Here is a list of all the postings Hacksaw has made in our forums. Click on a thread name to jump to the thread.
Thread: Flat bar steel for track |
26/09/2023 20:03:42 |
Brundles |
Thread: Steam-Wagon Steering Query (Ackermann) |
28/06/2023 23:34:10 |
Any helpful info in this thread on a Super Sentinel ?
Thread: What is this for ? |
16/04/2023 17:50:14 |
I did a buy in Lidl this morning .Gas powered soldering irons for 16 quid . Actually , it is a bit naff , (weak ) ..I just tried it ...but there you go...I've bought it now . The hot bit doesn't touch ,and burn , the workbench when you put it down , so that rest is useful for resting a fag whilst soldering
Edited By Hacksaw on 16/04/2023 17:50:31 |
10/04/2023 14:30:22 |
I thought it could be a book mark / paper clip for holding plans ! |
10/04/2023 14:28:04 |
Brilliant thanks ! I can put that to use !! In fact i'll make some bigger ones for my angle grinders !! |
10/04/2023 14:15:10 |
It was on my late fathers workbench . It's about bank card size .. He made 4mm scale locos shim brass ... from Garbage or a tool ? |
Thread: Jupiter and Venus |
01/03/2023 19:47:29 |
Popped out for a fag a moment ago, and saw 2 aircraft with landing lights close together , coming into Gatwick ....low in the western sky. In 5 minutes they didn't move though...because it is Venus and Jupiter !! Go look ! |
Thread: Christmas Cracker Jokes |
25/12/2022 20:41:38 |
What did the drummer call his daughters ? Anna one .. Anna two.. |
Thread: Early Stuart I.C. engine |
08/11/2022 12:30:03 |
Is that 4 cylinder 50cc engine still on display at the museum ? |
Thread: 41/2" discs |
02/09/2022 10:52:15 |
I get through hundreds of 1mm discs , like jaCK says above ,if you want speed plunge it , if you want disc life drag it back towards you .. I found the Screwfix discs ok . Avoid Silverline from the Saturday market stall if you want disc life ! A trial on youtube
Thread: Smart and Brown Model A Fine feed adjustement |
18/07/2022 22:23:03 |
On the subject of S&B ,if i could interrupt ...On a Model M fine feed , how do you trigger it off ? Am i missing an adjustable " Stop" ? Or is the onus on the operator to hit the knob down just in the nick of time ?( which is what i do...) Also what are the knurled parts for either side of the apron where the power feed axle enters and exits ? |
Thread: Giving an aged look to alloy |
23/04/2022 22:39:58 |
What would happen if it was placed in a poly bag filled with oxygen ? Would brass tarnish overnight ? |
Thread: Rising costs of materials |
12/04/2022 16:42:24 |
3 x 6m lengths of 30x6 black rolled delivered just cost 40 quid . (Local fabricator ..i asked if he'd put my order in with his to get free delivery ) Not too bad ?
) Edited By Hacksaw on 12/04/2022 16:42:59 |
Thread: Metal Cleaning Using Vinegar? |
29/01/2022 00:04:48 |
My favorite is lemon juice . Tesco's sell big bottles for a quid . Buying several bottles at once gets questioned sometimes at the till , if that's all you're buying .. I just say i like pancakes , and they laugh |
Thread: Just Finished, I think! |
11/01/2022 16:29:07 |
(off topic ...) My fraudulent cousin I adored ( he's gone now ) also played a mean lead guitar in a Beat group in the 60's and pretty good was they, too . Claim to fame , as support band , he shared a dressing room one evening with a young guy called Paul.. The gig was at the Invicta Ballrooms , Chatham I think the date was 12th January 1963... and the other group were pretty good he said.... |
10/01/2022 17:52:18 |
That's brilliant .
I was in awe of my grown up cousin when i was small in the 60's . And he thought the world of me , always buying me Dinky toys and showing me " Magic tricks " .. He worked at Chatham Dockyard refitting submarines. He made a skeleton clock ,(in dockyard time...) it was under a glass dome in his mums house . Corrr , I thought , he must be really clever ..all those wheels filed out and shiny , and it worked... Then he got married and moved away to Rosyth when the dockyard closed , we kinda never saw them again , i was heartbroken ! Forward a few decades , he's retired and he comes down south to visit relatives , and we meet up . I mention my memory of the clock . . " Christ no " he says " I didn't make just one ..I made dozens !! Well i didn't actually make them "Then we'd send them to an auction....slip them in with other junk we'd found .. What a fraud ! And i idolised him !! Edited By Hacksaw on 10/01/2022 17:53:41 |
Thread: Lidll |
04/01/2022 00:10:46 |
I opened the old 16 v battery earlier today . It has a printed circuit board , packed with i.c.'s inside . ..so i thought I'll just put that back together....I can't fix that .but I'm sure it had 4 cells.. I've used it a bit , it was 16v .
And the new 20v one fully charged ............20v ..go figure !
03/01/2022 14:47:59 |
A new 16v parkside original battery for the old drill is 17 quid online . It still charges but it is dying . The drill is tired too though! I don't know anything about Li ion but it was at 3.5v dead flat an hour ago .I've charged it till the light went green (3/4 hour Lidls often have the newer "x " fit 20v batteries for cheap.
I've many a time run it down to flat and then slippped in the charger for ten minutes to finish a job..and then not charged it fully for a while . is that a good way of ruining a Li ion battery ? It's been charged hundreds of times ! Edited By Hacksaw on 03/01/2022 14:51:20 Edited By Hacksaw on 03/01/2022 14:53:28 |
03/01/2022 14:12:25 |
Parkside Drill update , purchased May 2017 until January 2022 . Well, it just about holds a charge still after much abuse . Rubber bits peeled off , the casing hasn't broken or cracked . The Drill /Screwdriver selector switch did fail recently causing it to jump into neutral when drilling , along with a dreadful screech of mashing gears !! .A detent spring holding the selector in place , had just disappeared.. when i took it to bits to look . A new one was made which kind of worked .. Anyway for 29.99 it did ok !!
I saw that Lidlls was selling drills again today .Gone up to £39.99 .This time they're up at 20v 2Ah..slightly larger ,a fair bit heavier .You get a set of screwdriver bits and a few drills ,which appear good quaility . ( As good as the 107 drill pack i bought last week ! ) The chuck is all metal now. Now the other good thing is the 20v battery is interchangeable with the Parkside Impact gun i have , that is 4Ah .It does make the drill somewhat heavier though . Pics
Edited By Hacksaw on 03/01/2022 14:15:32 |
Thread: Brittle stainless steel |
24/11/2021 23:37:56 |
Yeah ,I know they're dreadful things, but they do come in handy for rapid local heating !
I'm a Noel too . I was born on Xmas day |
