mark smith 20 | 15/06/2017 10:33:00 |
682 forum posts 337 photos | Im not into cars really but this turned up out of the blue and found it fascinating .A Rolls SIlver ghost i think. Wife took photos on her phone camera. A few more photos in my albums under Rolls. |
John Rudd | 15/06/2017 10:35:46 |
1479 forum posts 1 photos | Magnificent does not even come close......what a marvellous car.. |
John Stevenson | 15/06/2017 10:42:18 |
![]() 5068 forum posts 3 photos | You would have thought that with all that money involved he could have afforded a bonnet cover? Edited By John Stevenson on 15/06/2017 10:43:02 |
Steven Vine | 15/06/2017 10:51:08 |
340 forum posts 30 photos | Posted by John Stevenson on 15/06/2017 10:42:18:
John, that's the engine cooling system. Steve |
Speedy Builder5 | 15/06/2017 11:22:27 |
2878 forum posts 248 photos | Yep, couldn't afford the spokes for the spare wheel! Very impressive (excuse the pun) door and body pressings for the time. I note he didn't have the windscreen straps on, so perhaps not going on a long trip. |
richardandtracy | 15/06/2017 11:30:09 |
![]() 943 forum posts 10 photos | Given the age & production numbers, more likely to be panel beaten I think. Looks absolutely immaculate. Somewhat envious. Regards Richard - 2CV Charleston owner |
Mike E. | 15/06/2017 13:02:58 |
![]() 217 forum posts 24 photos | Wow, what a jewel ! I remember seeing a Rolls similar to that for sale for ten thousand dollars at the Rose Bowl swap meet in California back in 1970. There was also a gull wing Mercedes for sale for fourteen thousand at the car show held on my High School's football field the same year. If one could only have speculated their future value and desirability in todays world. |
Perko7 | 15/06/2017 13:09:39 |
452 forum posts 35 photos | Reminds me a bit of a RR 20hp tourer owned by a friend of my father. Like most RR's it could be started without using the starter. The reason given, I am told, was that when 'sir' was departing from the club, the noise of a starter motor, or the need to turn a crank handle to start the engine, was not deemed 'seemly'. The process apparently was that, while waiting for his master, the chauffeur would carefully turn the crank handle a few times with the ignition turned off to prime each cylinder, then make sure No. 1 piston was not far past tdc. When 'sir' arrived, the ignition was switched on, and the advance/retard lever on the steering column rapidly moved to full retard and back which would introduce a spark on the spark plugs in the primed cylinders. The engine would spring into life and away they would go. I saw this demonstrated a number times on the RR 20hp tourer mentioned above. It seemed to work about 4 times out of 5, which is still pretty impressive. |
Jonathan Garside | 15/06/2017 13:16:29 |
52 forum posts 3 photos | Looks like AX 201 a 1907 40/50 Silver Ghost built in Manchester, now owned by Bentley Motors in Crewe. Reputably the most valuable car in the world. Jonathan |
John Flack | 15/06/2017 15:20:00 |
171 forum posts | As no more as no more than a silly question, if you owned it would you actually use it??????
A story you won't believe , about 1960 drove my moggie to a club rally held in Malvern, I stopped at a garage on the bank of the R Avon it resembled an old coaching inn with a courtyard type stable/Garage units. The attendant looked at my vehicle and said "you into old cars.? I had a bloke done a runner owing garage rental of £150 , my solicitor says I can sell it to get my money back he unlocked a door revealing a type 35 Bugatti it's yours if you want it. Being the weekend, 150 miles from home, in days before I had bank account or credit card I could do nothing but weep. I did say you would not believe it but it really is true. |
Oldiron | 15/06/2017 17:08:06 |
1193 forum posts 59 photos | John Stevenson :- If you look closely the bonnet is folded over to the near side. It has been lifted to show the engine off. Gary |
Geoff Theasby | 15/06/2017 17:11:13 |
615 forum posts 21 photos | Despite this being a 'deprived constituency', I've seen Mercedes convertibles, hot rods, Overfinch and Revere Range Rovers in this street in recent weeks. Geoff |
Phil P | 15/06/2017 17:12:22 |
851 forum posts 206 photos |
Posted by John Flack on 15/06/2017 15:20:00: As no more as no more than a silly question, if you owned it would you actually use it??????
A story you won't believe , about 1960 drove my moggie to a club rally held in Malvern, I stopped at a garage on the bank of the R Avon it resembled an old coaching inn with a courtyard type stable/Garage units. The attendant looked at my vehicle and said "you into old cars.? I had a bloke done a runner owing garage rental of £150 , my solicitor says I can sell it to get my money back he unlocked a door revealing a type 35 Bugatti it's yours if you want it. Being the weekend, 150 miles from home, in days before I had bank account or credit card I could do nothing but weep. I did say you would not believe it but it really is true. A pal of mine obtained a couple of XK120 Jaguars in similar circumstances about five years ago. All he had to do was remove them from the garage where they had been left, within three days. Phil Edited By Phil P on 15/06/2017 17:14:49 |
Neil Wyatt | 15/06/2017 19:54:49 |
![]() 19226 forum posts 749 photos 86 articles | When my dad was much younger than I am, he saw some local wide boys trying to bump-start a Vincent HRD Rapide. He asked if they had changed the valves and they had. he guessed that hadn't ground down the valves to match the push rod wear (I think that was the problem) and offered them a scrap price for it. they said yes as they were on the verge of throwing it in the docks. He did it up, but ended up selling it when I arrived A few years ago I tracked it down in an old issue of the Vincent Owners club newsletter -- it had ended up in the hands of their chairman. Neil
John Stevenson | 15/06/2017 19:55:30 |
![]() 5068 forum posts 3 photos | Way back around 74, 75 we had a garage near us that dealt in old rolls Royces. Most of these were shopped to the States One day a friend called round and whilst we the talking he mentioned that old man Nudd had got an old rolls pickup round the back Now the pickup bit interested me so took a ride down and sure enough it was a pickup Car would be about an early 30's big radiator, no silver lady obviously. Asked Nuddy about the history but he didn't know I'm surmising that it was owned as a car by some estate somewhere and it it grew older it was replaced but they had the coach builders modify this into a pick up for the ground staff as the conversion was too neat for a hone built It wasn't in bad nick for its year seats were all split and worn and the bed had seen better days but main problem was the engine had been robbed. No head manifolds, waterpump, dynamo or starter but that didn't worry me as I fancied doing a lump transplant with a Commer TS3 engine of which we had loads kicking about. So asked how much and he wanted. 100 pounds Offered him 80 but he wouldn't accept. Kept going back but neither of us would move on price No idea what happened to it,probably broke up for spares |
Samsaranda | 15/06/2017 20:27:32 |
![]() 1688 forum posts 16 photos | In 1960 I lived on a farm in Devon for six months, as a thirteen year old I was in heaven, what a great life, used to help the farmer with milking there were a dozen cows which we milked by hand. During my stay there the farmer acquired a new car which was a 1920's Rolls Royce saloon, it was not in concours condition but because the boot lid opened and formed a level platform he found it ideal for carrying his milk churns on the opened lid. Every day he drove up the lane with the churns to leave them for the dairy Lorry to collect. He was regarded by his peers as somewhat eccentric before he acquired his Roller but more so afterwards. Dave
Robbo | 15/06/2017 22:18:39 |
1504 forum posts 142 photos | This must belong to a farmer. They keep telling me they can't afford new cars. |
