Hacksaw | 30/08/2017 17:44:12 |
474 forum posts 202 photos | I don't suppose anyone knows where i could buy say a kilo or 2 of raw black rubber ? . I hope to vulcanize it myself in my own mold , in the oven, when my wife is out...Does it ( raw ) have a shelf life , does it dry out , do you keep it wrapped ?? Baines rubber is near me , I'm sure they use it , but the jobsworth on the counter is negative about selling me a bit ! |
not done it yet | 30/08/2017 17:50:00 |
7517 forum posts 20 photos | Fort Dunlop? Oh, maybe not! |
mark smith 20 | 30/08/2017 19:30:04 |
682 forum posts 337 photos | I don`t think there such a thing as raw black rubber ,its latex which is a milky colour.Or dried latex dissolved in solvent To get the black stuff its mixed with carbon black pigment and sulphur plus other things. I assume you might have been watching that bbc4 programme about plastics???? Your house would stink to helI. I have a large container of latex which stinks of ammonia . The ammonia is added to keep it in an emulified state but shelf life is limited. Edited By mark smith 20 on 30/08/2017 19:32:18 |
Robert Butler | 30/08/2017 19:42:23 |
511 forum posts 6 photos | Black rubber - all sounds rather.....................?? |
Stuart Bridger | 30/08/2017 19:54:29 |
566 forum posts 31 photos | No idea on a source, but I spent a couple of weeks in the rubber moulding department at BAe Brooklands during my apprenticeship. They manufactured non standard seals and mouldings for both prototype and production use. There was a great variety of raw ingredients, which were mixed up and milled before moulding and curing. It really was like cooking, the recipe had to be followed exactly or the result was a disaster. Looking back on it now there was so much I picked up in those days, it just needs posts like these to jog my memory. |
MW | 30/08/2017 21:10:11 |
![]() 2052 forum posts 56 photos | Posted by Hacksaw on 30/08/2017 17:44:12:
I don't suppose anyone knows where i could buy say a kilo or 2 of raw black rubber ? . I hope to vulcanize it myself in my own mold , in the oven, when my wife is out...Does it ( raw ) have a shelf life , does it dry out , do you keep it wrapped ?? Baines rubber is near me , I'm sure they use it , but the jobsworth on the counter is negative about selling me a bit ! I have a load of 30mm round P.U ( black) rubber bars if that helps? I can also link you to the Alibaba page where I got it from, factory seems legit. Michael W Edited By Michael-w on 30/08/2017 21:11:41 |
Hacksaw | 30/08/2017 21:58:35 |
474 forum posts 202 photos | I think want some similar to this type at 3.00 **LINK**
It' for a thick gasket rubber moulding .. My prototype mould is a bit rough |
Hacksaw | 30/08/2017 22:59:51 |
474 forum posts 202 photos | It's a foglight gasket for a Ford Fiesta mk1
2 rectangular plates and spigots will make this sides shape, then a clamping plate on top (and the top corners need a shallower radius I know , hence it's only tacked together at the mo . )
Low temperature (supposedly ! )melt rubber stuff., trial fill .. Step on the swage line just right !
So I want to put the rubber dough in the mould bolt through the middle clamping the plates till it oozes out , and then cook it . Edited By Hacksaw on 30/08/2017 23:03:42 |
thaiguzzi | 31/08/2017 04:29:20 |
![]() 704 forum posts 131 photos | Pop out here. I'll give you a couple of kilos for free. I have 25 acres of rubber trees being tapped, we just sold @ auction yesterday, cup lump (yes it does pong) at roughly 0.67 pence per kg. |
Clive Hartland | 31/08/2017 08:36:29 |
![]() 2929 forum posts 41 photos | Perhaps try some of that self amalgamating rubber tape used for sealing cabling, You may need a a few reels though. Strip off backing and layer it and see what happens when you apply a little heat and pressure. Clive |
Jon Gibbs | 31/08/2017 09:21:16 |
750 forum posts | Sugru? Not cheap but would do the job I think. Jon |
Gordon W | 31/08/2017 10:21:19 |
2011 forum posts | I have been using cheap hot glue gun for this sort of job. Buy some black filler rod and practice a bit, just refitted mud flaps on my motor and looks quite good, by my standards anyway. |
Ian S C | 31/08/2017 12:07:17 |
![]() 7468 forum posts 230 photos | When I was helping a guy building, and rebuilding Willys Jeeps, I made some molds, and a firm in Christchurch(NZ) cooked them up. The molds cost me next to nothing to make, but I was told that their value would range from $NZ1000 to $NZ3000. What sort of rubber do you need, most of ours was done with 5011 Hy Car Nitrile rubber, this stuff is fuel proof. Ian S C |
Hacksaw | 31/08/2017 15:52:03 |
474 forum posts 202 photos | Thanks for ideas , my panic is over , something exciting is being posted to me ! From the tyre remoulders |
richardandtracy | 31/08/2017 16:11:07 |
![]() 943 forum posts 10 photos | Could use silicone casting rubber from www.mbfg.co.UK the red hardener stuff, 20 shore A, is excellent. Takes 8 hrs to cure, can be coloured and if a mould release is used, it can be used as the mould too. The Polycraft GP 3481-F is stuff I have used, and bought some more after finishing the first 500g. Only the hardener is a bit unpleasant, the main component is inert, as is the cured rubber. Regards Richard |
Adrian R2 | 31/08/2017 16:32:31 |
196 forum posts 5 photos | Have you thought of trying plumbers adhesive mastic, Tigerseal or similar? This is thick black and sticky but dries to a rubbery consistency and would probably hold a moulded shape. I don't know its longevity but the outside galvanised tank that I glued up a couple of years back is still holding water. |
mark costello 1 | 31/08/2017 18:32:52 |
![]() 800 forum posts 16 photos | Could You go to a tire retreaders and get a sample? |
Watford | 31/08/2017 18:50:01 |
![]() 142 forum posts 11 photos | I have had success with cold casting rubber.
From MB FibreGlass the variety I used was 'Polytek PT-Flex 85 PU Casting Rubber'.
There is a range of hardness's, 85 being at the hard end and equated to trolley caster wheels.
I was/am restoring a very vintage typewriter and need a new roller. I have had a trial run on a short roller which went O'K.
MB FibreGlass is worth a look as they have a vast range of such products.
http://www.mbfg.co.uk/polyurethane-rubbers/duroflex-85.html |
Neil Wyatt | 31/08/2017 19:49:45 |
![]() 19226 forum posts 749 photos 86 articles | Or just buy one off eBay for £5...
richardandtracy | 31/08/2017 20:05:46 |
![]() 943 forum posts 10 photos | Where's the fun in that? Regards Richard.
