Here is a list of all the postings Stuart Bridger has made in our forums. Click on a thread name to jump to the thread.
Thread: Wera hand-tools |
04/10/2023 11:52:00 |
RS have always had a premium price, you were paying for pretty much guaranteed stock availability and next day service, that was well before the internet. Obviously others have cuaght up with them since. |
Thread: Drain plug |
03/10/2023 20:15:52 |
looking at the chuck from the tailstock end, bottom right of headstock. |
Thread: Help! Excessive machine marks! |
22/08/2023 18:10:29 |
I have never seen HSS tooling sold suitable for brass, As mentioned I have never bothered with grinding specifically. |
22/08/2023 17:48:10 |
There could be a number of things here |
Thread: Arceuro |
16/08/2023 18:53:58 |
Similar experience from GWR fasteners this week. Ordered on Monday and took the lowest cost delivery option as they weren't urgent. This was First Class Post and they arrived Tuesday morning. |
Thread: Do you need an oil change with less than 10,000 miles in 10 years? |
13/07/2023 15:17:18 |
I had a honda 4 stroke lawnmower that I inherited from a relative. No idea when it was last serviced. I had checked the oil level at the start of each season and replaced the plug a few times for starting issues. Edited By Stuart Bridger on 13/07/2023 15:29:57 |
Thread: when you go for a pee ... |
13/07/2023 15:01:54 |
When I started my apprenticeship in 1980, it was very much impressed on us to wash hands before. The message reinforced by some very graphic photos of the potential consquences of not doing so. |
Thread: Quick change tooling for the mill? |
14/06/2023 18:31:18 |
Thanks for all the feedback. I am using an "old school" Clarkson style milling chuck. I hadn't considered switching to ER collets. That looks to be the best way forward.
14/06/2023 13:38:45 |
Anyone have any experience with R8 quick change tooling? The Cutwel EZchange system looks good on paper . It's not cheap though and I could easily invest in a pillar drill for about the same money. |
Thread: Warco VMC spindle knocking |
05/05/2023 11:53:42 |
Simon, see Roger's post above for a good explanation, the idea is that you are trying to minimise the interrupted cut and smooth the entry of the tooth. If the cutter is larger than the workpiece you are running the cutter down the centreline. The tooth entrypoint will be at 90 degress to the edge of the work with quite a high impact. Moving the cutter off to one side so it just clears the edge of the work will result in a much shallower entry point angle for the tooth. |
Thread: ALSGS Power feed oops on Warco VMC |
01/05/2023 13:50:37 |
When you are installing your new power feed and just have to do a test BEFORE installing the limit switches AND you don't appreciate the range of the Z axis.I drove it down until it hit the bottom... All was not lost, replacement "Zytel Gear" ordered via the usual auction site at not great cost. It arrived from China in good time. Spent this morning fitting the limit switches BEFORE replacing the gear. Still a few tasks to complete the install of the Z feed, but already appreciating the X feed working under power. Edited By Stuart Bridger on 01/05/2023 13:52:37 |
Thread: Should I buy a posher digital micrometer/caliper? |
27/04/2023 09:59:19 |
i invested in a Mitutoyo digital caliper last year after getting tired of the sheer waste, cost and inconvenience of replacing batteries virtually every time I need to use the cheap one. Great investment, so much better feel and battery life is a magnitude better. |
Thread: Road bridge weight limits. |
23/04/2023 22:12:37 |
Newbridge (second oldest crossing over the Thames) had its rating reduced to 18 tonnes MGW after numberous HGVs were damaging the structure. The engineers calculated that one of the arches shouldn't support its own weight. The 13thC Bridge designers obviously knew better. |
Thread: Major flaw in the world of engineering |
21/04/2023 15:32:18 |
I do sympathise with the OP, it is a bit of a minefield getting started. I was lucky enough to have engineering apprenticeship under my belt. Although it was a 30 year gap to when I started my own workshop, the basics soon came back to me. Like others, I did a huge amount of research before getting out my wallet. I will admit to making mistakes with cheap tooling. The vice "bundled" with my mill was near to useless and I have upgraded a number of other pieces since. Is there a local ME club you could get advice from? Not knocking the advice here but a friendly face and eyes diretcly on the problem(s) can be very valuable. |
Thread: Battery powered lawn mowers? |
21/04/2023 15:09:38 |
I have a Husqvarna, it is excellent and does a great job. Now in its 3rd season. Big advantage is commonality of batteries across other tools. I also run a pole hedge trimmer and chainsaw on the same battery. |
Thread: Is this a Warco / Metric thing...or am I just out of date? |
19/04/2023 09:32:30 |
My 1963 Colchester Chipmaster is graduated on diameter. I also have my apprentice journal from 1980, I learned to turn on a Colchester Student 1800, no mention there of cross slide graduations and radius/diameter. I have to assume it was aslo showing diameter as wehn i got my Chipmaster at home some 30 years later, I didn't have any surprises. So definitely not a new challenge |
Thread: Remotely oiling a workshop of line shaft machinery |
17/04/2023 19:41:58 |
How about a gravity fed system? Have a header tank, witha manifold plumbing into each oiling point with a tap to control the flow rate. The header tank could be topped up daily from a hand pump. Also have an overflow pipe back to your source, so no need for any level monitoring on the header. Just pump until it overflows back down. |
Thread: VFD documentation, almost useless |
13/04/2023 08:03:21 |
I agree with Clive in that the terminal labelling is all out of line with the functions. Very scary ansd potentially dangerous for those not familiar with such devices. It can be confusing enough undertanding these devices even with a correct diagram. I have to say if quality control lets this slip though in the manual, what else could be wrong? |
10/04/2023 15:56:15 |
Hi Roger, |
09/04/2023 20:56:28 |
Thanks for the feedback, some very good points |
