the trick. Good to know for the future. What are you using to prevent scaling while heating metal to red heat? Martin |
OldMetaller | 08/12/2017 08:06:00 |
![]() 208 forum posts 25 photos | I can confirm that the woodstove treatment works. I often pick up lumps of metal that have been left lying around at work: when we replace, for instance, small track components on the railway, the old ones usually just get thrown down the bank as nobody can be bothered to take them to a scrap bin. I have quite a few large (30mm-ish) nuts and bolts that are still usable but, more importantly, after 'normalising' in the woodstove, will machine beautifully. I assume they are high-tensile, as before normalising, they can't be sawn or filed easily. One caveat, however, is that if you are normalising something like a flywheel, make sure you support it adequately, or you may end up with something Salvador Dali would have been proud of! Regards, John. |
Ian Hewson | 08/12/2017 09:03:23 |
354 forum posts 33 photos | Usually find the edges of castings are pot hard after doing a lot of work on them, not wanting to heat up thin flywheels as John says, I find that mounting the Dremel in the vertical slide usually gets a good finish on them. Slow but faster than returning the casting and finding the same problem with the new one. Not usually enough metal to get under the skin of the castings I seem to buy.
Ian Hewson | 08/12/2017 09:15:34 |
Howard Lewis | 08/12/2017 10:34:06 |
7227 forum posts 21 photos | Chilled cast iron can be glass hard. Cash Iron camshafts, in engines, are often poured with chills in the mould, to chill deliberately for hardening. The cams are then ground, rather than turned or milled. A batch of cylinder block castings, that had been inadvertently chilled, ruined every carbide inserted tooth cutter in a multi station transfer line. Annealing, if possible, before hand, or as soon as discovered, should solve make life easier. Howard |
